Results 1 to 25 of 25
  1. In the past, I have successfully decrypted videos with pssh from mpd file and the license url with tools like WKS-KEYS.
    However, this time I'm trying to decrypt a video I got from an app running in android emulator.
    I intercept the traffic with fiddler but there's no mpd file. It only got several m3u8 files.
    Written below is the response of a m3u8 file with the most information.
    HTTP/1.1 200 OK
    Content-Type: application/vnd.apple.mpegurl
    Content-Length: 552
    Connection: keep-alive
    x-amz-server-side-encryption: AES256
    Accept-Ranges: bytes
    Server: AmazonS3
    ETag: "xxxxxx"
    X-Cache: Hit from cloudfront
    Via: 1.1 xxxxx.cloudfront.net (CloudFront)
    X-Amz-Cf-Pop: xxxxx
    X-Amz-Cf-Id: C_xxxxxxxxxxxxxxxx==
    #EXTM3U
    #EXT-X-VERSION:5
    #EXT-X-TARGETDURATION:7
    #EXT-X-MEDIA-SEQUENCE:1
    #EXT-X-PLAYLIST-TYPE:VOD
    #EXT-X-KEY:METHOD=SAMPLE-AES,URI="skd://xxxxxxx",KEYFORMAT="com.apple.streamingkeydelivery",KEYFORMATVERSIONS="1"
    #EXTINF:6,
    movie_hls_00001.ts
    #EXTINF:6,
    movie_hls_00002.ts
    #EXTINF:6,
    movie_hls_00003.ts
    #EXTINF:6,
    movie_hls_00004.ts
    #EXTINF:6,
    movie_hls_00005.ts
    #EXTINF:6,
    movie_hls_00006.ts
    #EXTINF:6,
    movie_hls_00007.ts
    #EXTINF:3,
    movie_hls_00008.ts
    #EXT-X-ENDLIST
    License URL:
    https://license.theoplayer.com/
    I already downloaded the encrypted video but can't seem to find the pssh in order to get the key. The "X-Amz-Cf-Id" looks like a pssh but when I used it in WKS-KEYS, it returns an error:
    binascii.Error: Invalid base64-encoded string: number of data characters (49) cannot be 1 more than a multiple of 4
    Would be really grateful if someone could point me in the right direction.
  2. Member aqzs's Avatar
    Mar 2024
    Paris
    Could you share more informations ? The pssh ? Or a link ?
  3. Originally Posted by aqzs View Post
    The closest thing I found that looks like a PSSH is the "X-Amz-Cf-Id" part in the response. And it changes everytime I request it.
    X-Amz-Cf-Id: PsueBgTU8gPj2QQGdZxkdiUqetUA1gd9uKvbzgBznu3I4FhpjbRaWg==
    Unfortunately, I can't post the URL here as it's paid content. Can I send it to you through DM?
  4. There are a lot of useful info in this thread: https://forum.videohelp.com/threads/413718-My-journey-with-AES-128-encrypted-HLS and this one as well: https://forum.videohelp.com/threads/414047-Help-with-downloading-encrypted-HLS-video-f...ffline-viewing
    Basically you need to feed the .m3u8 to N_m3u8DL-RE, and after getting the key provide it with the flag --custom-hls-key.
  5. Originally Posted by white_snake View Post
    Thank you for your reply.
    My video is encrypted with SAMPLE-AES which I believe is a bit different from AES-128. Nevetheless, I tried converting the X-Amz-Cf-Id I got to hex and putting it as the key in N_m3u8DL-RE, the resulted video is still encrypted.
    Judging from this, X-Amz-Cf-Id is probably not the key. And since there's no mpd file, I couldn't find the PSSH either.
    There're also several other m3u8 requests caught by fiddler. I don't know if they'll help but I can send them to you through DM.
    If there's someone with experience in decrypting video from an app in emulator, it would be incredibly helpful to me....
  6. SAMPLE-AES and AES-128 is the same
    I tried converting the X-Amz-Cf-Id I got to hex and putting it as the key in N_m3u8DL-RE, the resulted video is still encrypted. Judging from this, X-Amz-Cf-Id is probably not the key
    sure this isn't the key
    yes, with AES no mpd (and so no pssh...) but only m3u8
    also your lic url is useless
    your key is here
    ... but how to rip and decrypt it's another problem
    have you tried Stream Recorder extension? maybe it work for you. slowly but work. or try Tubedigger in Rec Mode
  7. Originally Posted by lomero View Post
    your key is here
    Thank you for the clarification!
    I'll try those extensions and see if they can work on the app.
  8. Stream Recorder is an extension (and this is free from chrome store)
    Tubedigger is windows software (not free, but you can test it in trial mode, only 50% of full video is allowed)
  9. kid in skd url?
  10. Originally Posted by crippled View Post
    kid in skd url?
    FYI, the skd looks like this:
    skd://56723cf3-b237-49aa-9a28-db0389923388
    Does this look like a kid?
    I've heard of kid before but forgot what's its usage. Is it the direct key or do I need to do some steps with the kid to get the key?
  11. Originally Posted by Tsubasa View Post
    You might want to try to use something like this in your N_m3u8DL-RE command:
    --custom-hls-key 56723cf3b23749aa9a28db0389923388
    but that's hardly going to work, there's probably some js debugging here to do.
  12. Originally Posted by Tsubasa View Post
    kid in skd url?
    yes, could also be the key but I doubt it.
    Got the captured data for https://license.theoplayer.com/ ?
  13. This is Apple’s DRM FairPlay, which hasn’t been publicly cracked yet.
    discord=notaghost9997
  14. Originally Posted by crippled View Post
    I sent it to you through PM. Thanks for the help.
  15. Originally Posted by white_snake View Post
    Just try it and yeah it didn't work.
  16. Originally Posted by notaghost View Post
    Sad to hear this, I guess it can't be helped then...
  17. ye, but sometime no need key to decrypt
    i know one site (aes encrypted) that download work fine just with right link and token too, all linked. also i know the hex key for that site, but no need this key for download.
    but it's also true that each site is a special case, so i can't generalize
    however with my post#8 you can choose 2 different ways to rip your video (on Rec Mode) maybe it slowly but almost certainly work. try it
  18. Originally Posted by lomero View Post
    Thanks for helping me but after checking those two softwares you mentioned, they seem to only work in browser. In my case, the video is playing in an android app so they probably won't work....
  19. If the video can be played on Android, please provide the app link, as the sample AES is for Apple's DRM for iOS.
  20. Originally Posted by notaghost View Post
    I sent you a PM with the detailed info of the app. Could you please check it?
    Thank you for the help.
  21. With the help from notaghost, I managed to decrypt the video/audio. Apparently, it's not SAMPLE-AES but widevine.
    Using an android emulator plus fiddler as a proxy to capture data probably didn't work as it's not showing widevine at all.
    Thanks for all of the help again.
  22. How to solve this?
  23. Originally Posted by notaghost View Post
    Hi, I am in a similar situation. It is an android app and getting sample-aes. How did you solve this problem? Can you help me? Please.
  24. Sample AES might have Widevine data in it share app name please
  25. Originally Posted by notaghost View Post
    I have an app but I can’t get the key, can you help me? The app is kanta。
