Until I can see that error in action I am unable to help. Sorry.
Results 31 to 60 of 90
Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
https://files.videohelp.com/u/301890/hellyes6.zip -
I understand, thanks.
Re this code
Do you happen to know if the 403 is likely to be from a bad wv challenge? I'm wondering if something is likely to be misconfigured in my WKS-KEYS setup, or is the licence url rejecting the request even before validating the challenge.Code:wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_b64, device=deviceconfig.device_android_generic) widevine_license = httpx.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=None) license_b64 = b64encode(widevine_license.content) wvdecrypt.update_license(license_b64)
FWIW I'm new to all this and have not configured wks-keys beyond downloading. -
I'd try doing a:
And see if WKS-KEYS works for you. It should prompt for a PSSH value. If it instead complains about something, you'll need to resolve that first.Code:python l3.py
You need to create your own CDM (device_client_id_blob and device_private_key). Instructions are in the stickies in this forum and the files need to be put in the right places in the WKS-KEYS distribution before it'll work.
This is the thread to help with that: https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-Studio -
Hi A_n_g_e_l_a....
After reading post 1... there is mention of two scripts in the zip.. "Two python scripts itv_loader.py and slimitv.py".. but I have only itv_loader.py and ITVX.py an empty script called __init__.py
and a requirments text file.... (do i rename ITVX.py to slimitv.py)... or am i missing something. many thanks for your help and hard work... -
Okay, i got it, A_n_g_e_l_a,...
There is no slimitv.py... but after running the script i am getting an error...
D:\YT_Rips\WKS-KEYS>itv_loader.py
←[32m ____ ______ _ __ _ __
/ _/ /_ __/ | | / / | |/_/
_/ / / / | |/ / _> <
/___/ /_/ |___/ /_/|_|
←[0m
←[31mAn ITVX Video Search, Selector and Downloader.
←[0m
Search word(s)? limbo
[info] getting data for https://www.itv.com/watch/In-Limbo/10a4874
←[31m
Use up/down keys + spacebar to de-select or re-select videos to download
←[0m
Using pywidevine WVD on this machine
File "D:\YT_Rips\WKS-KEYS\itv_loader.py", line 246, in <module>
myITV.download(url)
File "D:\YT_Rips\WKS-KEYS\ITVX.py", line 168, in download
key = self.get_key(pssh, lic_url)
File "D:\YT_Rips\WKS-KEYS\ITVX.py", line 82, in get_key
from pywidevine.cdm import Cdm
ModuleNotFoundError: No module named 'pywidevine.cdm'
I'm aware there is no pywidevine.cdm module,... as I had this error once before. I cured it by making sure that an empty __init__.py was in every folder within the pywidevine folder. I have checked and they are within the folders. So i'm unsure why i am getting the error.
my reason for changing to this script is due to the 403 error with my older a_n_g_e_l_a script.. -
I'm assuming you're using WKS-KEYS given the folder name.
Did you change PYWIDEVINE = False in ITVX.py? -
Thank you dodgydodgy,
Testing on a series now,... I changed it to False and now its working. I was trying before on single episodes,... but I've decided to let it go on a four part series. Also Thank you A_n_g_e_l_a, It looks really smart.
My main folder is getting full up with old scripts,... its looking a right mess. Wish I could have Half a dozen WKS-KEYS folders,.. each one holding a script. But I'm guessing one can only have a single WKS-KEYS folder on a P.C. -
I was going to try and have a folder for CH5, one for itv, one for all4, ect.. Each containing the relevant script. I'm having to create txt files to remind me which ones work there are so many scripts in there, also due to me examining the scripts and creating new ones. (it's basically a mess).
This was the only info i could gain from a quick google search: https://github.com/rlaphoenix/pywidevine/releases
"Added new export-device command-line function to export WVD files back as files. I.e., a private key and client ID" blob file.
This is going to look easy for the experts, but I have no idea what the Code would do if i ran it.
After reading your post a dozen or so times, I think I slightly understand what you mean... I have a single WKS-KEYS folder.... Then on a separate drive a selection of folders named as i want them. place the relevant script into each of the folders.
