Results 1 to 16 of 16
  1. I will edit this post in case someone wants to download VdoCipher videos.
    You will need a real CDM and a custom script. There isn't any script available on the internet that works. You will just get error after error until your entire device is banned. You can test your script on the demo video (https://www.vdocipher.com/video-security/), but even if you can download that, it probably won't work on a paid video. Good luck.
  2. Banned
    Apr 2022
    Hong Kong
    I once wrote a script in March when it was still working. But I couldn't make it when I tried last month.
  3. Originally Posted by Ademir View Post
    Hey, I read a ton of threads, consulted every piece of information I found, but I'm stuck trying to decrypt VdoCipher keys.
    I already have a real CDM (It's unbelievable that it hasn't been revoked/banned yet).
    I already have the PSSH, mdb, headers, and a cURL with a blocked token.
    I tried three scripts that I found and tried to modify one of my own but still got different errors.
    angel - https://forum.videohelp.com/threads/407216-Decryption-The-Dungeon-of-Despair - Got 400 Bad Request (maybe a headers problem?).
    Diazole - https://github.com/Diazole/vdocipher-dl - Too old, the token feature doesn't work anymore.
    2nHxWW6GkN1l916N3ayz8HQoi - https://forum.videohelp.com/threads/413153-Decryption-fails-with-keys - Sounded promising, but I got pywidevine.exceptions.InvalidLicenseMessage: Could not parse license_message as a SignedMessage, Error parsing message.
    cdm-project: https://cdm-project.com/How-To/Obtaining-Keys-VDOCipher -> Tpd-key doenst have vdochiper option nor drmheaders.py
    I have no idea what to do anymore, if anyone want to help I can give access to the account.
    If you've real device cdm then give a try to Widevine L3 Guesser Extension once with enable licence blocking option
  4. Originally Posted by LittleSoldier View Post
    ... once with enable licence blocking option
    interesting feature. but where is this option ?
    no from guesser window
    [Attachment 80383 - Click to enlarge]
    also i can't find with right key on guesser icon
    [Attachment 80384 - Click to enlarge]
    Feb 2022
    Search the forum first!
    I write in general for the technicality of the issue; nothing more.
    If a site uses a one-time-only token then the browser uses it up. In normal use, that is.
    However, in the browser there is a menu item in the Web-Tools window, (shift+ctrl+c), under the network tab, that allows you to disable a particular request for a url. So if you allow the browser to load properly once, find the url for the license and then block it requesting, then Ctrl+R to reload the page, it will deliver you a license url with an unused token. Allhell3.py will work in these circumstances BUT ONLY with your own CDM. The one in the kit is an emulated CDM and will not work on heavily protected sites.
    Noob Starter Pack. Just download any Widevine media! Over 30,000 downloads for V6!.
  6. https://www.vdocipher.com/blog/2014/12/add-text-to-videos-with-watermark/
    Block:
    license.vdocipher.com/auth
    Firefox Browser doesn't show auth token.
    Feb 2022
    Try F5
  8. @whs912km Just right click on page you'll find enable licence blocking in context menu
    P.S. - Just make sure to select appropriate challenge scheme for your desired service
    @A_n_g_e_l_a Thanks for the Explanation
    I'll try with Allhell3.py as you've explained above once i dump physical cdm again
  9. LittleSoldier
    Your address 'license.vdocipher.com/auth' is not blocked.
    A_n_g_e_l_a
    OK. Using 'F5' it works. Thanks!
    But the token is only present in the first browser request 'license.vdocipher.com/auth'. It is not present in the second request 'license.vdocipher.com/auth'.
  10. Originally Posted by LZAA View Post
    LittleSoldier
    Got it.
    I thought you were unable to find that token in normal (unblocked licence request) scenario so posted that Screenshot
    Feb 2022
    LittleSoldier
    A_n_g_e_l_a
    I'm only passing on what I'm told:-
    "yea you just watch the waterfall and see which call requests the token, click the blocking button
    F5 the page and when the page loads again the video wont play, it will stop at the token request
    Just right click on it, copy it, use that to then get yur key (once the videos playing the token has been used) "
  12. Originally Posted by LZAA View Post
    LittleSoldier
    A_n_g_e_l_a
    Doenst matter, I just notice now that the first and second token is exactly the same (if the token is blocked). For some reason, firefox, firefox developer and Opera didnt show the "payload" of the blocked request. The only one that really shows the blocked token is Google chrome (last version, at least)
  13. I found out that the script vdocipher-dl actually gets the keys, but your CDM will be banned (it doesn't matter if you use it just one time, it will be banned no matter what). So, if you want to clone 10 videos, you will need 10 .wvd files. The other scripts (all of them) don't work at all. Good luck. I am out.
  14. Member aqzs's Avatar
    Mar 2024
    Paris
    CDM get banned only if you make bad requests.. You have to make a custom script for every websites to avoid getting banned. I managed to get keys from 3 services with a single .wvd that never got banned.
  15. Originally Posted by aqzs View Post
    And you have a custom script that actually work on vdocipher? Could you share with me? Cause I tried everything and nothing worked. Or i got the error "400 bad request" or just "code":2048,"message":"Authentication failed"
  16. Member aqzs's Avatar
    Mar 2024
    Paris
    Yes I got script working for vdocipher for exemple the video download challenge : https://files.videohelp.com/u/309512/Video%20Download%20Challenge.mkv (https://www.vdocipher.com/video-security/). I'll not share script here, you have to make those by yourself.
