thanks!
I would've edited the [CODE][//CODE] later, but the message was pending, so I could not see/edit it
So you did not use this website to get the Key?
the 540p version looks really awful, RTL should've increased at least the bitrate
Results 61 to 90 of 166
Hi folks,
Im also needing help to download something from RTL+. This is my first time trying to grab something from RTL+ and for some reason i can't find the mpd in web inspector, maybe im just being blind haha.
If anyone could help me download the program that would be much appreciated.
The program im trying to download - https://plus.rtl.de/video-tv/shows/rock-am-ring-936712/rock-am-ring-2024-993793/episod...ng-2024-993817 -
mpd :
key :Code:https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/993817/1-1-1-3-2.ism/v1.mpd
command used :Code:335fc54d94ee251e37b1316eb57d4eff:9799dd3586fb9252049fad1c62bf76d2
https://www.swisstransfer.com/d/4c6a60e8-daf3-439a-abc9-b7109abd7889Code:N_m3u8DL-RE "https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/993817/1-1-1-3-2.ism/v1.mpd" --key 335fc54d94ee251e37b1316eb57d4eff:9799dd3586fb9252049fad1c62bf76d2 -M mkv --save-name "Rock am Ring 2024, Folge 31"
Another newbie here and almost the same problem / request. I'm trying to grab https://plus.rtl.de/video-tv/shows/rock-am-ring-936712/rock-am-ring-2024-993793/episod...ng-2024-993815
Can't find mpd, only m4s. Much appreciated, if I can get some help. -
Here is the mpd :
Here is the key :Code:https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/993815/1-1-1-3-2.ism/v1.mpd
Command to download :Code:57331359b5eb7b91b932a1ac2589ae7a:7a8948c798f3d38486814458f1796c9b
You might add this to download command, I was getting 404 for the last part sometimes..Code:N_m3u8DL-RE --key 57331359b5eb7b91b932a1ac2589ae7a:7a8948c798f3d38486814458f1796c9b "https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/993815/1-1-1-3-2.ism/v1.mpd" -M mkv --save-name "Royal Republic live bei Rock am Ring 2024 - Folge 16"
Download link in 540p : https://www.swisstransfer.com/d/282f0796-9757-4715-aa11-10c1c3762651Code:--check-segments-count False
Download link in 1080p : https://www.swisstransfer.com/d/1d5a3664-ccc2-44b3-a6fb-d389e40ab421Last edited by aqzs; 12th Jun 2024 at 16:46.
Hey ! What do you think about this crispy 7.2Mb/s 1080p
: https://www.swisstransfer.com/d/198cc03c-dc10-4d08-b92b-a9b629c6ee03
I saw that some of you were interested in this Rock am Ring 2024 concert. I downloaded every shows available (in 1080p) : https://gofile.io/d/nKnF8z (28 files, 79.5 GB)
How did you obtain the content links for 1080p? The mpd's contain only up to 540p, afaict. Guessing? Manipulating the mpd? Paid subscription? I'm curious ...
I don't have a paid subscription, I don't even have an account. Manipulating the mpd gives me 1080p. By the way I'm able to get mpd for paid content but I can't get the key, the license request return :
If some of you have paid subscription and could just share a license requestHTML Code:{"error":"free.availability.missing","errorCode":21000,"origin":"entitlement"}
This trick doesn't work sadly for mpds of this format:
Either you got lucky or it only works for ism that have 1 digit groups. In the previous case it finds a mpd with audio only.Code:https://vodnowusoawsdash-a.akamaihd.net/p112/streaming/watch/861475/25-4000-1-1-1.ism/rtlplus.mpd
Edit: Apparently if you replace 4000 with 8000 you can get 1080p. Kudos to @Lostion for explaining the trick. He also claims that if you add 10000 instead for all mpd URLs such as the one I posted you can get 1080p. It's worth checking.Last edited by 2nHxWW6GkN1l916N3ayz8HQoi; 17th Jul 2024 at 01:52. Reason: Was given solution
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
I am trying to download the following video in 1080p:
https://plus.rtl.de/video-tv/shows/schlefaz-die-schlechtesten-filme-aller-zeiten-98885...obicide-988861
The MPD file is the following:
https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/988861/1-1-1-3-2.ism/v1.mpd
That MPD provides only lower resolutions, but I have found that there is another MPD at the following URL:
https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/988861/1-1-1-1-1.ism/v1.mpd
That MPD provides two 1080p resolutions which differ in bit rate. Yeah!
