How disable black line (border)?
Panasonic DMR-EH58
Capture component: Behold 8
Capture HDMI: No name HDMI Video Campure (to USB-C)
VHS->Capture
No border
VHS->DMR->Capture (Component) (work TBC)
Add black border. Part of the left image has been lost
VHS->DMR->Capture (HDMI) (TBC not work?)
no border
Compare:
https://slow.pics/c/5xSX811S
There are always black borders on the analog outputs, only the HDMI out does not have them (same with most other dvd recorders and players and other devices that digitize video.)
I have a EH58 myself and the TBC definitely works whatever output you use including HDMI (it would be very odd if it didn't.) Maybe it just doesn't look like it since you are now seeing the full borders of the video which may not look 100% clean. -
This is overscan data. It's normal, it's expected. The signal is 704, the palette is 720. You can crop to 704x576, leave it interlaced. In fact, cropping 16 pixels is the correct way to crop prior to 720x540 (4:3) resize.
I may see some wiggling and tearing in the HDMI output, and the line TBC may not be active.
Using a cheap HDMI capture card is a huge mistake. You can readily see the typical awful blown exposure. You're making crappy video conversions.Want my help? Ask here! (not via PM!)
Border thickness depends on how the capture card handles the HBI signal burst, Some are advanced, some are retarded, some are somewhere in the middle, line TBCs tend to have thin border because the way they process scan lines in a memory buffer, so they have a better prediction on where the line starts exactly because of that delay advantage.
To remove it completely you're going to make compromises, the vertical resolution will have to be cropped as well to keep the aspect ratio, The resulting resolution will be illegal, so it must be resized to a legal resolution. resizing it to a higher resolution is recommended or you will get the resizing jagged edges, Imagine going from say 560 lines back to 576 lines, that will destroy the video. The best compromise is mask the junk.Last edited by dellsam34; 5th Sep 2024 at 15:33.
DVD Recorders in analog passthrough may crop the picture horizontally slightly. See the discussion around here:
https://forum.videohelp.com/threads/413492-Missing-pixels-with-s-video-vs-firewire-cap...e2#post2725356
So one may loose a few pixels. There's nothing one can do about it.
And by the way be careful with the levels, e.g. blown out (DMR) or clipped whites (HDMI, loosing details in the brights). More important than a few pixels loss, IMO.Last edited by Sharc; 6th Sep 2024 at 07:38.
Canopus ADVC 100 Gives Only a Black Screen With a Thin Vertical Line
By dman535 in forum Capturing and VCRReplies: 6Last Post: 6th Oct 2024, 03:04 -
How do I reduce a multi-line script to 1 line?
By LaserBones in forum Newbie / General discussionsReplies: 8Last Post: 16th Aug 2024, 17:42 -
How to add an empty line after every line?
By Nico Darko in forum SubtitleReplies: 17Last Post: 25th Jan 2023, 22:24 -
DVD Subtitles IDX/SUB Always Black Text with Black Outline in VIDEO_TS
By larrygrobertson in forum Authoring (DVD)Replies: 2Last Post: 23rd May 2022, 12:02 -
Divide each line of text into new subtitle line
By martanius in forum SubtitleReplies: 1Last Post: 11th Apr 2021, 16:21
