Page 3 of 3
FirstFirst 1 2 3
Results 61 to 81 of 81
  1. Thanks, I found the error. I had an incorrect .mpd URL.
    I don't understand. I set the filter to mpd. Then I take the first URL directly.
    Best regards
    Heiko
  2. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    You encountered this same issue a year ago and you solved it somehow
    https://forum.videohelp.com/threads/411044-Downloading-videos-from-RTL
  3. Good evening,
    I wanted to try N_m3u8DL-RE. But somehow it records a lot of small files. If I cancel with Ctrl-C, nothing final comes out.
    I tried this command under Linux:
    N_m3u8DL-RE "https://pnowlive-a.akamaized.net/live/rtl2hd/dash/rtl2hd.mpd" --key dbc471fc4c310aab6023f1dd38462e83:86763f0030ecd2fd8 2a8b04d20f7f4b3 --save-dir "media/plus_rtl2_de" --save-name "rtl2" -M format=mkv
    What am I doing wrong again?
    Best regards
    Heiko
  4. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    N_m3u8DL-RE "https://pnowlive-a.akamaized.net/live/rtl2hd/dash/rtl2hd.mpd" --key dbc471fc4c310aab6023f1dd38462e83:86763f0030ecd2fd82a8b04d20f7f4b3 --save-dir "media/plus_rtl2_de" --save-name "rtl2" --live-pipe-mux --live-record-limit 00:02:00
    This will download 2 minutes starting from the present. Don't forget to mux the final ts to mkv or whatever else you want (mkvtoolnix etc).
  5. I found this: --live-record-limit 00:01:30. But it still doesn't seem to produce an MKV file in the end.
    Best regards
    Heiko
  6. Thank you. But the command doesn't work. I copied it exactly as it was.
    Best regards
    Heiko
  7. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    The command works. Show screenshot with error code and the input. If by "not working" you mean no mkv output, then just mux it manually to mkv using mkvtoolnix. N_m3u8DL-RE is an excellent tool for vods, but mediocre tool for livestreams (the only good thing is default DRM support).
    Muxing the file to mkv just means changing the container, so no reencoding shenanigans.
  8. Hello,
    here is a screenshot of the copied command:
    heiko@Worf:~/RTL2$ ll
    insgesamt 8
    drwxrwxr-x   2 heiko heiko 4096 Sep 29 14:50 ./
    drwxr-xr-x 103 heiko heiko 4096 Sep 29 00:04 ../
    heiko@Worf:~/RTL2$ N_m3u8DL-RE "https://pnowlive-a.akamaized.net/live/rtl2hd/dash/rtl2hd.mpd" --key dbc471fc4c310aab6023f1dd38462e83:86763f0030ecd2fd82a8b04d20f7f4b3 --save-dir "media/plus_rtl2_de" --save-name "rtl2" --live-pipe-mux --live-record-limit 00:02:00
    Unrecognized command or argument '--live-pipe-mux'.
    Description:
      N_m3u8DL-RE (Beta version) 20221120
    Usage:
      N_m3u8DL-RE <input> [options]
    Arguments:
      <input>  Input Url or File
    Options:
      --tmp-dir <tmp-dir>                      Set temporary file directory
      --save-dir <save-dir>                    Set output directory
      --save-name <save-name>                  Set output filename
      --base-url <base-url>                    Set BaseURL
      --thread-count <number>                  Set download thread count [default: 8]
      --download-retry-count <number>          The number of retries when download segment error [default: 3]
      --auto-select                            Automatically selects the best tracks of all types [default: False]
      --skip-merge                             Skip segments merge [default: False]
      --skip-download                          Skip download [default: False]
      --check-segments-count                   Check if the actual number of segments downloaded matches the expected number [default: True]
      --binary-merge                           Binary merge [default: False]
      --del-after-done                         Delete temporary files when done [default: True]
      --no-date-info                           Date information is not written during muxing [default: False]
      --write-meta-json                        Write meta json after parsed [default: False]
      --append-url-params                      Add Params of input Url to segments, useful for some websites, such as kakao.com [default: False]
      -mt, --concurrent-download               Concurrently download the selected audio, video and subtitles [default: False]
      -H, --header <header>                    Pass custom header(s) to server, Example:
                                               -H "Cookie: mycookie" -H "User-Agent: iOS"
      --sub-only                               Select only subtitle tracks [default: False]
      --sub-format <SRT|VTT>                   Subtitle output format [default: SRT]
      --auto-subtitle-fix                      Automatically fix subtitles [default: True]
      --ffmpeg-binary-path <PATH>              Full path to the ffmpeg binary, like C:\Tools\ffmpeg.exe
      --log-level <DEBUG|ERROR|INFO|OFF|WARN>  Set log level [default: INFO]
      --ui-language <en-US|zh-CN|zh-TW>        Set UI language
      --urlprocessor-args <urlprocessor-args>  Give these arguments to the URL Processors.
