Results 1,321 to 1,350 of 1860
Hi all.
Just a query on commands, is there a way you can set a -vb limit at all? I can't see anything in the help so I fear not. For example, I don't always need the top 1080p track, out of the multiple available. I tend to have to manually check the --list and then note the -vb for the second 1080p track. The -vb varies, usually floats around 3000 kb/s in this instance.
I'm just wondering if I'm missing a trick or command such as -vbmax (I made that up) or something so I can just set that and rattle through without having to get the exact -vb for each episode track?
Thanks -
I'm getting the 3221225477 error as well when downloading from ALL4:
Code:devine -d dl all4 https://www.channel4.com/programmes/the-great-british-bake-off-festive-specials/on-demand/74275-002
When I run it I see a folder appear C:\Bin\Stream\devine\temp\Video_3f73f144.mp4_segme nts which contains 0.mp4 - the folder then vanishes and an Audio folder appears in its place. That then vanishes and Subtitle_b8243f.vtt is created and is left in the tmp folder.Code:/ __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.3 Copyright © 2019-2025 rlaphoenix https://github.com/devine-dl/devine Service Config loaded Loaded Cdm Widevine CDM: 4464 (L3) Loaded 1 Vaults ────────────────────────────── Service: ALL4 ─────────────────────────────── Starting new HTTPS connection (1): ipinfo.io:443 https://ipinfo.io:443 "GET /json HTTP/11" 200 222 Service is not Geoblocked in your region Starting new HTTPS connection (1): api.channel4.com:443 https://api.channel4.com:443 "POST /online/v2/auth/token HTTP/11" 200 4483 + Acquired tokens... Authenticated with Service https://api.channel4.com:443 "GET /online/v1/views/content-hubs/the-great-british-bake-off-festive-speci als.json?client=android-mod&deviceGroup=mobile&include=extended-restar t HTTP/11" 200 8718 ─────────── Series: The Great British Bake Off: Festive Specials ─────────── 1 Season, 1 Episode ─ The Great British Bake Off: Festive Specials S08E02 The Great New Year' ─ https://api.channel4.com:443 "GET /online/v1/vod/stream/74275-002?client=android-mod HTTP/11" 200 1391 Starting new HTTPS connection (1): www.channel4.com:443 https://www.channel4.com:443 "GET /vod/stream/74275-002 HTTP/11" 200 2034 Starting new HTTP connection (1): ak.dash01.stream.c4assets.com:80 http://ak.dash01.stream.c4assets.com:80 "GET /wvmod-stream/CH4_33_05_42_74275_002_1_173504029723069.mpd?c3.ri=13499 110668568164375 HTTP/11" 200 10048 Starting new HTTPS connection (1): cf.jos.c4assets.com:443 https://cf.jos.c4assets.com:443 "GET /CH4_08_02_900_74275_002_1_173504028398771/CH4_08_02_900_74275_002_1_1 73504028398771_J01.ism/stream.mpd?c3.ri=13500236514541029823&mpd_segme nt_template=time&filter=%28type%3D%3D%22video%22%26%26%28%28DisplayHei ght%3E%3D288%29%26%26%28systemBitrate%3C4800000%29%29%29%7C%7Ctype%21% 3D%22video%22&ts=1738156691&e=600&st=aIe2McSYMY2nYQgM0o60v6I4sPKjEgyg3 tz88MqQ8Nw HTTP/11" 200 23659 http://ak.dash01.stream.c4assets.com:80 "GET /wvmod-stream/CH4_33_05_42_74275_002_1_173504029723069.mpd?c3.ri=13499 