But I would not need to have a wks-keys folder in each. But i would need ffmpeg.exe ffprobe.exe an elevated command prompt, mkvmerge.exe, mp4decrypt.exe, n_m3u8dl-cli_v2.9.8.exe, and n_m3u8dl-re.exe, along with n_m3u8dl-cli-simpleg.exe placed into each of my folders. -
Hi LastResort,
You wouldn't need to have all those files in each of your folders. All you need to do is add them into the PATH on your PC.
The quickest way to do this is to put them in the C:\windows\system32 folder. You will then be able to run them in any command prompt run from any directory on your PC.
Basically, when you call a windows executable, windows will look in the folder you've run the script from first, if it doesn't find it it then looks in all the folders mentioned in your PATH and when it finds it it will run it. C:\windows\system32 is always in the PATH in windows so just put the files in there and it will automatically find it. Obviously if you want to update to new versions of files in the future then you just copy over the file in c:\windows\system32 with the updated file. -
There is an update at #1 .
It is very minor but cleans up exiting the program mid-way through the selection of downloads. Ctrl-C will either take you back stage or exit according to where you've reached. So if you don't like the search result and need to enter a new term Ctrl-C will do it.
Less minor is that requirements.txt has been tightened to specify versions of the module imports. Should stop the recent mess with httpx versions being incompatible.Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
Hi All, super new to all this and would appreciate some help if you dont mind.
I seem to be getting the following
Any pointers in where to get android_sdk.wvd pleaseCode:Using pywidevine WVD on this machine Traceback (most recent call last): File "C:\itvx\itv_loader.py", line 254, in <module> myITV.download(url) File "C:\itvx\ITVX.py", line 168, in download key = self.get_key(pssh, lic_url) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\itvx\ITVX.py", line 86, in get_key device = Device.load(WVD_PATH) ^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\name\AppData\Local\Programs\Python\Python311\Lib\site-packages\pywidevine\device.py", line 164, in load with Path(path).open(mode="rb") as f: ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\name\AppData\Local\Programs\Python\Python311\Lib\pathlib.py", line 1044, in open return io.open(self, mode, buffering, encoding, errors, newline) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ FileNotFoundError: [Errno 2] No such file or directory: '\\home\\name\\android_sdk.wvd' PS C:\itvx> -
You need your own CDM and you need your own working pywidevine setup before you run this script.
Follow the stickies in this forum, they take you through it all. -
Depending where you are on your journey dodgydodgy's advice is for getting a Content Decryption Module and if you just need a wvd file that points to your CDM https://forum.videohelp.com/threads/411862-Beyond-WKS-KEYS
Thank you for another great script Angela! The search function has changed my life.
Thanks!
If you liked the search style then these are of the same format.
Channel4 https://files.videohelp.com/u/301890/channel4.zip
My 5 https://files.videohelp.com/u/301890/my5_update.zip
STV https://files.videohelp.com/u/301890/stv_files.zip for 1080p vidoes on ITV platform
UKTVPlay https://files.videohelp.com/u/301890/uktvp_files.zip Dave, Yesterday etc
And coming soon a fully searchable all-in-one for these 5 UK channels from a single starting point.Last edited by A_n_g_e_l_a; 6th Oct 2023 at 12:01.
I now have my own device_client_id_blob & device_private_key and tried to make my own android_sdk.wvd using json file with
but that didnt work, any pointers?Code:{ "device_private_key_url": "C:\dumper-main\key_dumps\Android Emulator 5554\private_keys\4464\1991389027\device_private_key", "device_client_blob_url": "C:\dumper-main\key_dumps\Android Emulator 5554\private_keys\4464\1991389027\device_client_id_blob" } -
"Beyond WKS-KEYS" describes a different way of building a .wvd file, a JSON file is not involved there. Maybe you should follow the instructions from that post?