      --key <key>                              Pass decryption key(s) to mp4decrypt/shaka-packager. format:
                                               --key KID1:KEY1 --key KID2:KEY2
      --key-text-file <key-text-file>          Set the kid-key file, the program will search the KEY with KID from the file.(Very large file are not recommended)
      --decryption-binary-path <PATH>          Full path to the tool used for MP4 decryption, like C:\Tools\mp4decrypt.exe
      --use-shaka-packager                     Use shaka-packager instead of mp4decrypt to decrypt [default: False]
      --mp4-real-time-decryption               Decrypt MP4 segments in real time [default: False]
      -M, --mux-after-done <OPTIONS>           When all works is done, try to mux the downloaded streams. Use "--morehelp mux-after-done" for more details
      --custom-hls-method <METHOD>             Set HLS encryption method (AES_128|AES_128_ECB|CENC|CHACHA20|NONE|SAMPLE_AES|SAMPLE_AES_CTR|UNKNOWN)
      --custom-hls-key <FILE|HEX|BASE64>       Set the HLS decryption key. Can be file, HEX or Base64
      --custom-hls-iv <FILE|HEX|BASE64>        Set the HLS decryption iv. Can be file, HEX or Base64
      --use-system-proxy                       Use system default proxy [default: True]
      --custom-proxy <URL>                     Set web request proxy, like http://127.0.0.1:8888
      --live-perform-as-vod                    Download live streams as vod [default: False]
      --live-real-time-merge                   Real-time merge into file when recording live [default: False]
      --live-keep-segments                     Keep segments when recording a live (liveRealTimeMerge enabled) [default: True]
      --live-record-limit <HH:mm:ss>           Recording time limit when recording live
      --live-wait-time <SEC>                   Manually set the live playlist refresh interval
      --mux-import <OPTIONS>                   When MuxAfterDone enabled, allow to import local media files. Use "--morehelp mux-import" for more details
      -sv, --select-video <OPTIONS>            Select video streams by regular expressions. Use "--morehelp select-video" for more details
      -sa, --select-audio <OPTIONS>            Select audio streams by regular expressions. Use "--morehelp select-audio" for more details
      -ss, --select-subtitle <OPTIONS>         Select subtitle streams by regular expressions. Use "--morehelp select-subtitle" for more details
      --morehelp <OPTION>                      Set more help info about one option
      --version                                Show version information
      -?, -h, --help                           Show help and usage information
    heiko@Worf:~/RTL2$
    The --live-pipe-mux doesn't seem to be correct.
    Best regards
    Heiko
  9. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    https://github.com/nilaoda/N_m3u8DL-RE/releases get the latest version for your OS and delete your old previous one
  10. Thanks, it worked now.
    I now have an rtl2.ts file, among other things, that I can play.
    Why do I still need the mkvtoolnix?
    Have a nice evening,
    Heiko
  11. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Because in this comment you seemed to be complaining that the final file isn't mkv. If you're ok with ts, you can leave it as it is.
  12. OK.
    Then I'll see if my satellite receiver can play the .ts files.
    But I have another question. I have a link:
    https://forum.videohelp.com/threads/412209-Download-from-plus-rtl-de/page2
    Are there any more channels with the mpd?
    Mainly German channels.