But stop:fails to download the variant with the higher bit rate, because there is something wrong with the last segment. This is reproducible: I have tried a dozen of times and each time it downloaded all of the segments except the last one.Code:yt-dlp
It's the same when using. That is,Code:N_m3u8DL-RE
also downloads all segments but the last if I select the 1080p resolution variant with the highest bit rate. Therefore I believe that the error is on RTL's side. Can somebody confirm that?Code:N_m3u8DL-RE
Side note:
I am aware the the stream is encrypted. However, currently I don't care about that. I just would like to know why downloading that last segment is not possible.
Thank you very much in advance! -
N_m3u8DL-RE "https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/988861/1-1-1-1-2.ism/v1.mpd" --key 585787b6c95ca81ffafb1907f7421e4d:e5bcd701227725e4462ad503531ad0cc --save-dir "media\plus_rtl_de" --save-name "SchleFaZ_-_Die_schlechtesten_Filme_aller_Zeiten_SchleFaZ_Aerobicide" -M format=mkv
Just ignore the warning regarding the last segment - sometimes the real number of segments doesn't match the segments from the manifest. For N_m3u8DL-RE you can add "--check-segments-count False"
choose:
https://vodnowusoawsdash-a.akamaihd.net/p112/streaming/watch/988861/1-10000-1-1-1.ism/rtlplus.mpd
its the highest bitrate CBR version, the v1 mpd is only the vbr version with a terrible bitrate (even for vbr its way to low)
Still trying to find a way to force the API for the CBR version at the moment RTL choose the VBR and CBR versions completely random and you must find out the CBR path by just pure testing (which is ridiclious) already tested the android/tizen API but RTL just decides randomly what playlist will be played via API.
Maybe somebody found a method to get the higher CBR version? -
Thank you very much, Obo. That's a little bit embarrassing because that command line option has been mentioned a few posts above, so I really should have tried it myself. But I thought that missing segments would render the file useless and that I shouldn't ignore them for that reason. Thanks again for explaining that this is normal.
[ As a side note, I regularly downloaded the Schlefaz episodes from Tele5 as long as they were located there, and I never encountered missing segments there. This made me worry even more. ] -
Thank you very much! You are completely right. The video quality of the version you have linked is really better than that of the other versions.
I would also be highly interested into a method that enables us to find the best quality version.
Apart from that, I have two further questions:
1. Would it be appropriate to come back here whenever a new Schlefaz episode is online in order to ask for the MPD that provides the best quality?
2. Is it possible to determine before downloading whether the streams in a MPD are VBR or CBR? I have just had a look into the output of yt-dlp -F as well as of N_m3u8DL-RE, but that output doesn't seem to provide this information. Of course, once a stream is downloaded, the type (VBR vs. CBR) can easily determined by several free tools, but is this easily possible also before download? -
v1.mpd is always the lower vbr version. rtlplus.mpd is always the higher cbr version. The main problem is sometimes the subtitles are in different spots.
For example:
1-10000-1-1-1.ism there can be subs
40-10000-1-1-1.ism there can be subs (and in 1-10000-1-1 not) sometimes you can only choose between 1-10000-1-1 and 2-10000-1-1 the rest gives you not found errors
i didn't find an api method yet to get it directly its just pure testing. I still don't know why RTL is doing that it makes no sense sometimes they even switch between episodes of a series ("Gute Zeiten, schlechte Zeiten" as an example).