110668568164375 HTTP/11" 200 10048 http://ak.dash01.stream.c4assets.com:80 "GET /wvmod-stream/CH4_33_05_42_74275_002_1_173504029723069_5000.mp4 HTTP/11" 206 927 Starting new HTTP connection (1): ak.dash01.stream.c4assets.com:80 http://ak.dash01.stream.c4assets.com:80 "GET /wvmod-stream/CH4_33_05_42_74275_002_1_173504029723069_5000.mp4 HTTP/11" 206 2168520401 http://ak.dash01.stream.c4assets.com:80 "GET /wvmod-stream/CH4_33_05_42_74275_002_1_173504029723069_128_prog.mp4 HTTP/11" 206 855 Starting new HTTP connection (1): ak.dash01.stream.c4assets.com:80 http://ak.dash01.stream.c4assets.com:80 "GET /wvmod-stream/CH4_33_05_42_74275_002_1_173504029723069_128_prog.mp4 HTTP/11" 206 58012147 Starting new HTTP connection (1): 127.0.0.1:63816 http://127.0.0.1:63816 "POST /jsonrpc HTTP/11" 200 148 http://127.0.0.1:63816 "POST /jsonrpc HTTP/11" 200 394 http://127.0.0.1:63816 "POST /jsonrpc HTTP/11" 200 87 Resetting dropped connection: 127.0.0.1 1 Video └── [H.264, SDR] | en | 1920x1080 @ 5033 kb/s, 25.000 FPS ⠸ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ --:-- Decrypting 1 Audio └── [AAC] | en | 2.0 | 134 kb/s ⠸ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ --:-- Decrypting 1 Subtitle └── [VTT] | en ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 00:25 Downloaded 6 Chapters ├── 00:00:00.000 | Chapter 01 ├── 00:17:14.920 | Chapter 02 ├── 00:35:06.760 | Chapter 03 ├── 00:48:55.400 | Chapter 04 ├── 00:54:37.280 | Chapter 05 └── 00:57:35.640 | Credits Widevine(AAAASnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAACoIARIQHEWKPgudTIdEU 4NwQClnwBoIcmJtY2g0dHYiCDExODE5NTQyMgA=) └── 1c458a3e0b9d4c8744538370402967c0:d7e7435c2364c61e681e9444de7a79e4* from My Local Vault SQLite ╭───────────────────── Traceback (most recent call last) ──────────────────────╮ │ C:\Python\Lib\site-packages\devine\commands\dl.py:540 in result │ │ │ │ 537 │ │ │ │ │ │ │ ) │ │ 538 │ │ │ │ │ │ │ for i, track in enumerate(title.tracks) │ │ 539 │ │ │ │ │ │ )): │ │ ❱ 540 │ │ │ │ │ │ │ download.result() │ │ 541 │ │ │ except KeyboardInterrupt: │ │ 542 │ │ │ │ console.print(Padding( │ │ 543 │ │ │ │ │ ":x: Download Cancelled...", │ │ │ │ C:\Python\Lib\concurrent\futures\_base.py:449 in result │ │ │ │ 446 │ │ │ │ if self._state in [CANCELLED, CANCELLED_AND_NOTIFIED]: │ │ 447 │ │ │ │ │ raise CancelledError() │ │ 448 │ │ │ │ elif self._state == FINISHED: │ │ ❱ 449 │ │ │ │ │ return self.__get_result() │ │ 450 │ │ │ │ │ │ 451 │ │ │ │ self._condition.wait(timeout) │ │ 452 │ │ │ │ C:\Python\Lib\concurrent\futures\_base.py:401 in __get_result │ │ │ │ 398 │ def __get_result(self): │ │ 399 │ │ if self._exception: │ │ 400 │ │ │ try: │ │ ❱ 401 │ │ │ │ raise self._exception │ │ 402 │ │ │ finally: │ │ 403 │ │ │ │ # Break a reference cycle with the exception in self._ │ │ 404 │ │ │ │ self = None │ │ │ │ C:\Python\Lib\concurrent\futures\thread.py:59 in run │ │ │ │ 56 │ │ │ return │ │ 57 │ │ │ │ 58 │ │ try: │ │ ❱ 59 │ │ │ result = self.fn(*self.args, **self.kwargs) │ │ 60 │ │ except BaseException as exc: │ │ 61 │ │ │ self.future.set_exception(exc) │ │ 62 │ │ │ # Break a