delete
just a heads up
please be careful with jwt ... may wish to remove it
\"name\":\"sxxxxxx\",\"phone\":\"8xxxxxxxx\",\"ip\ ":\"4x.3x.2xx.xx\",\"countryCode\":\"in\",\"custom erType\":\"nu\",\"type\":\"phone\",\"isEmailVerifi ed\":false,\"isPhoneVerified\":true,\"deviceId\":\ "4542ed-496986-81fadf-54xxxx\",\"profile\":\"ADULT\ -
thanks removed it, could you please help with mpd?
You have no idea what you are doing. The jwt is still there. Read up on what is a jwt and remove all those long strings that start with ey
Redact the cookie info
Also, the thread title is need help grabbing pssh
but this is not what you are after because you then state i can't download the mpd
Look at dev tools and study the curl call used to download the mpd.
You need to replicate that curl call.
Write a small python snippet just to download the mpd.
Break your task into small pieces then put them all together after they work. This is the foundation of debugging. -
getting this error when trying to send a get request to mpd:
Code:<HTML><HEAD><TITLE>Error</TITLE></HEAD><BODY> An error occurred while processing your request.<p> Reference #199.d4762c31.1696408146.78648a8 </BODY></HTML>
help grabbing from Polsat
By zoboomafu in forum Video Streaming DownloadingReplies: 10Last Post: 14th Apr 2024, 07:22 -
Different PSSH in mpd, EME logger and PSSH Box Generator
By Kevste in forum Video Streaming DownloadingReplies: 4Last Post: 31st May 2023, 23:24 -
How to get the PSSH?
By Anonymousdk01 in forum Video Streaming DownloadingReplies: 2Last Post: 28th Mar 2023, 11:06 -
get pssh
By tere1579 in forum Video Streaming DownloadingReplies: 6Last Post: 1st Dec 2022, 23:35 -
Which PSSH is the right one?
By Quint in forum Video Streaming DownloadingReplies: 5Last Post: 24th Oct 2022, 05:39
