Page 2 of 2
FirstFirst 1 2
Results 31 to 46 of 46
  1. Originally Posted by axemanozh View Post
    However, running both PSSHs through a CDM does yield a decryption key. Not sure why the methods generate different PSSHs, but they both worked for me, nothing that they both did pull up a previously cached key.
    [Attachment 77285 - Click to enlarge]
    [Attachment 77286 - Click to enlarge]
    I'll try another file later tonight or tomorrow and note if I find anything different.
    If they're pulling cached keys then you're really not requesting a license to the license server. Both PSSH work because they likely contain the same KID. If you wanted to test both PSSH against the license server then you should check "Force".
  2. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Just as an update with my test for any who might be interested.
    I used the Fetch PSSH Data tool to retrieve information from the init I find in developer tools:
    While this may work on some services, it's unclear which services check which fields in the PSSH. For some services it might be enough to have the KID in the PSSH to validate a license. Other services, however, could potentially refuse to validate a license because of other fields that are not filled out correctly.
    I'm not sure if this is the case, but it could very well be possible.
    Either way, I usually get the PSSH from the init file, which will always give me the correct one.
  3. Originally Posted by ElCap View Post
    the output box is much better now but it looks like the "3200" is still being appended
    Indeed, that's now fixed also, thanks for checking.
  4. I tried again today with another file, and it definitely works. Same method as in my previous post, just have to include the x-dt-auth-token value found in the license post in dev tools when running through the CDM.
    [Attachment 77301 - Click to enlarge]
    [Attachment 77302 - Click to enlarge]
  5. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    DRMToday is very easy with PSSH, never had any issue with generated PSSH even if not the same as the one from EME logger.
  6. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Originally Posted by ridibunda View Post
    Tested and approved It works. Thank you.
    R.I.P. Axinom
    Am I the only one who still has access to Axinom ?
  7. Me too.
    we just need to be registered to continue to use it
    [Attachment 77317 - Click to enlarge]
  8. Originally Posted by cedric8528 View Post
    Me too.
    Problem I had was they rejected my registration attempt. They were requiring an e-mail address with a broadcaster affiliated domain, IIRC.
  9. Simply registered with a gmail adress.
    I just tested
    Once registered, you just have to wait their approval.
    [Attachment 77320 - Click to enlarge]
  10. Originally Posted by cedric8528 View Post
    I just tested
    Interesting, thanks. I went back into my e-mail archive and this is what I got when I tried to register in September of last year.
    [Attachment 77322 - Click to enlarge]
    I wonder if their policy changed. Do you happen to have a "business" e-mail address, or what did you say when they asked for why you want an account, if you don't mind sharing?
    Edit: This is what my account looked like on their portal:
    [Attachment 77323 - Click to enlarge]
  11. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    I requested access on an email on my own domain. I don't remember what I added alongside the request though.
    Dec 2021
    england
    [Attachment 77326 - Click to enlarge]
    i put business is im chef business which is i lies ;P
  13. Originally Posted by axemanozh View Post
    I just tested
    Yesterday I tested and opened a new account with a classic gmail adress.
    2 hours after, my account was opened
    [Attachment 77351 - Click to enlarge]
    [Attachment 77352 - Click to enlarge]
    I said that I would like an account to learn more about PSSH decoding and widevine technic...something like that
  14. Originally Posted by cedric8528 View Post
    I just tested
    Thanks! I don’t particularly need the Axinom tool anymore, thanks to great knowledge and resources provided by everyone on this forum, but I might give it another attempt, more out of curiosity than anything else.
  15. Originally Posted by Karoolus View Post
    Now I saw their email about approving my account (And surprised to see that, because I lied about my account info )
    Anyway I won't use it. We have a great alternative here.
