Hello,
I have a new link here where I want to download something:
https://plus.rtl.de/video-tv/shows/die-ultimative-chart-show-785220/staffel-28-907246/...ive-chart-show
Unfortunately, it doesn't work with yt-dlp:
The download Python script that I got here in the forum doesn't work either.Code:yt-dlp --allow-u -o enc.mp4 "https://px1.vtrtl.de/vt/hb.do?angebot=rtlpweb&beat=4&display=1&ivw=/developer/default&paystatus=10&rnd=535326734821026&starttype=0&status=3&videoid=907248&videoservice=plus&videourl=/p112/streaming/watch/907248/21-10000-1-1.ism/.mpd" WARNING: You have asked for UNPLAYABLE formats to be listed/downloaded. This is a developer option intended for debugging. If you experience any issues while using this option, DO NOT open a bug report [generic] Extracting URL: https://px1.vtrtl.de/vt/hb.do?angebot=rtlpweb&beat=4&display=1&ivw=/developer/default&paystatus=1...1-10000-1-1.ism/.mpd [generic] .mpd: Downloading webpage WARNING: [generic] Falling back on generic information extractor WARNING: [generic] URL could be a direct video link, returning it as such. [info] .mpd: Downloading 1 format(s): 0 [download] Destination: enc.mp4 [download] 100% of 43.00B in 00:00:00 at 323.96B/s heiko@Worf:~/Die ultimative Chart Show$ ll insgesamt 12 drwxrwxr-x 2 heiko heiko 4096 Sep 1 23:32 ./ drwxr-xr-x 66 heiko heiko 4096 Sep 1 23:27 ../ -rw-rw-r-- 1 heiko heiko 43 Sep 1 23:32 enc.mp4
Best regards
Heiko
				Results 1 to 18 of 18
	I get this mpd address:
 https://vodnowusoawsdash.secure.footprint.net/p112/streaming/watch/907248/21-10000-1-1.ism/.mpd
	mpd link:
 And the key to decrypt the video is:Code:https://vodnowusoawsdash.secure.footprint.net/p112/streaming/watch/907248/21-10000-1-1.ism/.mpd
 Code:--key c9cf3f7ac79bb32ca2311250788cb90b:e61e3870e8c8f7af313a0eb3860818ac
	Good morning,
 I looked again. Now I also find the .mpd link. Why I found something else yesterday is beyond me.
 I also found the pssh entry.
 I also found the license (https://widevine.tvnow.de/index/license). But I can't find the preAuthorization!
 https://getwvkeys.cc/ is still correct?!
 Best regards
 Heiko
	I tried again with https://getwvkeys.cc/. Always get an error message:
 {"code":500,"error":true,"message":"The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application."}
 Where can I get the script from? Is Python?
 Best regards
 Heiko
	Hi bro put this code in new text archive, and change by tvnow.py
 Open the python file and go
 Thanks @sk8ordi3Code:from pywidevine.L3.cdm import cdm, deviceconfig from base64 import b64encode from pywidevine.L3.decrypt.wvdecryptcustom import WvDecrypt m3u8DL_RE = 'N_m3u8DL-RE.exe' from pathlib import Path import requests import subprocess import re import os files_to_delete = ["key.txt"] for file_name in files_to_delete: if os.path.exists(file_name): os.remove(file_name) print(f"{file_name} file successfully deleted.") print('\ntest link: https://www.tvnow.de/shows/sing-meinen-song-das-tauschkonzert-7007/staffel-10/episode-1-stefanie-kloss-silbermond-5434807\ntest link: https://www.tvnow.de/shows/grill-den-henssler-2471/staffel-2023/episode-3-mit-christine-urspruch-the-bosshoss-pierre-m-krause-5440786\n') link = input('link: ') link_id = re.findall(r'-(\d+)$', link)[0].strip() headers1 = { 'authority': 'bff.apigw.tvnow.de', 'accept': 'application/json, text/plain, */*', 'origin': 'https://www.tvnow.de', 'referer': 'https://www.tvnow.de/', 'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/113.0.0.0 Safari/537.36 Edg/113.0.1774.42', } params1 = { 'playertracking': 'true', } response1 = requests.get('https://bff.apigw.tvnow.de/player/'+link_id+'', params=params1, headers=headers1).json() format = response1['videoConfig']['meta']['format'] title = response1['videoConfig']['meta']['title'] a_title = f'{format} - {title}' print(f'\n{a_title}\n') dashUrl = response1['videoConfig']['sources']['dashUrl'] print(f'{dashUrl}\n') jwt = response1['pageConfig']['user']['jwt'] import requests headers2 = { 'Accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9', 'Connection': 'keep-alive', 'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36', } response2 = requests.get(dashUrl, headers=headers2).text pssh = re.findall(r'<cenc:pssh>(.{20,170})</cenc:pssh>', response2)[0].strip() print(f'{pssh}\n') lic_url = 'https://widevine.tvnow.de/index/license' headers = { 'origin': 'https://www.tvnow.de', 'referer': 'https://www.tvnow.de/', 'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/113.0.0.0 Safari/537.36 Edg/113.0.1774.42', 'x-auth-token': jwt, 'content-type': 'application/x-www-form-urlencoded', } def WV_Function(pssh, lic_url, cert_b64=None): wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_b64, device=deviceconfig.device_android_generic) widevine_license = requests.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=headers) license_b64 = b64encode(widevine_license.content) wvdecrypt.update_license(license_b64) Correct, keyswvdecrypt = wvdecrypt.start_process() if Correct: return Correct, keyswvdecrypt Correct, keys = WV_Function(pssh, lic_url) st='' for key in keys: st+=' --key '+key with open("key.txt","a+") as f: f.write(st[1:]+'\n') with open("key.txt", "r") as f2: datas = f2.read() print(datas) with open("key.txt", "r") as fs: ke_ys = fs.readlines() ke_ys = ke_ys[0].strip().split() print() subprocess.run([m3u8DL_RE, '-M', 'format=mkv:muxer=ffmpeg', '--concurrent-download', '--auto-select', '--del-after-done', '--log-level', 'INFO', '--save-name', 'video', dashUrl, *ke_ys]) try: Path('video.mkv').rename(''+a_title+'.mkv') print(f'{a_title}.mkv \nall done!\n') except FileNotFoundError: print("[ERROR] no mkv file") for file_name in files_to_delete: if os.path.exists(file_name): os.remove(file_name) print(f"{file_name} file successfully deleted.")
	with wks-keys
 header:
 [Attachment 76582 - Click to enlarge]
 pssh and lic url:
 [Attachment 76583 - Click to enlarge]
 there is key
	The key specifically for what?
 The process is described very well in the stickies of this forum. And if you really refer to RTL: it's one of the easier sites to get the keys from.
 Just find the mpd url, extract pssh, look for the license request, and let your local cdm script acquire the keys.
 If you look for a specific video you should post the url.
	How can I capture this?
 https://plus.rtl.de/video-tv/shows/stern-tv-791695/2024-7-1006198/episode-28-sendung-v...4072024-970336
 Greetings,
 HJ
	You can download it:
 Code:https://vodnowusoawsdash-cf.tvnow.de/p112/cves/sd/rtlplus/970336/1-1-1-1-1.ism/v1.mpd Code:3c65a53ab54b09f696ce477e7b5b6f80:b1210cae3b0e64f9821e66100a24f971 Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
	Hi!
 Thank you!
 What program I must using for downloading?
 I never do this...
 Greetings,
 HJ
	Use N_m3u8DL-RE with the command:
 You might also need ffmpeg if not already 'installed'.Code:N_m3u8DL-RE https://vodnowusoawsdash-cf.tvnow.de/p112/cves/sd/rtlplus/970336/1-1-1-1-1.ism/v1.mpd --key 3c65a53ab54b09f696ce477e7b5b6f80:b1210cae3b0e64f9821e66100a24f971 -M format=mkv Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
	Hi!
 Stocking with that...
