Hi all,
I've downloaded and decrypted a track with the format 'AAC_24' from Spotify.
I already opened a thread on the 'Audio' Sub-Forum but we didn't get far and I wanted to post this in here too as this Sub-Forum is more active and it's somewhat related to Video Streaming Downloading.
A link to the unmodified (just decrypted) version of the file: https://forum.videohelp.com/attachments/80672-1720858349/file.aac
Its file header is 'SPaC' (Spotify Audio Codec?).
I hope someone has an idea.
Results 1 to 20 of 20
Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
There is no "wrong decryption". Either it works or it doesn't and the file changes into a different kind of garbage data. The only way this file could be decrypted incorrectly would be if the garbage data blob arranged its bytes in a way where it looked like a file by chance but the chances of this happening is zero.
Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
I'll send it when i get home, but I'm guessing you want the Key and IV too?
It's AES-128-CTR btwBypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
There's also OGG_VORBIS_320/160/96 which are used by the spotify client (160 by default). I'm not sure where AAC_24 is used though. The formats you're referring to are MP4_256/128(_DUAL).
AES-128-CTR
Key: a4c251a7b3bbab69b9f71b595cd56f8e
IV: 72e067fbddcbcf77ebe8bc643f630d93Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
All of the reverse engineering I've done so far can be found here: https://github.com/DevLARLEY/spotify-oggmp4-dl
try using the musicfab spotify downloader - https://www.dvdfab.cn/spotify-converter.htm?trackid=headmenu2
the have a free trial. -
This is what is returned by the Spotify API:
Code:{ "cdnurl": [ "https://audio4-ak-spotify-com.akamaized.net/audio/df6087632f48c2da7a049edf3bad9f5bf672781d?__token__=exp=1721240290~hmac=41d58b07ffe385e70919abe0ba28a69b5a6349766c1eefb546e9fc96081f6f87", "https://audio4-fa.scdn.co/audio/df6087632f48c2da7a049edf3bad9f5bf672781d?1721240290_9URiNZuQyx8F85BuWJc4LRoVkQ9wusKZDU9cYDsSKlc=" ], "fileid": "df6087632f48c2da7a049edf3bad9f5bf672781d", "result": "CDN", "ttl": 86400 }
This is what ffmpeg outputs after printing 50 errors and warnings:
Code:Input #0, aac, from '.\file.aac': Duration: 00:00:38.85, bitrate: 133 kb/s Stream #0:0: Audio: aac (LC), 3.0, fltp, 131 kb/s
I'm not asking about the file. I'm asking about the content on a web resource.
Ah, 3m 33s
If the content duration is '3m 33s', then why does FFmpeg show '00:00:38.85'? Something is wrong here.
For example.
I have two audio files in an 'AAC' container:
1. 1m 2s=996 KB.
2. 3m 49s=1,97 MB.
Can you save a session in 'Fiddler'? -
Hey sorry to bother, I got my .WVD some days ago but right now I'm struggling on how to forge the POST request for receiving the widevine license and then decrypt it to get the actual key to decrypt the spotify content, do you know how to do it exactly? I'm really losing my mind after that
Spotify Audio
By Ranma in forum Video Streaming DownloadingReplies: 34Last Post: 11th Sep 2025, 14:14 -
Downloading audio from Spotify
By TopSkillGamer in forum Video Streaming DownloadingReplies: 9Last Post: 29th Sep 2024, 09:28 -
spotify ripper
By lomero in forum AudioReplies: 6Last Post: 1st Aug 2023, 14:06 -
Problem forcing bitrate in StaxRip with HE-AAC format
By Occlumens in forum AudioReplies: 0Last Post: 12th Dec 2020, 22:36 -
how do i open a raw disc/ RAW format on a computer
By elm in forum DVB / IPTVReplies: 2Last Post: 9th Mar 2020, 18:33
