How do you extract frames and keyframes from .bik files?
Also, how do I use Avidemux to extract frames and keyframes?
Use the up and down arrow keys to navigate to the I frame you want.
File/save as image -
What about the .bik files and VirtualDub? How do I extract all keyframes at once?
Why don't you just use ffmpeg as was suggested here. This command given seems to work
https://forum.videohelp.com/threads/412226-Losslessly-Extract-Keyframes#post2711506 -
I see what you mean, ffmpeg can not decode the source. Directshow can open it with LAV filters installed,
for example, you can use Graphedit.
But I don't know how to get FFmpeg to open a file using Dshow, or if it's even possible
You can certainly open the file in an Avisynth script and use that as input to ffmpeg, but then
access to the original I frames is lost -
Like this?
[Attachment 74789 - Click to enlarge]
.bik (2.5 newest version) audio only play music track theres no dialogue
By sh2dc in forum Newbie / General discussionsReplies: 7Last Post: 5th Nov 2023, 04:42 -
.bik and .thp Help
By Jay123210599 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2023, 08:57 -
BIK Audio Problem
By Jay123210599 in forum Newbie / General discussionsReplies: 13Last Post: 2nd Nov 2023, 15:48 -
yoitv extraction
By tu0ba0tu0 in forum Video Streaming DownloadingReplies: 1Last Post: 25th Jan 2023, 03:12 -
Mp4Box - Output is generated without frame Width, frame height & frame rate
By Saptarshi in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2022, 08:27