reference cycle with the exception 'exc' │ │ │ │ C:\Python\Lib\site-packages\devine\core\tracks\track.py:200 in download │ │ │ │ 197 │ │ │ │ │ license_widevine=prepare_drm │ │ 198 │ │ │ │ ) │ │ 199 │ │ │ elif self.descriptor == self.Descriptor.DASH: │ │ ❱ 200 │ │ │ │ DASH.download_track( │ │ 201 │ │ │ │ │ track=self, │ │ 202 │ │ │ │ │ save_path=save_path, │ │ 203 │ │ │ │ │ save_dir=save_dir, │ │ │ │ C:\Python\Lib\site-packages\devine\core\manifests\dash.py:533 in │ │ download_track │ │ │ │ 530 │ │ │ │ 531 │ │ if drm: │ │ 532 │ │ │ progress(downloaded="Decrypting", completed=0, total=100) │ │ ❱ 533 │ │ │ drm.decrypt(save_path) │ │ 534 │ │ │ track.drm = None │ │ 535 │ │ │ events.emit( │ │ 536 │ │ │ │ events.Types.TRACK_DECRYPTED, │ │ │ │ C:\Python\Lib\site-packages\devine\core\drm\widevine.py:291 in decrypt │ │ │ │ 288 │ │ │ p.wait() │ │ 289 │ │ │ │ │ 290 │ │ │ if p.returncode != 0 or had_error: │ │ ❱ 291 │ │ │ │ raise subprocess.CalledProcessError(p.returncode, argu │ │ 292 │ │ │ │ │ 293 │ │ │ path.unlink() │ │ 294 │ │ │ if not stream_skipped: │ ╰──────────────────────────────────────────────────────────────────────────────╯ CalledProcessError: Command '['input=C:\\Bin\\Stream\\devine\\temp\\Video_3f73f144.mp4,stream=0,output=C:\\B in\\Stream\\devine\\temp\\Video_3f73f144_decrypted.mp4,output_format=MP4', '--enable_raw_key_decryption', '--keys', 'label=0:key_id=1c458a3e0b9d4c8744538370402967c0:key=d7e7435c2364c61e681e9444de7 a79e4,label=1:key_id=00000000000000000000000000000000:key=d7e7435c2364c61e681e94 44de7a79e4', '--temp_dir', WindowsPath('C:/Bin/Stream/devine/temp')]' returned non-zero exit status 3221225477. ❌ Download Failed... An unexpected error occurred in one of the download workers. Binary call failed, Process exit code: 3221225477 See the error trace above for more information.
I'm a bit confused why the files don't hang around to be muxed, and what's causing them to be deleted.
iPlayer downloads work fine -
@dodgydodgy: What version of Shaka Packager are you using? stabbedbybrick recommends v2.6.1.
anyone able to try https://www.channel5.com/dexter/season-1/dexter
keep getting
('Connection broken: IncompleteRead(2040233185 bytes read,
242165062 more expected)', IncompleteRead(2040233185 bytes read,
242165062 more expected))
other stuff from Channel 5 works fine
good old freevine gets video, audio & subs but fails on muxing -
The subtitles are missing\empty. Just download video and audio and it works...
Code:devine dl -V -A my5 https://www.channel5.com/dexter/season-1/dexter
Just wanted to say cheers for the services and the downloader. Been lurking without an account on here for a while and honestly this place has helped massively with archiving favourite stuff when it pops up on the FTA services. Very grateful. Even got me trying to modify existing services which is something I would've never thought I'd be doing. Mixed results obvs but given it's the AMZN one from TPD94 and trying to make it work in the UK, not one for asking about here. Did send me down a very interesting amazon prime API documentation rabbithole though.