Sometimes they even replace the lower vbr version with the cbr version after some days. Also there is not always a vbr version sometimes only the cbr version is available which makes it even more different
Edit: @pYPsfVARqM3nH7hD send me a link via PM when the new episode is out and i'll send you the correct .mpd
Thank you very much again! That explanation has helped me a lot. In all cases I have tried, I was able to get the rtlplus.mpd. The remaining question then is if there are other rtlplus.mpd files that provide even better quality.
For example, for the first Schlefaz episode of the current season, I have found an MPD that provides 1080p with a bit rate of 6640 Kbps. Now I am asking myself if there is an even better one; after all, the best version for the second episode was at 7800 Kbps.
I'll take your offer and send you a PM with the link to the first episode and the MPD I have found
EDIT:
Subtitles are not that interesting for me. I believe that the Schlefaz episodes don't contain subtitles anyway.Last edited by pYPsfVARqM3nH7hD; 12th Sep 2024 at 15:34.
Now I've got another problem. I am trying to download this video:
https://plus.rtl.de/video-tv/shows/schlefaz-die-schlechtesten-filme-aller-zeiten-98885...faz-ape-988862
I am completely new in this field and was glad that I found a ready-made solution which Angela's (at least, I believe) hellyes3 and hellyes3gui. I have partial success:
When loading the video, I can easily find the MPD file and the license request. If I paste them into the respective fields of hellyes3gui, it gives me the correct keys, and I can download and decrypt the video. So far, so good.
But the MPD file offers only versions with bad quality and low resolutions. Fortunately, a helpful soul told me the location of another MPD file for this video that contains 1080p in good quality.
Now, when I paste the URL of that MPD file into hellyes3gui (leaving the license request as-is) and hit the "Get Keys" button, I get a HTTP 403 status. What could be the reason for this?
A few things to note:
- I could download the first two episodes of the current Schlefaz season using the same method (i.e., paste the license request from the developer tools into hellyes3gui, paste the manipulated MPD URL for the best resolution into hellyes3gui, and hit "Get Keys"). It's just the third episodes where this method fails. Did RTL change something during the last days?
- I thought that perhaps the wvd device may have been blocked, so I downloaded a ZIP-File with ready-made wvd devices from another thread here, picked on of them and changed one line in the code of hellyes3gui to make it use that other wvd file. This did not change anything, I am still getting a 403 when hitting "Get Keys".
- I have tried hellyes3 instead of hellyes3gui with the same result.
- If I then use the MPD link from the developer tools again, everything works like a charm. This is reliably reproducible. With the license request and the MPD from the developer tools, everything works. With the license request from the developer tools and the other (better) MPD, I get a 403, and don't get any keys.
Any ideas?
The person who helped me told me that RTL has not changed anything. This makes the situation a mystery for me. There must be a reason why the good MPD together with the original license request leads to a 403, but the original (bad) MPD with the original license request works. -
I got 1080p at 4Mb/sCode:
Video url: https://plus.rtl.de/video-tv/shows/schlefaz-die-schlechtesten-filme-aller-zeiten-988858/staffel-1-988859/episode-3-schlefaz-ape-988862 ---------------------------------------------------------------------------------------------------- mpd_url: https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/988862/1-1-1-1-1.ism/v1.mpd pssh: AAAAUHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADAIARIgMjUxMDNmNzk1Y2RjOGNjZTk5ZTBhNjE5NDQ0ZjgyN2EiBjk4ODg2MioCU0Q= keys: ['25103f795cdc8cce99e0a619444f827a:e30a1f5edb49ee6c5cbe95065e36d382'] N_m3u8DL-RE "https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/988862/1-1-1-1-1.ism/v1.mpd" --save-name "SchleFaZ.A.P.E.E03" --select-video best --select-audio all --select-subtitle all -mt -M format=mkv --log-level OFF --key 25103f795cdc8cce99e0a619444f827a:e30a1f5edb49ee6c5cbe95065e36d382
https://gofile.io/d/Bi6xatLast edited by aqzs; 16th Sep 2024 at 17:34.
