Thanks I didn't even think about using chatGPT for things like that. I'm using windows 10 by the way. Also, will updating it fix the errors I get when I try to get something from Pluto?
Results 841 to 870 of 1613
I use it all the time, my tech knowledge in this kind of stuff is very limited so ChatGPT is extremely useful, I use it for writing all my little scripts and various things, it's like my tech Agony Aunt!
I just tested with Gunsmoke s07e01 and it downloaded fine!
[Attachment 76409 - Click to enlarge] -
Hey Stabbed hope you are well and thank you so much for all your efforts put into this project. I see you added TVNZ. Been able to get loads from it. Do you have any future plans to also add 'Threenow NZ' https://www.threenow.co.nz/ its free viewing but like a lot of sites, may just need credentials
Thanks -
This may be a stupid question, but how do I get my private_key and client_id blob?
Ran Proxy set to Hola:
(freevine115) PS C:\freevine115>python freevine.py get -t https://www.bbc.co.uk/iplayer/episode/p055vzj1/ --proxy UK
which gave me three episodes.
Decided to download each episode separately.
Success in downloading the first two episodes.
When I tried to download the third and the last episode I ran into:
Not sure how long is the ban.Code:(freevine115) PS C:\freevine115> python freevine.py get --episode S01E03 https://www.channel4.com/programmes/britain-ad-king-arthurs-britain --proxy UK ❯_freevine v1.1.5 16:08:13.162 INFO : ALL4 16:08:13.163 INFO : + Adding service profile 16:08:13.170 INFO : + Adding Hola proxy location: UK Traceback (most recent call last): File "C:\freevine115\freevine.py", line 15, in <module> cli() File "C:\freevine115\Lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine115\Lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "C:\freevine115\Lib\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine115\Lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine115\Lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\freevine115\utils\commands.py", line 90, in get Service(config, **kwargs) File "C:\freevine115\services\channel4\channel4.py", line 51, in __init__ super().__init__(config, **kwargs) File "C:\freevine115\utils\config.py", line 118, in __init__ uri = get_proxy(cli=self) ^^^^^^^^^^^^^^^^^^^ File "C:\freevine115\utils\proxies.py", line 155, in get_proxy return hola.proxy(query) ^^^^^^^^^^^^^^^^^ File "C:\freevine115\utils\proxies.py", line 91, in proxy raise ConnectionError(f"{output.stderr}") ConnectionError: MAIN : 2024/01/25 16:08:13 main.go:196: WARNING Detected latest extension version: "1.219.646". Pass -ext-ver parameter to skip resolve and speedup startup Transaction error: temporary ban detected. Retrying with the fallback mechanism... Transaction error: temporary ban detected. Retrying with the fallback mechanism... Transaction error: temporary ban detected. Retrying with the fallback mechanism... Transaction error: temporary ban detected. Retrying with the fallback mechanism... Transaction error: temporary ban detected. Retrying with the fallback mechanism... Transaction error: temporary ban detected. Retrying with the fallback mechanism... Transaction error: temporary ban detected. Retrying with the fallback mechanism... Transaction error: temporary ban detected. Retrying with the fallback mechanism... Transaction error: temporary ban detected. Retrying with the fallback mechanism... Transaction error: temporary ban detected. Retrying with the fallback mechanism... Transaction error: temporary ban detected. Retrying with the fallback mechanism... All attempts failed. (freevine115) PS C:\freevine115>Last edited by Spectrumhsm; 25th Jan 2024 at 17:34.
Not sure how long the ban lasts, I haven't really run into this issue enough to test it. But I'd recommend trying windscribe over hola for iplayer, or any other site that accepts it. And if you're downloading multiple episodes/seasons, I'd advise against doing it separately since that will send unnecessary requests to the proxy APIs.
Sorry to ask is there a thread for what goes into the directory for freevine ive got all the files downloaded but havent got a clue what needs to be put in the folder and the structure.
