Let's say I have a short video with YUV 4:4:4 and 10bit depth, and I convert it to a FFV1 with YUV 4:2:0 and 8bit depth. Is the FFV1 lossless? Will the colors be the same?
If so, how do I convert videos while changing the chroma subsampling and bit depth without losing quality and get the right colors?
FFV1 is lossless but conversion from YUV 4:4:4 10b to YUV 4:2:0 8b is lossy - colors can be the same or similar (within 8 bit accuracy) - depends on your YUV 4:4:4 10b source - if your source is 8 bit converted to 10 bit and after back to 8 bit then there is chance that in overall conversion will be lossless.
Say you have a 1920x1080 YUV 4:4:4 frame. All three channels have 1920x1080 resolution. But when you convert that to YUV 4:2:0 the chroma channels (U and V) are reduced to 960x540. This is a lossy conversion.
https://en.wikipedia.org/wiki/Chroma_subsampling
Here's a sample where 4:4:4 was converted to 4:2:0:
https://forum.videohelp.com/threads/319360-DVD-LAB-PRO-color-map#post1977264
10 bit video has a range of 1024 different values (0 to 1023) for each component (Y, U, and V). Converting that to 8 bits (typically done by dividing the 10 bit values by 4) reduces the range to only 256 different values (0 to 255). That is a lossy conversion.Last edited by jagabo; 27th Apr 2024 at 12:44.
YUV and YUVJ
By Sound Master in forum Newbie / General discussionsReplies: 3Last Post: 18th Apr 2024, 21:21 -
10-Bit YUV to RGB
By chris319 in forum ProgrammingReplies: 5Last Post: 25th Aug 2023, 04:28 -
How do you change the YUV in FFMPEG?
By Guernsey in forum Newbie / General discussionsReplies: 4Last Post: 30th Jun 2021, 22:03 -
Why does YUV not use full range?
By Videogamer555 in forum DVB / IPTVReplies: 4Last Post: 27th Jan 2021, 04:00 -
Converting Blu-Ray YUV to RGB and back to YUV?
By killerteengohan in forum RestorationReplies: 17Last Post: 17th Mar 2020, 21:42
