  1. I'm trying to install the WKS-KEYS tool on termux... But it's not working correctly... Is there a tool that works in termux to get widevine keys...?
  2. have you read this tutorial from Angela?
    https://forum.videohelp.com/threads/405466-Downloading-and-decryption-on-your-Android-phone
    If you have problem post in this Thread.
  3. Hi, i have tried the tutorial, but i'm stuck with this problem. When I try to move mp4decrypt to the /data/data/com.termux/files/usr/bin/ directory when trying to run it gives me a "permission denied" error and after changing mp4decrypt's permissions with chmod 777 when I try to execute the following error "bad address" appears. What should I do?
    Feb 2022
    Search the forum first!
    You can only move files into Termux FROM Termux. That means from your PC you copy mp4decrypt into your phones sdcard/. I use 'adb push' to do the transfer. Assuming everything is well you then start Termux and use the Termux path to your /sdcard/mp4decrypt binary to copy to your Termux /bin location.
    In use there normally is never a need to use /data/data/com.termux/files/. All instruction are in the link Cedric gave. Clearly you need to go over it more carefully.
    This post also may help clarify. https://forum.videohelp.com/threads/405466-Downloading-and-decryption-on-your-Android-...ne#post2666459
    Noob Starter Pack. Just download any Widevine media! Over 28,000 downloads for V6!.