Hi All
Can anyone assist me with how to download just one season (4) of this show
https://www.ctv.ca/shows/moonlighting
but without the subtitles
thanks -
Hi guys, I thought I'd give TUBI a test, when I tried I got this error, I have my TUBI cookie in place, is the error something to do with N_m3u8DL-RE? thanks for the help
Code:(devine-py3.12) PS C:\Users\User\git\devine-333-poetry-n_m3u8dl_re\devine> devine dl -w S10 TUBI https://tubitv.com/series/300011392/mythbusters/season-10 / __ \/ ____/ | / / _/ | / / ____/ / / / / __/ | | / // // |/ / __/ / /_/ / /___ | |/ // // /| / /___ /_____/_____/ |___/___/_/ |_/_____/ ⠀ v3.3.3 Copyright © 2019-2025 rlaphoenix https://github.com/devine-dl/devine Service Config loaded Loaded Cdm Widevine CDM: 4464 (L3) Loaded 0 Vaults ────────────────────────────── Service: TUBI ─────────────────────────────── Service is Geoblocked in your region, getting a Proxy to us Authenticated with Service ──────────────────────── Series: MythBusters (2003) ──────────────────────── 9 Seasons, 186 Episodes ───────────────── MythBusters S10E01 Duct Tape: The Return ───────────────── No Widevine PSSH was found for this track, is it DRM free? No Widevine PSSH was found for this track, is it DRM free? 1 Video └── [H.264, SDR] | en | 1280x720 @ 2452 kb/s, 23.993 FPS ⠦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ --:-- FAILED 1 Audio └── [AAC] | en | 2.0 ⠦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ --:-- FAILED ❌ Download Failed... [N_m3u8DL-RE]: Descriptor.URL is currently not supported An unexpected error occurred in one of the download workers. See the error trace above for more information. -
Thankfully TUBI worked for me and I hope you find a solution to your issue.
hello,
quick question about iP and HLG. usingresults in a video file withCode:devine dl -w s01e01 --no-folder -r hlg ip https://www.bbc.co.uk/iplayer/episode/m0023h9f/asia-series-1-1-beneath-the-waves
how do I getCode:Transfer characteristics: BT.2020 (10-bit)
Any ideas? Many thanks.Code:Transfer characteristics: HLG
The MP4 video file (before merging) seems to have the correct metadata (Transfer characteristics : HLG). Is mkvmerge the culprit here?
Code:General Complete name : Video.mp4 Format : iso9 Codec ID : iso9 (iso9/avc1/dash/clg1) File size : 7.64 GiB Duration : 57 min 59 s Overall bit rate : 18.8 Mb/s Frame rate : 25.000 FPS Encoded date : 2024-11-01 20:03:03 UTC Tagged date : 2024-11-01 20:03:03 UTC Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@Main Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 57 min 59 s Bit rate : 18.8 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : Component Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.091 Stream size : 7.63 GiB (100%) Title : BBC Video Service kind : urn:mpeg:dash:role:2011:main Encoded date : 2024-11-01 20:03:03 UTC Tagged date : 2024-11-01 20:03:03 UTC Color range : Limited Color primaries : BT.2020 Transfer characteristics : HLG transfer_characteristics_Original : HLG / BT.2020 (10-bit) Matrix coefficients : BT.2020 non-constant Codec configuration box : hvcC
Most likely ....
What version of MKVToolnix do you have on your system?
# MKV ToolNix;
Also looking at:Code:mkvextract --version;
https://cdm-project.com/stabbedbybrick/devine-services
Some versions of the dependencies work better than others. These are the recommended versions as of 241015:
Shaka Packager: v2.6.1
CCExtractor: v0.93
MKVToolNix: v87.0
FFmpeg: v7.1 -
Hey,
I should have mentioned that every version of mkvtoolnix from 79 to 89 seems to modify the metadata of the video file. Weirdly, when I ask devine to download only the video with -V the mkv file has the correct metadata (Transfer characteristics: HLG). I can grab audio+subs separately with -A -S and combine the video mkv with the audio+subs mkv and that also seems to keep Transfer characteristics: HLG. smh -
When using Python 13 and trying to install the dependencies of devine using poetry, I get this strange error in return.
Any ideas?
C:\APPLICATIONS\git_stabbedbybrick_devine_py313poe try>py -3.13-64 -m poetry install
The "poetry.dev-dependencies" section is deprecated and will be removed in a future version. Use "poetry.group.dev.dependencies" instead.
