I just found out that according to the creator of Deblock_QED, that function should be used before deinterlacing. The problem is that Delock_QED works only with progressive videos, so he provided this workaround:
I'm trying to make a generic function to be used on every video with interlacing that needs deblocking. I wrote this code:Code:par=getparity() SeparateFields().PointResize(width,height) Deblock_QED() AssumeFrameBased() SeparateFields() Merge(SelectEven(),SelectOdd()) par ? AssumeTFF() : AssumeBFF() Weave()
but I got the error "Weave should be applied on field based material. Use AssumeFieldBased() beforehand." Where is the issue?Code:function Deblock_QED_Interlaced_Source(clip c, int quant1, int quant2) { par=getparity(c) SeparateFields(c).PointResize(c.width, c.height) Deblock_QED(c, quant1, quant2) AssumeFrameBased(c) SeparateFields(c) Merge(SelectEven(c),SelectOdd(c)) AssumeFieldBased(c) par ? AssumeTFF(c) : AssumeBFF(c) Weave(c) } Deblock_QED_Interlaced_Source(30, 30)
You are applying Weave on c which was not modified by any of the other lines.Where is the issue?
You might want to read up on variable use and assignments in Avisynth.
I assume:
orCode:function Deblock_QED_Interlaced_Source(clip c, int quant1, int quant2) { par=getparity(c) c = SeparateFields(c).PointResize(c.width, c.height) c = Deblock_QED(c, quant1, quant2) c = AssumeFrameBased(c) c = SeparateFields(c) c = Merge(SelectEven(c),SelectOdd(c)) c = AssumeFieldBased(c) c = par ? AssumeTFF(c) : AssumeBFF(c) return Weave(c) }
is what you are trying to do,.. (didn't test this, but I think I didn't miss anything)Code:function Deblock_QED_Interlaced_Source(clip c, int quant1, int quant2) { par=getparity(c) c = c.SeparateFields().PointResize(c.width, c.height) c = c.Deblock_QED(quant1, quant2) c = c.AssumeFrameBased() c = c.SeparateFields() c = c.Merge(c.SelectEven(),c.SelectOdd()) c = c.AssumeFieldBased() c = par ? c.AssumeTFF() : c.AssumeBFF() return c.Weave() }
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
"Invalid arguments to function Merge"
needs to beCode:c.Merge(c.SelectEven(),c.SelectOdd())
without the 'c.' at the start.Code:Merge(c.SelectEven(),c.SelectOdd())
Cu Selur
Ps.: Depending on your content, using QTGMC to deinterlace, then apply Deblock_QED and re-interlace might be better.Last edited by Selur; 10th Sep 2024 at 14:03.
Where? What you linked was a workaround mentioned, if you don't want to deinterlace.I just found out that according to the creator of Deblock_QED, that function should be used before deinterlacing.
I can't remember that Didée ever wrote that Deblock_QED should be used before deinterlacing.
(I think that statement is simply wrong.)
then deblock after deinterlacing,..The results of my Avisynth scripts are always progressive
Here's my version of deblock_QED_i() for interlaced video. It requires deblock_QED().
Code:function Deblock_QED_i ( clip clp, int "quant1", int "quant2", int "aOff1", int "bOff1", int "aOff2", int "bOff2", int "uv" ) { quant1 = default( quant1, 24 ) # Strength of block edge deblocking quant2 = default( quant2, 26 ) # Strength of block internal deblocking aOff1 = default( aOff1, 1 ) # halfway "sensitivity" and halfway a strength modifier for borders aOff2 = default( aOff2, 1 ) # halfway "sensitivity" and halfway a strength modifier for block interiors bOff1 = default( bOff1, 2 ) # "sensitivity to detect blocking" for borders bOff2 = default( bOff2, 2 ) # "sensitivity to detect blocking" for block interiors uv = default( uv, 3 ) # u=3 -> use proposed method for chroma deblocking # u=2 -> no chroma deblocking at all (fastest method) # u=1|-1 -> directly use chroma debl. from the normal|strong deblock() last=clp par=getparity() SeparateFields().PointResize(width,height) Deblock_QED(last, quant1, quant2, aOff1, aOff2, bOff1, bOff2, uv) AssumeFrameBased() SeparateFields() Merge(SelectEven(),SelectOdd()) par ? AssumeTFF() : AssumeBFF() Weave() }
File size 3x bigger when using Avisynth trim function through VDub2
By VideoYak in forum Newbie / General discussionsReplies: 6Last Post: 9th Sep 2023, 07:58 -
any one got guide on how to install avisynth that don' point to avisynth.nl
By MrKool in forum Newbie / General discussionsReplies: 7Last Post: 9th Aug 2023, 11:57 -
avisynth/AvsPmod macro/function to append videos
By Marc1973 in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2023, 01:27 -
AviSynth Script error: there is no function named "setmtmode"
By minimax in forum RestorationReplies: 27Last Post: 10th Sep 2021, 04:57 -
Create a function in Avisynth to apply a logo on a clip
By kaskaï in forum EditingReplies: 1Last Post: 9th Apr 2020, 10:03