 C:\Users\Hans Jörg>N_m3u8DL-RE https://vodnowusoawsdash-cf.tvnow.de/p112/cves/sd/rtlplus/970336/1-1-1-1-1.ism/v1.mpd --key 3c65a53ab54b09f696ce477e7b5b6f80:b1210cae3b0e64f98 21e66100a24f971 -M format=mkv
 23:39:06.428 INFO : N_m3u8DL-RE (Beta version) 20230628
 23:39:06.441 ERROR: mp4decrypt not found!
 Any help again?
 Greetings,
 HJ
	your mp4decrypt is not in folder with N_m3u8DL-RE
 here, put it in folder with N_m3u8DL-RE
 https://files.videohelp.com/u/301156/mp4decrypt.zip
	Hi!
 I could download the video now,but the audio is corrupted...
 00:18:00.785 WARN : Reading media info...
 00:18:01.039 INFO : NaN: Video, h264 (avc3), 1920x1080
 00:18:47.230 INFO : Binary merging...
 00:19:26.342 INFO : Decrypting...
 00:19:26.874 INFO : Start downloading...Aud audio_1=128000 | 128 Kbps | mp4a.40.2 | de | 2CH
 00:19:26.914 WARN : Type: cenc
 00:19:26.916 WARN : PSSH(WV): CAESIDNjNjVhNTNhYjU0YjA5ZjY5NmNlNDc3ZTdiNWI2ZjgwIg Y5NzAzMzYqAlNE
 00:19:26.917 WARN : KID: 3c65a53ab54b09f696ce477e7b5b6f80
 00:19:26.918 WARN : Reading media info...
 00:19:28.169 INFO : NaN: Audio, aac (mp4a), 128 kb/s
 00:19:32.189 INFO : Binary merging...
 00:19:32.799 INFO : Decrypting...
 00:19:32.859 WARN : v1_2024-07-30_00-17-59.mp4
 00:19:32.859 WARN : v1_2024-07-30_00-17-59.de.m4a
 00:19:32.859 WARN : Muxing to v1_2024-07-30_00-17-59.MUX.mp4
 00:19:33.559 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 06674580] Incorrect number of samples in encryption info
 00:19:33.559 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 06674580] Could not find codec parameters for stream 0 (Video: h264 (avc3
 / 0x33637661), none, 1920x1080, 7789 kb/s): unspecified pixel format
 00:19:33.562 WARN : Consider increasing the value for the 'analyzeduration' and 'probesize' options
 00:19:33.746 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 07cae040] Incorrect number of samples in encryption info
 00:19:33.747 WARN : [mp4 @ 0ac2f400] track 1: codec frame size is not set
 00:19:33.749 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 07cae040] Incorrect number of samples in encryption info
 00:19:33.758 WARN : [mov,mp4,m4a,3gp,3g2,mj2 @ 06674580] Incorrect number of samples in encryption info
 00:19:33.759 WARN : C:\Users\Hans J├Ârg\v1_2024-07-30_00-17-59.mp4: Invalid data found when processing input
 00:19:33.761 WARN : C:\Users\Hans J├Ârg\v1_2024-07-30_00-17-59.de.m4a: Invalid data found when processing input
 00:19:33.852 WARN : Cleaning files...
 00:19:33.853 ERROR: The process cannot access the file 'C:\Users\Hans Jörg\v1_2024-07-30_00-17-59.mp4' because it is being used by another process.
 What is the problem?
 Any help again...
 Greetings,
 Hans
  Help downloading some videosBy oxoxen21 in forum Video Streaming DownloadingReplies: 115Last Post: 21st Dec 2023, 03:36
  First try with RTL+/TVNowBy resonator79 in forum Video Streaming DownloadingReplies: 3Last Post: 23rd Feb 2023, 07:41
  Help for downloading vdocipher videosBy Tusor in forum Video Streaming DownloadingReplies: 4Last Post: 4th Dec 2022, 19:03
  Help downloading some videosBy Doromilo in forum Video Streaming DownloadingReplies: 1Last Post: 29th Jul 2022, 17:54
  How can I download videos from play.rtl.hr?By Nintendo Custom in forum Video Streaming DownloadingReplies: 23Last Post: 24th May 2022, 13:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