Install instructions are on https://github.com/stabbedbybrick/freevine
Just scroll down. -
Anyone having issues with Tubi? Trying to run this:
freevine.py get --season https://tubitv.com/tv-shows/501362/s01-e04-episode-4
But receive: 19:49:58.683 ←[4m←[31mERROR←[0m : URL did not match any supported service -
animal rescue school
https://tubitv.com/series/4603/animal-rescue-school
season 1 episode 4
orCode:freevine.py get -e s01e04 https://tubitv.com/series/4603/animal-rescue-school
Code:freevine.py get -e https://tubitv.com/tv-shows/501362/s01-e04-episode-4
Do i have something missing please ?
PS C:\freevine> python freevine.py --get https://www.channel5.com/show/finders-keepers/season-1/episode-2
File "C:\freevine\freevine.py", line 5, in <module>
from utils.commands import cli
File "C:\freevine\utils\commands.py", line 6, in <module>
import urllib3
ModuleNotFoundError: No module named 'urllib3'
PS C:\freevine> -
Did you install the requirements.txt? I had ChatGPT write an install guide as posted previously, maybe that will help you:
Code:Of course, Paul. I'll provide you with a guide for installing Git, cloning the repository, and setting up a Python virtual environment (venv) on Windows 11. ### Installing Git on Windows 11 1. **Download Git:** - Go to [Git Downloads](https://git-scm.com/downloads). - Click on the "Windows" link to download the installer. 2. **Install Git:** - Run the downloaded installer. - Follow the installation steps. Default settings are generally fine, but ensure "Git from the command line and also from 3rd-party software" is selected for PATH. - Complete the installation. 3. **Verify Installation:** - Open Command Prompt or Git Bash. - Type `git --version` and press Enter to confirm the installation. ### Cloning the Repository 1. **Open Command Prompt or Git Bash:** - Navigate to the folder where you want to clone the repository. 2. **Clone the Repository:** - Enter: ``` git clone https://github.com/stabbedbybrick/freevine.git ``` - This creates a "freevine" folder with the repository's contents. ### Setting Up a Python Virtual Environment 1. **Install Python:** - If not already installed, download Python from [python.org](https://www.python.org/downloads/windows/). - During installation, ensure that "Add Python to PATH" is checked. 2. **Verify Python Installation:** - In Command Prompt, type `python --version` and press Enter. 3. **Navigate to the Project Folder:** - In Command Prompt, navigate to the cloned "freevine" directory: ``` cd path\to\freevine ``` Replace `path\to\freevine` with the actual path to the folder. 4. **Create a Virtual Environment:** - In the "freevine" directory, run: ``` python -m venv venv ``` - This creates a virtual environment named "venv" in the project folder. 5. **Activate the Virtual Environment:** - To activate it, run: ``` venv\Scripts\activate ``` - Your command line should now indicate that you're inside the 'venv'. 6. **Install Required Packages (if any):** - If there's a `requirements.txt` file, install the required packages using: ``` pip install -r requirements.txt ``` 7. **Deactivate the Virtual Environment:** - When done, you can deactivate the virtual environment by typing `deactivate` in Command Prompt. By following these steps, the person you're helping should be able to install Git, clone the repository, and set up a Python virtual environment on Windows 11. Remember, the exact steps can vary slightly depending on the specific configurations and needs of the project. -
Hi All, since a day or so I get this message for CH4:
Proxy is set to basic in config and I have 1.1.5Code:Max retries exceeded with url: http://ak.dash01.stream.c4assets.com/wvmod-stream/CH4_33_05_42_75701006001001_002_HD.mpd?c3.ri=13503862342625625887 (Caused by ProxyError('Cannot connect to proxy.', NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f6f32d11a10>: Failed to establish a new connection: [Errno -2] Name or service not known'))) -
I'm not sure if this has been mentioned before, but for some reason Roku has some content that is not encrypted and causes Freevine to error out.
