  1. Hi all,
    i downloaded and decrypted an AAC audio file. It looks like it should be playable (has file header, etc.) but neither ffmpeg nor VLC can play it.
    I wasn't able to find anything online.
    Help is greatly appreciated.
  2. DECEASED
    Jun 2009
    Heaven
    You'd better tell us from where you downloaded it and how you decrypted it.
    MediaInfo does not read it as an ADTS stream.
    "Programmers are human-shaped machines that transform alcohol into bugs."
  3. The file is from Spotify in the 'AAC_24' format. The decryption is VERY complicated and uses AES.
    If you really wanna know, look at this: https://github.com/librespot-org/librespot-java/discussions/421#discussioncomment-10037403
    Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
  4. DECEASED
    Jun 2009
    Heaven
    Hummm, it appears your problematic file is a RAW .aac file, which is ""unplayable"" by nature or/and by definition
    ffprobe does detect it as Advanced Audio Coding, but all the other info besides that is a mess
    I tried to wrap it in an MP4 container with ffmpeg, but the program outputs a zero-byte MP4 file.
    I also gave a try to GraphStudioNext, I managed to build various graphs, however none of the graphs generated an audible output.
