Hello I am here to learn I have a Macbook Pro intel 2019 and I would like to convert an MKV H.265 video in H.264 what is the best software thank you in advance
in fact I'm looking for software to encode without making my macbook heat up to encode in H.265
Results 1 to 10 of 10
I tried with Handbrake my macbook when I ancode heats up enormously
and with LosslessCut I can do it? I just downloaded it I can't find how to do it
to encode in H.265 -
You can try to disable the Turbo Boost.
How to cool down CPU while encoding with GPU
Ctrl.blog: Disable processor boost mode to prolong your battery life
See this tool for the Intel MACs:
Turbo Boost Switcher for Intel Mac -
Encoding video is a very intensive task, so it will still heat up the CPU of course.
But if disabling Turbo Boost only is still not enough you have to somehow limit the maximum CPU speed/use further.
Here are some possible options?
AskDifferent: Limit entire system's CPU usage (MacOS) -
Vidéo MKV H.265 in H.264
By filderiques in forum Newbie / General discussionsReplies: 5Last Post: 6th Oct 2024, 07:11 -
H.264 to H.265
By Jay123210599 in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2023, 21:35 -
The new MacBook Pro M1 systems are beasts for video editing
By sophisticles in forum Latest Video NewsReplies: 8Last Post: 8th Dec 2020, 06:41 -
Base Macbook Pro 16 for video editing
By Shul1994 in forum MacReplies: 1Last Post: 23rd May 2020, 16:59 -
Playing 4K HDR HEVC video on 2017 MacBook Pro to external monitor
By hmnlzr in forum MacReplies: 3Last Post: 20th Mar 2020, 15:52
