Results 1 to 15 of 15
    Jun 2024
    Montreal, QC Canada
    Hi there.
    I am digging in several threads and I tried to download a video from RTL Plus.
    Here is the video URL:
    https://plus.rtl.de/video-tv/shows/hurricane-festival-993850/2024-6-1008128/episode-17...l-2024v-993875
    MDP:
    https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/993875/1-1-1-3-2.ism/v1.mpd
    PSSH (from the MDP):
    AAAAUHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADAIARIgZW M2ZTE4YWFiYzg2Y2E4ZDA2NTE5MWQ5MDYyYzM0MjQiBjk5Mzg3 NSoCU0Q=
    I was able to get these keys from https://keysdb.net/ with the license URL : https://cwip-shaka-proxy.appspot.com/no_auth
    39eda0e44957509ebb6408fe72250d46:a055180e63558a17a 703916e4b8a510e
    336847b2390a5e55ad8a7613c07f72ab:1950ab7ea0fae5d02 2a749f1bafa4893
    3514229ff9d55183be5a387229533074:a5c78c273308cba35 f1c95b2ad357be7
    925e0f42bcb9545a979758fa5f2112c7:14f739d323aa78933 6f7bd1c14e7c2f6
    ccce6b81fcd65fb6ba1c3d67cc3c02d3:55abe31715a55ff36 2cee03361fb68d9
    I downloaded the video with yt-dlp, but when I tried to decrypt the video with mp4decryptor, I always getting a video without image and sound.
    If anyone can help me figure out what I'm doing wrong, I'd appreciate it!
    Thanks,
    Steve
  2. Member aqzs's Avatar
    Mar 2024
    Paris
    Here is the right key :
    ec6e18aabc86ca8d065191d9062c3424:d724f1d94b192302c47646b1398d3a53
    Here is a download command :
    N_m3u8DL-RE "https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/993875/1-1-1-1-1.ism/v1.mpd" --save-name "Simple.Plan.live.auf.dem.Hurricane.Festival.2024v.E17" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv  --log-level OFF --key ec6e18aabc86ca8d065191d9062c3424:d724f1d94b192302c47646b1398d3a53
    Here is your file : https://www.swisstransfer.com/d/42365a27-5f91-4716-a98a-6cb3d06f56da
    Jun 2024
    Montreal, QC Canada
    Hi there!
    Thanks for the download link.
    Can you tell me what I did wrong?
    I think it is the license URL, but where did you find it?
    Thanks,
    Steve
  4. Member aqzs's Avatar
    Mar 2024
    Paris
    The license url is :
    https://widevine.tvnow.de/index/rtlplus
    and you also need to add to the header 'x-auth-token'. The keys you got are probably from cache.
  5. Originally Posted by stevetur29 View Post
    In your browsers developer console open the "Network" tab and filter for commonly used names in the license url: lic, drm, widevine, ...
    If you still aren't able to locate the license url, look for binary data in the preview or response of every single request made. If you've seen it once, you know exactly what it looks like.
    Copy that request as "Copy as cURL" and look for potentially important headers - token, unusual header names ... You'll probably not need every single header field for the license request, but it doesn't hurt to use them all.
  6. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    To add to this:
    A license url request will always be a POST request, which narrows it down a lot already.
    Often there is an initial OPTIONS request, immediately (or shortly) followed by a POST to that same url.
    If there is two POST requests, the payload of the first one is 8,4 a lot of the time
    Jun 2024
    Montreal, QC Canada
    Thanks guys,
    I was able to find the correct license URL, but unfortunately I was not able to get the key using http://108.181.133.95:8080/ for example.
    I always get an error.
    And yes, I set the HEADER X-Auth-Token with the value from my browser in the Dev Tools, but no success.
  8. Member aqzs's Avatar
    Mar 2024
    Paris
    Probably because of geo restriction. Use this header :
    HTML Code:
    headers = {
       'x-auth-token': ACCES_TOKEN,
       'x-forwarded-for': '47.65.137.89',
    Jun 2024
    Montreal, QC Canada
    Oh wow, that was just it!
    Thank you so much!
    Dec 2021
    england
    --key 29568ea210b75460474a7f09c6a4282d:cab6ac8914ad0acb67f985419942c054
    N_m3u8DL-RE -M format=mkv --check-segments-count false --key 29568ea210b75460474a7f09c6a4282d:cab6ac8914ad0acb67f985419942c054 "https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/993861/1-1-1-4-2.ism/v1.mpd" --save-name video
  11. Member aqzs's Avatar
    Mar 2024
    Paris
    The key @iamghost it the right one!
    N_m3u8DL-RE "https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/993861/1-1-1-1-1.ism/v1.mpd" --save-name "Frank.Carter.The.Rattlesnakes.live.auf.dem.Hurricane.Festival.2024.E03" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv  --log-level OFF --key 29568ea210b75460474a7f09c6a4282d:cab6ac8914ad0acb67f985419942c054
    Your video in 1080p : https://www.swisstransfer.com/d/8c3311c8-cfbd-4529-9e67-1851ac2a1704
  12. By exchanging "1-1-1-3-2.ism" with "1-1-1-1-1.ism" I can get better resolutions for series and shows. What do I have to do to get better resolutions for films?
    For example this free one:
    https://vodnowusoawsdash-a.akamaihd.net/p112/streaming/watch/907748/23-4000-1-1-1.ism/rtlplus.mpd
  13. I've found the solution in this post:
    https://forum.videohelp.com/threads/412143-Can-someone-help-me-to-download-a-video-fro...e3#post2750386
    Does anybody know if there's also a way to get better audio bitrates? Or even 5.1 sound?
  14. Originally Posted by kewifa7400 View Post
    10000 instead of 4000
    No 5.1 on RTL plus only stereo AAC.