Code:freevine.py get --movie https://therokuchannel.roku.com/details/445229e2804657aebad6cafb63594965/monsters-ball
Another thing I noticed is that the filename does not reflect the actual resolution that was chosen. For example, using -sv worstCode:❯_freevine v1.1.5 03:20:34.512 INFO : The Roku Channel 03:20:34.766 INFO : Monster's Ball (2001) Traceback (most recent call last): File "C:\Freevine\freevine.py", line 15, in <module> cli() File "C:\Freevine\.venv\lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) File "C:\Freevine\.venv\lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) File "C:\Freevine\.venv\lib\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) File "C:\Freevine\.venv\lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) File "C:\Freevine\.venv\lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) File "C:\Freevine\utils\commands.py", line 90, in get Service(config, **kwargs) File "services\roku\roku.py", line 52, in __init__ self.get_options() File "services\roku\roku.py", line 262, in get_options self.download(download, title) File "services\roku\roku.py", line 267, in download lic_url, manifest = self.get_playlist(stream.id) File "services\roku\roku.py", line 159, in get_playlist lic_url = [ File "services\roku\roku.py", line 162, in <listcomp> if x["drmParams"]["keySystem"] == "Widevine" KeyError: 'drmParams'
Results in "Other.Peoples.Money.1991.1080p.ROKU.WEB-DL.AAC2.0.H.264.mkv" but the actual height is 216.Code:freevine.py get --movie https://therokuchannel.roku.com/details/5db3b92f00d6574baa73d7a7576abee2/other-peoples-money -sv worst
Good catch. I didn't know there was unencrypted content on Roku.
As for the resolution in filenames, using "-sv worst" kind of bypasses those checks and it assumes you've specified nothing, which automatically results in best available. Using "res=" or nothing will print the proper names. It's an oversight on my part, but I guess I never imagined anyone would intentionally want the worst so I didn't think to add it. -
https://www.channel4.com/programmes/car-sos
Having issues with this episode, comes up with some list error. Everything else on channel4 works fine. Perhaps bug? tried with --movie, -s11, anything i could think of but comes up with the same error. Anyone else manage to get it with freevine? -
Sometimes Roku will have 5.1 audio whereas the same title on Amazon is only 2.0 so I download the video as 'reference'. It's easy to count the offset frames between the two versions and determine the audio delay. I use -sv worst because it's the easiest option.
Thanks for the quick fix, just tested Roku with the same example.Last edited by Reel.Deal; 27th Jan 2024 at 13:46. Reason: Roku fix
Anyone please tell me what is wrong with this command ?
Just testing i have this complete
python freevine.py get --select-video res=720 --season https://www.bbc.co.uk/iplayer/episodes/m001vfg8/gladiators
❯_freevine v1.1.5
20:45:03.082 ←[4m←[31mERROR←[0m : URL did not match any supported service
PS C:\freevine>Last edited by PSXman_uk; 27th Jan 2024 at 15:46. Reason: wrong command line
I found another discrepancy, this time with Plex.
This particular movie does not have English subtitles, only Spanish. If I use -ds all it works or if I change the language in the hardcoded subtitle line in services\plex\api.yaml to https://vod.provider.plex.tv/library/streams/{id}-spa?format=vtt. However, with the second method, the subtitles do not have a language or title tag in the resulting mkv. This seems to be an issue even with English subtitles. If I download the video directly with N_m3u8DL-RE, the subtitles are correctly named.Code:freevine.py get --movie https://watch.plex.tv/movie/whos-your-caddy 15:45:10.422 INFO : Start downloading...Sub English 15:45:14.474 WARN : Response status code does not indicate success: 404 (Not Found). 15:45:16.962 INFO : Binary merging... 15:45:17.453 INFO : Decrypting... 15:45:29.042 INFO : Binary merging... 15:45:31.790 INFO : Decrypting... 15:45:47.579 ERROR: Download first segment failed!
UK Free to Air Downloader
By A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 656Last Post: 29th Oct 2025, 11:20 -
Video/Screenshot Guide to Freevine/N_m3u8DL-RE downloader for MacOS
By gwilliams1996 in forum Video Streaming DownloadingReplies: 16Last Post: 15th May 2024, 07:14 -
Forcing quality on streaming services
By qnufc in forum Video Streaming DownloadingReplies: 10Last Post: 8th Mar 2024, 18:27 -
Are we going to see all streaming services switching to L1 completely
By Loryanam2 in forum Video Streaming DownloadingReplies: 7Last Post: 5th Mar 2023, 08:37 -
Portable Streaming DownLoader for XMovies8?
By KermitJ in forum Video Streaming DownloadingReplies: 0Last Post: 27th Sep 2019, 11:44