Last hurdle I think... How do I point the ITVX.py to the .wvd file as I am getting
I also triedCode:Using pywidevine WVD on this machine Traceback (most recent call last): File "C:\itvx\itv_loader.py", line 254, in <module> myITV.download(url) File "C:\itvx\ITVX.py", line 168, in download key = self.get_key(pssh, lic_url) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\itvx\ITVX.py", line 86, in get_key device = Device.load(WVD_PATH) ^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\name\AppData\Local\Programs\Python\Python311\Lib\site-packages\pywidevine\device.py", line 164, in load with Path(path).open(mode="rb") as f: ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\name\AppData\Local\Programs\Python\Python311\Lib\pathlib.py", line 1044, in open return io.open(self, mode, buffering, encoding, errors, newline) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ FileNotFoundError: [Errno 2] No such file or directory: '\\home\\name\\android_sdk.wvd' PS C:\itvx>
Which gives meCode:WVD_PATH = "C:\Users\name\WVD\google_aosp_on_ia_emulator_14.0.0_381026f8_4464_l3.wvd"
Changed so the path isCode:PS C:\itvx> py itv_loader.py Traceback (most recent call last): File "C:\itvx\itv_loader.py", line 19, in <module> import ITVX as itv File "C:\itvx\ITVX.py", line 36 WVD_PATH = "C:\Users\name\WVD\google_aosp_on_ia_emulator_14.0.0_381026f8_4464_l3.wvd" ^ SyntaxError: (unicode error) 'unicodeescape' codec can't decode bytes in position 2-3: truncated \UXXXXXXXX escape PS C:\itvx>
Code:WVD_PATH = "C:\\Users\\name\\WVD\\google_aosp_on_ia_emulator_14.0.0_381026f8_4464_l3.wvd"
Code:Using pywidevine WVD on this machine Keys found 842f32ccf8794bcfaa46f49c510cd8c6:b005removde9883aab625cf Traceback (most recent call last): File "C:\itvx\itv_loader.py", line 254, in <module> myITV.download(url) File "C:\itvx\ITVX.py", line 207, in download subprocess.run(command) File "C:\Users\name\AppData\Local\Programs\Python\Python311\Lib\subprocess.py", line 548, in run with Popen(*popenargs, **kwargs) as process: ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\name\AppData\Local\Programs\Python\Python311\Lib\subprocess.py", line 1026, in __init__ self._execute_child(args, executable, preexec_fn, close_fds, File "C:\Users\name\AppData\Local\Programs\Python\Python311\Lib\subprocess.py", line 1538, in _execute_child hp, ht, pid, tid = _winapi.CreateProcess(executable, args, ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ FileNotFoundError: [WinError 2] The system cannot find the file specified PS C:\itvx>Last edited by phantom84; 6th Oct 2023 at 15:10.
Ahh fish sticks! Close I think I can feel it!
Code:Using pywidevine WVD on this machine Keys found 842f32ccf8794bremoved883aab625cf Traceback (most recent call last): File "C:\itvx\itv_loader.py", line 254, in <module> myITV.download(url) File "C:\itvx\ITVX.py", line 207, in download subprocess.run(command) File "C:\Users\name\AppData\Local\Programs\Python\Python311\Lib\subprocess.py", line 548, in run with Popen(*popenargs, **kwargs) as process: ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\name\AppData\Local\Programs\Python\Python311\Lib\subprocess.py", line 1026, in __init__ self._execute_child(args, executable, preexec_fn, close_fds, File "C:\Users\name\AppData\Local\Programs\Python\Python311\Lib\subprocess.py", line 1538, in _execute_child hp, ht, pid, tid = _winapi.CreateProcess(executable, args, ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ FileNotFoundError: [WinError 2] The system cannot find the file specified PS C:\itvx> -
Clearly you are very much a beginner at this with limited computing experience. Whilst in itself that is OK, after all we each were beginners once, endless small-step questions only fill up a thread with irrelevance for most and which tries the patience of older hands. The answers you seek are already here; printed in many places; the questions have been asked many times; many, many times. (Apologies to Round The Horne and Betty Marsden
) In fact for many of us it seems like Ground-Hog-Day here.
As an attempt to provide answers to newbies I wrote a few guides that appear in the 'stickies' and you need to read them. Start at 'Decryption: The last Crusade' - skipping a couple of guides - since you already have a CDM and are likely only going to be a script user. Most of your answers are there.
