  1. Hello. I’m trying to figure how it works the CDRM Project 2.
    https://cdrm-project.com/
    For example I’m testing with this link:
    https://vix.com/es-es/video/video-4152473
    I watched a video but I see is very different.
    From that link for example I figured this is the link I found to deal:
    curl https://dcs-vod.mp.lura.live/vod/p/session/manifest.mpd?i=i176980022-n498ac97c-24e2-41...4-5368e4122a15
    From there I have:
    AAAANHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABQIARIQAf 4y/JN6rsAG20TZSwhSvQ==
    And the link from license link is ok?
    https://drm3.mp.lura.live/cenc?eqp=FL3rPNsRxGdqj6bhtpQDie2wP6qbOWNFU2InWQ9D21bBxr9fLeC...4&t=1726083444
    If I enter in link:
    PSSH:
    License link:
    And nothing else the rest empty and decrypt I have the keys:
    01fe32fc937aaec006db44d94b0852bd:597edc513aa5bc386 164fbc163c5037e
    00fe32fc937aaec006db44d94b0852bd:b3d40088b2abbb0d2 2520f8359232d15
    02fe32fc937aaec006db44d94b0852bd:042d0ccb0c9680780 9704844b1fb5f4b
    But if I give:
    N_m3u8DL-RE -M format=mkv -mt "https://dcs-vod.mp.lura.live/vod/p/session/manifest.mpd?i=i176980022-n498ac97c-24e2-41d0-9e85-35fb0cebd59b&guid=4ff931d8-053b-1334-5368e4122a15
    " --key 01fe32fc937aaec006db44d94b0852bd:597edc513aa5bc386 164fbc163c5037e --key 00fe32fc937aaec006db44d94b0852bd:b3d40088b2abbb0d2 2520f8359232d15 --key 02fe32fc937aaec006db44d94b0852bd:042d0ccb0c9680780 9704844b1fb5f4b
    I have an mkv that has no video or is encrypted who knows. What am I doing wrong there or what is the correct use of the links to fill in the cdrm project according the example video I give here?
    I have several days figuring but nothing.
    Thank you
  2. https://forum.videohelp.com/threads/414140-%5BRelease%5D-Widevine-L3-Guesser-Extension...-Chrome-All-OS
    N_m3u8DL-RE "https://dcs-vod.mp.lura.live/vod/p/session/manifest.mpd?i=i176979985-ncd75a50c-e0a7-400e-b835-f326b0c2a0ce&guid=63a7df30-e8e4-1dbe-9237a2af51c4" --save-name "Ver.Por.Estas.Calles.Capitulo.2.Baleo.Inesperado" --select-video best --select-audio best --select-subtitle all -mt -M format=mkv  --log-level INFO --key 01fe32fc937aaec006db44d94b0852bd:597edc513aa5bc386164fbc163c5037e --key 00fe32fc937aaec006db44d94b0852bd:b3d40088b2abbb0d22520f8359232d15 --key 02fe32fc937aaec006db44d94b0852bd:042d0ccb0c96807809704844b1fb5f4b
    https://gofile.io/d/WwJaTj
  3. Your instruction works fine, but what I noticed is that you had a line break before the first key and at the end of the MPD link, I don't know if that is what was causing your errors...
    https://forum.videohelp.com/attachment.php?attachmentid=82186&stc=1&d=1726100330
  4. Oh I see I have a wrong formatted the command line. @Silv3r Worked perfect. I noted the link:” https://dcs-vod.mp.lura.live/vod/p/session/manifest.mpd?i=i176980022-n498ac97c-24e2-41...-5368e4122a15” changes eventually but it works the same keys.
    Thank you for the help
  5. I literally used your same instruction, I copied it as is, the only thing I changed is that line break I had... It is not difficult to get the keys out of ViX, I can confirm that it is done in the way you did it.