CBR Playlist:
Edit: Interesting they changed the keys for VBR and CBR versions. Strange but the key is the right one:Code:--------------------------------------------------------------------------------- URL: https://plus.rtl.de/video-tv/shows/schlefaz-die-schlechtesten-filme-aller-zeiten-988858/staffel-1-988859/episode-3-schlefaz-ape-988862 --------------------------------------------------------------------------------- MPD URL: https://vodnowusoawsdash-a.akamaihd.net/p112/streaming/watch/988862/1-10000-1-1-1.ism/rtlplus.mpd --------------------------------------------------------------------------------- PSSH: AAAAUHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADAIARIgNTAxZTIzZDc0ZGE2Njc2MzY0NjRiZmI4YmYzYjRmNjIiBjk4ODg2MioCU0Q= --------------------------------------------------------------------------------- License URL: https://widevine.tvnow.de/index/rtlplus --------------------------------------------------------------------------------- Decryption Key: 501e23d74da667636464bfb8bf3b4f62:683784faf29f18adb6886ed63e634cd8 ---------------------------------------------------------------------------------
KID: 501e23d74da667636464bfb8bf3b4f62 checks out withe the Decryption key.
Edit: https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/988862/1-1-1-1-2.ism/v1.mpd is for the browser vbr playlist also slightly different for LG/TIZEN/ANDROID etc. Not sure why its 1-1-1-1-1 above but doesnt matter the only difference is the segment size rest is identical. The CBR one is the way better one.
I still have no solution to get the CBR playlist via API its a hit and miss at the moment.
Edit2: Send @pYPsfVARqM3nH7hD a PM he had the wrong PSSH. Thats why the keys are different:
VBR = AAAAUHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADAIARIgMj UxMDNmNzk1Y2RjOGNjZTk5ZTBhNjE5NDQ0ZjgyN2EiBjk4ODg2 MioCU0Q=
CBR = AAAAUHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADAIARIgNT AxZTIzZDc0ZGE2Njc2MzY0NjRiZmI4YmYzYjRmNjIiBjk4ODg2 MioCU0Q=
must be a new change because atleast last week they used the same keys for VBR and CBR.
Back to finding the CBR API
already found all the major TV API but no luck if the VBR is on plus.rtl.de it is also on the TV APIs.
Edit:
https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/988862/1-1-1-1-1.ism/v1.mpd is 2 seconds shorter than https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/988862/1-1-1-1-2.ism/v1.mpd the CBR version is also 2 seconds shorter interesting!
Edit2: Seems like its just a counting mistake.Last edited by Lostion; 16th Sep 2024 at 21:01.
Hi - just a quick kind request for a friend -
can someone help me to get this one:
https://plus.rtl.de/video-tv/shows/unsere-erste-gemeinsame-wohnung-140972/staffel-8-20...-120912-200964
kr
Grorkul
Downloading videos from RTL
By Data2006 in forum Video Streaming DownloadingReplies: 17Last Post: 30th Jul 2024, 01:32 -
DOWNLOAD protected DRM video separated video and audio from (learnyst)
By yassin in forum Video Streaming DownloadingReplies: 4Last Post: 8th Jan 2024, 05:36 -
First try with RTL+/TVNow
By resonator79 in forum Video Streaming DownloadingReplies: 3Last Post: 23rd Feb 2023, 07:41 -
How can I download videos from play.rtl.hr?
By Nintendo Custom in forum Video Streaming DownloadingReplies: 23Last Post: 24th May 2022, 13:51 -
Download HLS video using FFMPEG with separate video and audio URLs?
By oschrndz in forum Video Streaming DownloadingReplies: 2Last Post: 15th Dec 2020, 14:53