Secondly, when faced with a screen and keyboard the technology can over-whelm; we all feel that; keep your brain in gear and when you get an error message - as you will - ask yourself what does it mean? Look at the last bit of the error message above, the script - for that it what it is, it is not a program - the script calls other programs on your machine to download and decrypt a video. Since this is the very first time you've every tried such a thing your system lacks the programs the script calls. That is what the error message is complaining about. So next time instead of printing a whole host of error code you can ask what do I need to do to avoid a file not found error. And the answer would be provide the 'file'. And if you look through the script you might find where an external file using a 'subprocess.run' method is being called. Then you have a clue to what is missing. What is harder is that missing program calls others that will not be on your system yet either.
As a script writer I know my target audience have already served their apprenticeship, They read The Temple of Doom; they used l3.py to get keys; they used yt-dlp to download audio and video streams; they decrypted and merged the streams into a playable video; renaming and saving. You haven't served your apprenticeship yet so get get reading the stickie mentioned and inform yourself, as each before you has done. The answers are there. But if they are NOT then people are more willing to help.Last edited by A_n_g_e_l_a; 7th Oct 2023 at 07:16.
@phantom84 Another small piece of advice following on from what A_n_g_e_l_a mentioned. Set up virtual environments for running python scripts as this will help to avoid plenty of issues not directly related to the script in question.
In short, uninstall Python then reinstall with just the defaults. Don't install any other package or module.
Then create virtual environments for each script/project that you need to run.
For example.
C:\DLers\angela\itv
C:\DLers\angela\stv
C:\DLers\angela\ch4
Within each respective project folder create a virtual environment. I use .venv but the naming is up to you.
Once activated, then and only then do you start installing packages. These will only be accessible from within that venv so won't affect any other project.
Eventually you'll work out which packages you can install in the host without messing up the venvs but the method above will eliminate cross script dependency issues.
Remember once you've install a package in a venv, it's there until you either uninstall it or or delete the venv folder. -
If you have those files properly generated it's probably easier for you to just use WKS_KEYS, at least until you learn a bit more.
All you need to do is download WKS-KEYS from here - https://github.com/weapon121/WKS-KEY/releases/
Then put those two files in the WKS-KEYS\pywidevine\L3\cdm\devices\android_generic folder, replacing the two already in there. That should be it, as long as you've installed all the correct python modules it should then work. It does for me, on Windows 11.
Oh, make sure you edit ITVX.py to say PYWIDEVINE = False. -
Not that very out of date release please.
The release below, has updated protobufs, so WKS-KEYS and pywidevine do not have conflicts over the protobuf versions. So migrating from one to the other isn't a fraught experience.
(Sounds like you need to update WKS-KEYS too?
WKS-KEYS is here https://files.videohelp.com/u/301890/WKS-KEYS.zip
And I actually disagree with you. I think pywidevine is on the whole easier.Last edited by A_n_g_e_l_a; 10th Oct 2023 at 12:18.
im needing a little small script the MPDs seem to have a token that expires in 6 hours any advice on how to login with a script call https://www.itv.com/watch?channel=fast1 and have it return just the MPD with a updated token? so i can run it every 6 hours to keep the token updated (key dont change and i already have the key for the MPDs) i just need a small quick script to grab the new mpd each time its ran!
(i already have the key)
any advice on a script to just grab the MPD token?
Crash course on downloading ITVx hub please?
By adrian44 in forum Video Streaming DownloadingReplies: 301Last Post: 30th Jan 2025, 09:16 -
Best ITVX Downloader with Subtitles
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 216Last Post: 7th Nov 2023, 03:18 -
Will pay for scripts/Package (ITVX/All4) to download TV programmes
By PolkaDotBikini in forum LinuxReplies: 0Last Post: 26th Jul 2023, 23:11 -
ITVX & Error 403
By PhilipG in forum Video Streaming DownloadingReplies: 14Last Post: 20th May 2023, 03:39 -
Encoding ATSC Revisited
By chris319 in forum Video ConversionReplies: 0Last Post: 12th Apr 2019, 21:50