Creating virtualenv devine in C:\APPLICATIONS\git_stabbedbybrick_devine_py313poe try\.venv
Installing dependencies from lock file
Package operations: 69 installs, 0 updates, 0 removals
- Installing frozenlist (1.4.1)
- Installing idna (3.7)
- Installing multidict (6.0.5)
- Installing setuptools (69.5.1)
- Installing aiosignal (1.3.1)
- Installing attrs (23.2.0)
- Installing charset-normalizer (3.3.2)
- Installing colorama (0.4.6)
- Installing certifi (2024.2.2)
- Installing construct (2.8.8)
- Installing distlib (0.3.8)
- Installing filelock (3.13.4)
- Installing marisa-trie (1.1.0): Failed
PEP517 build of a dependency failed
Backend subprocess exited when trying to invoke build_wheel
| Command '['C:\\Users\\ANONYM~1\\AppData\\Local\\Temp\\tmp95d wegnc\\.venv\\Scripts\\python.exe', 'C:\\Users\\AnonymousUser\\AppData\\Roaming\\Pytho n\\Python313\\site-packages\\pyproject_hooks\\_in_process\\_in_proces s.py', 'build_wheel', 'C:\\Users\\ANONYM~1\\AppData\\Local\\Temp\\tmp553 r6a_0']' returned non-zero exit status 1.
| running bdist_wheel
| running build
| running build_clib
| building 'libmarisa-trie' library
| creating build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\io
| creating build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\trie
| creating build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\vector
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -Imarisa-trie\lib -Imarisa-trie\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\i nclude" "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Auxiliary\VS\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.22621.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\um" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\shared" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\winrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\cppwinrt" /EHsc /Tpmarisa-trie\lib\marisa/grimoire/io\mapper.cc /Fobuild\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\io\mapper.obj
| mapper.cc
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -Imarisa-trie\lib -Imarisa-trie\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\i nclude" "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Auxiliary\VS\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.22621.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\um" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\shared" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\winrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\cppwinrt" /EHsc /Tpmarisa-trie\lib\marisa/grimoire/io\reader.cc /Fobuild\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\io\reader.obj
| reader.cc
| marisa-trie\lib\marisa/grimoire/io\reader.cc(121): warning C4267: 'initializing': conversion from 'size_t' to 'unsigned int', possible loss of data
| marisa-trie\lib\marisa/grimoire/io\reader.cc(121): warning C4267: 'initializing': conversion from 'size_t' to 'const unsigned int', possible loss of data
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -Imarisa-trie\lib -Imarisa-trie\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\i nclude" "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Auxiliary\VS\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.22621.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\um" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\shared" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\winrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\cppwinrt" /EHsc /Tpmarisa-trie\lib\marisa/grimoire/io\writer.cc /Fobuild\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\io\writer.obj
| writer.cc
| marisa-trie\lib\marisa/grimoire/io\writer.cc(121): warning C4267: 'initializing': conversion from 'size_t' to 'unsigned int', possible loss of data
| marisa-trie\lib\marisa/grimoire/io\writer.cc(121): warning C4267: 'initializing': conversion from 'size_t' to 'const unsigned int', possible loss of data
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -Imarisa-trie\lib -Imarisa-trie\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\i nclude" "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Auxiliary\VS\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.22621.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\um" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\shared" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\winrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\cppwinrt" /EHsc /Tpmarisa-trie\lib\marisa/grimoire/trie\louds-trie.cc /Fobuild\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\trie\louds-trie.obj
| louds-trie.cc
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -Imarisa-trie\lib -Imarisa-trie\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\i nclude" "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Auxiliary\VS\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.22621.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\um" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\shared" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\winrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\cppwinrt" /EHsc /Tpmarisa-trie\lib\marisa/grimoire/trie\tail.cc /Fobuild\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\trie\tail.obj
| tail.cc
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -Imarisa-trie\lib -Imarisa-trie\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\i nclude" "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Auxiliary\VS\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.22621.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\um" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\shared" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\winrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\cppwinrt" /EHsc /Tpmarisa-trie\lib\marisa/grimoire/vector\bit-vector.cc /Fobuild\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\vector\bit-vector.obj
| bit-vector.cc
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -Imarisa-trie\lib -Imarisa-trie\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\i nclude" "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Auxiliary\VS\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.22621.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\um" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\shared" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\winrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\cppwinrt" /EHsc /Tpmarisa-trie\lib\marisa\agent.cc /Fobuild\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\agent.obj
| agent.cc
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -Imarisa-trie\lib -Imarisa-trie\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\i nclude" "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Auxiliary\VS\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.22621.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\um" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\shared" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\winrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\cppwinrt" /EHsc /Tpmarisa-trie\lib\marisa\keyset.cc /Fobuild\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\keyset.obj
| keyset.cc
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -Imarisa-trie\lib -Imarisa-trie\include "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\i nclude" "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Auxiliary\VS\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.22621.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\um" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\shared" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\winrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\cppwinrt" /EHsc /Tpmarisa-trie\lib\marisa\trie.cc /Fobuild\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\trie.obj
| trie.cc
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\lib.exe" build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\io\mapper.obj build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\io\reader.obj build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\io\writer.obj build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\trie\louds-trie.obj build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\trie\tail.obj build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\grimoire\vector\bit-vector.obj build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\agent.obj build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\keyset.obj build\temp.win-amd64-cpython-313\marisa-trie\lib\marisa\trie.obj /OUT:build\temp.win-amd64-cpython-313\libmarisa-trie.lib
| Microsoft (R) Library Manager Version 14.42.34436.0
| Copyright (C) Microsoft Corporation. All rights reserved.