    Best regards
    Heiko
  13. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Read
    https://forum.videohelp.com/threads/412209-Download-from-plus-rtl-de/page2#post2740793
    @ghost gave you everything you need, mpd + keys
  14. Hello everyone.
    I have a problem with RTL+ again, but it's a free video:
    https://plus.rtl.de/video-tv/serien/medical-detectives-geheimnisse-der-gerichtsmedizin-241410
    PSSH: AAAAUHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADAIARIgMDZlZWZiMGIyY2IzYjhjZmIyZTRmMmM2ZTI3MzcwNjgiBjk3NTQ2MyoCU0Q=
    License URL: https://widevine.tvnow.de/index/rtlplus
    I get this error:
    heiko@Worf:~/test$ python3 '/home/heiko/Downloads/WKS-KEYS/l3.py'
    license request failed:
     b'{"error":"invalid.meta.data.ACCESS_DENIED.175)","errorCode":12400,"origin":"google"}'
    heiko@Worf:~/test$
    I think it's because of the broken WKS-KEYS l3.py or the Pywidevine.
    At first it worked the whole time. Then I messed something up.
    Many thanks,
    Heiko
  15. What does the requirements.txt for l3.py look like?
  16. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    python widefrog.py "https://plus.rtl.de/video-tv/serien/medical-detectives-geheimnisse-der-gerichtsmedizin-241410/staffel-6-975462/episode-1-ein-anderes-leben-975463"
    N_m3u8DL-RE "https://vodnowusoawsdash-a.akamaihd.net/p112/cves/sd/rtlplus/975463/4-1-1-1-2.ism/v1.mpd" --key 06eefb0b2cb3b8cfb2e4f2c6e2737068:df6def1471fae544f8750a230991341f --save-dir "media\plus_rtl_de" --save-name "Medical_Detectives_-_Geheimnisse_der_Gerichtsmedizin_Ein_anderes_Leben" -M format=mkv
  17. Hi, I got an error message:
    heiko@Worf:~/test$ python3 '/home/heiko/Downloads/Widefrog  v2.7.0/widefrog.py' "https://plus.rtl.de/video-tv/serien/medical-detectives-geheimnisse-der-gerichtsmedizin-241410/staffel-6-975462/episode-1-ein-anderes-leben-975463"
      File "/home/heiko/Downloads/Widefrog  v2.7.0/widefrog.py", line 6, in <module>
        from utils.main_service import main_service
      File "/home/heiko/Downloads/Widefrog  v2.7.0/utils/main_service.py", line 12, in <module>
        import utils.tools.common as common_tools
      File "/home/heiko/Downloads/Widefrog  v2.7.0/utils/tools/common.py", line 9, in <module>
        import numpy as np
    ModuleNotFoundError: No module named 'numpy'
    heiko@Worf:~/test$
    heiko@Worf:~/test$
    heiko@Worf:~/test$ python '/home/heiko/Downloads/Widefrog  v2.7.0/widefrog.py' "https://plus.rtl.de/video-tv/serien/medical-detectives-geheimnisse-der-gerichtsmedizin-241410/staffel-6-975462/episode-1-ein-anderes-leben-975463"
      File "/home/heiko/Downloads/Widefrog  v2.7.0/widefrog.py", line 95
        msg=f"The {CONFIG_FILE} file was created. Edit the file and run the program."
    SyntaxError: invalid syntax
    heiko@Worf:~/test$
    I downloaded and unpacked this link:
    https://files.videohelp.com/u/308780/widefrog_v2_7_0_python_source_code.zip
    Best regards
    Heiko
  18. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    Keep this thread only for plus.rtl.de issues. For the tool assistance, go to the support thread that can be found in the stickies.
  19. I was just about to write it, I already found the link:
    https://forum.videohelp.com/threads/414548-drm-free-content-batch-downloader-widefrog
    I already have N_m3u8DL-RE, mp4decrypt, ffmpeg and mkvmerge.
    What do I need for the shaka packager? There are several downloads available.
    Best regards
    Heiko
  20. If I don't want that, what happens next?
    pip install virtualenv
    virtualenv venv
    venv\Scripts\activate
    Best regards
    Heiko
  21. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    I don't think I made myself clear so I'll reiterate. Any questions you might have about the tool, you ask them on the relevant support thread and keep this one we're currently on, only for plus.rtl.de. This is basic forum etiquette.
