Quite right Damon. The script is giving you exactly the correct response to the incorrect inputs you've given it.
Instead of throwing aspersions on a script you might profitably learn something by reading the Temple of Doom trilogy in the stickies.
Therein you may find https://cwip-shaka-proxy.appspot.com/no_auth is the license url and you'll need the curl of that!!
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
Results 151 to 167 of 167
Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
https://files.videohelp.com/u/301890/hellyes6.zip -
finally got some progress
[Attachment 82599 - Click to enlarge]
80205 Invalid device IDLast edited by damon; 2nd Oct 2024 at 09:49. Reason: my mistake
n_m3u8dl_re_command = (
f"N_m3u8DL-RE '{mpd_url}' {keys} "
f"--save-name 'E:/MakeMKV DVD Reads!/{self.video_name_entry.text()}' "
"-mt "
"-M:format=mkv:muxer=mkvmerge"
self.n_m3u8dl_re_output.setText(n_m3u8dl_re_comman d)
subprocess_command = [
'N_m3u8DL-RE', mpd_url
] + keys.split() + [
'--save-name', f'E:/MakeMKV DVD Reads!/{self.video_name_entry.text()}',
'-mt', '-M', 'format=mkv:muxer=mkvmerge'
self.subprocess_output.setText(str(subprocess_comm and))
Can't see what is wrong at 02:00. Sadly, must go to bed...Last edited by The_Mole_UK; 2nd Oct 2024 at 20:03.
Angela, I thank you so much for your work, you have made me happy on many platforms.
Unfortunately I can't make it work on the site which until yesterday was the simplest because it wasn't encrypted: Raiplay, Italy.
The mpd is already found only as a segment, but no big deal, I think your program will then transform it.
However, the license curl is a huge problem for me, first of all I would like to point out that it seems like Nagra and not Widevine.
In any case I tried to copy only the license, the header with the permissions, but it seems that I am writing or copying them incorrectly.
Am I asking too much if I ask you for help with this?
I'll leave you the link to the video:
https://www.raiplay.it/video/2024/09/I-leoni-di-Sicilia-S1E3-6dc4c0f4-5951-444c-bdf4-d...64a07606e.html
The pssh is:
AAAAeXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAFkIARIQb+ nlrgV+OPq9AzsWjl8gHxoFTmFncmEiPGRybV9yb290L0RSTU5h Z3JhX0Rpc25leV9tdWx0aWF1ZGlvLzI0MjEwODI1XywxMjAwLD E4MDAsMjQwMA==
The site is free, you will probably need a VPN to view.
Can you try?
I would like to understand with what syntax to write this curl license, provided that your program also works on this site, so I can make do by myself in the future.
In any case, THANK YOU in advance for your splendid work.Last edited by timetunnel; 3rd Oct 2024 at 02:17.
no need to bother with such a powerful Angela tool for such a simple site as Raiplay. use a simple cdrm-project online
Code:mpd: https://streamcdnm2-b70cb04c54ab478189e9d8ee45637b13.msvdn.net/ostr2/podcastcdn/drm_root/DRMNagra_Disney_multiaudio/24210825_,1200,1800,2400/manifest_mvnumber.mpd?hdnea=st=1727941092~exp=1727941242~acl=/*~hmac=f2c9375ee79d94f21aab1cfb5b16f56cda7a50114c5a8e18ba9d06892d95129a key: 6fe9e5ae057e38fabd033b168e5f201f:2fadf9729989ba0870fbf43f75016a04
more easy: use FoxRefire guesser (see sticky thread)
[Attachment 82618 - Click to enlarge] -
Thank you, but I have already discarded this solution. It requires Android installations which I don't want to do,
Installed as a simple Firefox browser extension it always returns an error.
[Attachment 82621 - Click to enlarge]
This is why I asked Angela if her program also supports encrypted Raiplay videos. -
what you mean? The browser extension does not require anything... only 2 cdm files
and I suggested the FoxRefire extension you are using the cdrm extension (also old, as you can see yours requires an update...)
FoxRefire extension work fine, look better my post#160... -
What are you talking about?
In the sticky ther is only the wdv guesser, and anyway to create or obtain the two cdm files I need an android device or equivalent,
So, all time lose for me, considering I understand NOTHING in these things,
If nobody's know if Angela software works on Raiplay, patience,
I'll try to be speeder in copying the header's authorizations. -
You can find cdm files in the sticky threads as well.
Edit: also if you want max quality on raiplay, you may wanna read this entire post before trying any existing tools
https://forum.videohelp.com/threads/416111-Downloading-from-RaiPlay-and-finding-the-keyLast edited by 2nHxWW6GkN1l916N3ayz8HQoi; 3rd Oct 2024 at 07:25.
[*drm mass downloader: widefrog*]~~~[*how to make your own mass downloader: guide*] -
here FoxRefire guesser https://github.com/FoxRefire/wvg/tree/next
(look from Code download zip)
here cdm ready to use https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21
BOTH from Sticky Threads -
[Attachment 82624 - Click to enlarge] All done (download zip extension file, download CDM, extract two of them in the same folder of manifest.json file,
installed extension in firefox, but SAME error again.
[Attachment 82625 - Click to enlarge]Last edited by timetunnel; 3rd Oct 2024 at 08:06.
"From Hell to Texas (1958)-And Disney's Vault Hoarders from Hell
By dped91 in forum DVD RippingReplies: 5Last Post: 9th Jul 2023, 13:48 -
Having a hell of a time transfering VHS
By Inniss in forum CapturingReplies: 2Last Post: 28th Mar 2023, 19:18 -
Panasonic HC-x1500 loose battery trick
By realspeed in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2022, 10:39 -
very Buggy if u loose password - back after 10 years
By melani in forum FeedbackReplies: 2Last Post: 25th Jan 2022, 21:56 -
USB-C Braided 10' Cord Loose And Doesn't Charge Tablet
By Tom Saurus in forum Off topicReplies: 5Last Post: 30th Dec 2020, 23:42