| running build_ext
| building 'marisa_trie' extension
| creating build\temp.win-amd64-cpython-313\Release\src
| "C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\b in\HostX86\x64\cl.exe" /c /nologo /O2 /W3 /GL /DNDEBUG /MD -Imarisa-trie\include -IC:\Users\ANONYM~1\AppData\Local\Temp\tmp95dwegnc\ .venv\include -IC:\Users\AnonymousUser\AppData\Local\Programs\Pyt hon\Python313\include -IC:\Users\AnonymousUser\AppData\Local\Programs\Pyt hon\Python313\Include "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.42.34433\i nclude" "-IC:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Auxiliary\VS\include" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.22621.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\um" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\shared" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\winrt" "-IC:\Program Files (x86)\Windows Kits\10\\include\10.0.22621.0\\cppwinrt" /EHsc /Tpsrc/agent.cpp /Fobuild\temp.win-amd64-cpython-313\Release\src\agent.obj
| agent.cpp
| src/agent.cpp(1254): warning C4996: 'Py_UNICODE': deprecated in 3.13
| src/agent.cpp(1256): warning C4996: 'Py_UNICODE': deprecated in 3.13
| src/agent.cpp(3082): error C2660: '_PyLong_AsByteArray': function does not take 5 arguments
| C:\Users\AnonymousUser\AppData\Local\Programs\Pyth on\Python313\include\cpython/longobject.h(111): note: see declaration of '_PyLong_AsByteArray'
| src/agent.cpp(3082): note: while trying to match the argument list '(PyLongObject *, unsigned char *, size_t, int, bool)'
| src/agent.cpp(3355): error C2660: '_PyLong_AsByteArray': function does not take 5 arguments
| src/agent.cpp(3355): note: while trying to match the argument list '(PyLongObject *, unsigned char *, size_t, int, bool)'
| error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio\\2022\\BuildTools\\VC\\Tools\\MSVC\\14.42.3 4433\\bin\\HostX86\\x64\\cl.exe' failed with exit code 2
Note: This error originates from the build backend, and is likely not a problem with poetry but one of the following issues with marisa-trie (1.1.0)
- not supporting PEP 517 builds
- not specifying PEP 517 build requirements correctly
- the build requirements are incompatible with your operating system or Python version
- the build requirements are missing system dependencies (eg: compilers, libraries, headers). -
A couple of days ago, on TUBI, I downloaded and my downloads worked fine. Today I am trying, and anything that I download fails with the error below. I downloaded "passengers" a couple of days ago and it worked fine. Right now, I retry to download it from TUBI and the download fails:
Any ideas?Code:HTTPError: 403 Client Error: Forbidden for url: https://tubitv.com/oz/videos/100032304/content?video_resources=hlsv6_widevine_no nclearlead&video_resources=hlsv6
Here is the full output:
(devine-py3.11) W:\APPLICATIONS_DESKTOP\git_devine_dl_devine_py311 poetry>devine dl --list-titles TUBI https://tubitv.com/movies/100032304/passengers
Loaded 0 Vaults
Loaded Hola: 43 Countries
│ W:\APPLICATIONS_DESKTOP\git_devine_dl_devine_py311 poetry\.venv\Scripts\\devi │
│ ne:6 in <module> │
│ 3 from devine.core.__main__ import main │
│ 4 │
│ 5 if __name__ == '__main__': │
│ ❱ 6 │ sys.exit(main()) │
│ 7 │
│ W:\APPLICATIONS_DESKTOP\git_devine_dl_devine_py311 poetry\.venv\Lib\site-pack │
│ ages\click\core.py:1157 in __call__ │
│ ages\click\core.py:1078 in main │
│ ages\click\core.py:1688 in invoke │
│ ages\click\core.py:1657 in _process_result │
│ ages\click\core.py:783 in invoke │
│ W:\APPLICATIONS_DESKTOP\git_devine_dl_devine_py311 poetry\devine\commands\dl. │
│ py:302 in result │
│ 299 │ │ │ │ self.log.info("Authenticated with Service") │
│ 300 │ │ │
│ 301 │ │ with console.status("Fetching Title Metadata...", spinner="dot │
│ ❱ 302 │ │ │ titles = service.get_titles() │
│ 303 │ │ │ if not titles: │
│ 304 │ │ │ │ self.log.error("No titles returned, nothing to downloa │
│ 305 │ │ │ │ sys.exit(1) │
│ W:\APPLICATIONS_DESKTOP\symbolic_links_devine-services\TUBI\__init__.py:155 │
│ in get_titles │
│ 152 │ │ │
│ 153 │ │ if kind == "movies": │
│ 154 │ │ │ r = self.session.get(self.config["endpoints"]["content"].f │
│ ❱ 155 │ │ │ r.raise_for_status() │
│ 156 │ │ │ data = r.json() │
│ 157 │ │ │ return Movies( │
│ 158 │ │ │ │ [ │
│ ages\requests\models.py:1021 in raise_for_status │
│ 1018 │ │ │ ) │
│ 1019 │ │ │
│ 1020 │ │ if http_error_msg: │
│ ❱ 1021 │ │ │ raise HTTPError(http_error_msg, response=self) │
│ 1022 │ │
│ 1023 │ def close(self): │
│ 1024 │ │ """Releases the connection back to the pool. Once this method │
(devine-py3.11) W:\APPLICATIONS_DESKTOP\git_devine_dl_devine_py311 poetry> -
Hard to tell. I was hoping to get confirmation from someone else here whether they get Transfer characteristics: HLG or BT.2020
An easy link to try is https://www.bbc.co.uk/iplayer/episode/m001gn7t/the-boy-the-mole-the-fox-and-the-horse 🙏 -
With all the leaked SL3k's out combined, you can get AMZN 4k, DSNP 4k, ATVP 4k, STAN 4k, HULU 4k, MAX 4k, PMTP 4k and 1080p for most others. I'd say that's pretty fun. The downside is that once they become public there's a much higher risk of them being downgraded, so use them while you can.
Looks like Tubi's made some changes to their API. I'll look into it. -
We hit this a few weeks ago and the solution I found was to run this command on the ouput files:
Code:mkvmerge -o output.mkv --colour-transfer-characteristics 0:18 input.mkv
[Attachment 85354 - Click to enlarge]
[Attachment 85355 - Click to enlarge]
Hey guys, can someone help me figure out what am I doing wrong. I just setup devine. widevineproxy2 doesnt work either, it says "Response status code does not indicate success: 403 (Forbidden)". The following is my config file
[Attachment 85356 - Click to enlarge]
How do I completely remove the music and sound effects from a movie?
By cns00 in forum EditingReplies: 1Last Post: 15th Jan 2024, 13:11 -
Which software can remove music from show but keep character dialogue?
By Mohamed61020 in forum AudioReplies: 6Last Post: 2nd Jul 2023, 22:32 -
Software for simple music videos?
By dewiclements in forum Software PlayingReplies: 3Last Post: 26th Jul 2022, 02:21 -
H.264 for archival and editing - no go?
By malling in forum Capturing and VCRReplies: 8Last Post: 20th Aug 2019, 00:51 -
Movie music too loud but dialogue too quiet fix needed
By hokkom in forum AudioReplies: 121Last Post: 4th May 2019, 09:51
