Hello everybody! I've been using StreamFab for quite a time now but I just can't download a subtitle whatsoever from mubi.com (through the DRM MPD module). I've read this thread : https://forum.videohelp.com/threads/401133-Dash-textstream-subtitles#post2651167
A mine of information I reckon. Unfortunately, it's double Dutch to me even though I tried to decipher it.
Would somebody be so kind as to share a step-by-step method for a true beginner like myself?
Thank you!
				Results 1 to 9 of 9
	I downloaded the program. What would be the next step?
 I tried with IDM and I got a list of MP4 and JSON files varying from 2 octets to 800 Ko. For the complain, I did a quick web search and found out that the issue had already been reported in a few threads. Nothing has been done since.Last edited by razdemar27; 31st Aug 2023 at 15:11.
	If you don't find a solution, you can try creating the subtitles yourself using Whisper AI. Subtitle Edit has this option in the Video menu but their default module is not that accurate.
 You can try installing other modules or use the standalone Whisper AI Command Line.
	Very simple question.
 1. Copy the URL of the mpd file. (mpd link)
 2. Run the command below:
 3. Select the subtitle stream(s) in the list you see.Code:N_m3u8DL-RE.exe "<mpd link>"
 Next time check the README.md before you ask because unlike e.g. how to get the keys to some videos, it's already written in the readme document on its GitHub repo.
	Thanks a lot CrymanChen. I got it! Last edited by razdemar27; 31st Aug 2023 at 13:17.
	It worked perfectly! Thanks again! Last edited by razdemar27; 31st Aug 2023 at 13:30.
  Best ITVX Downloader with SubtitlesBy A_n_g_e_l_a in forum Video Streaming DownloadingReplies: 216Last Post: 7th Nov 2023, 03:18
  Portable Windows Video DownLoader & SubTitles?By TEH in forum Video Streaming DownloadingReplies: 4Last Post: 21st Jul 2022, 12:41
  MUBI Multiple SubtitlesBy yarrak in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Mar 2022, 04:02
  4K-Video-Downloader and playlist subtitlesBy ChasVideo in forum Video Streaming DownloadingReplies: 0Last Post: 11th Sep 2020, 06:49
  Extract subtitles from mubi.comBy linuz in forum SubtitleReplies: 0Last Post: 9th Mar 2020, 15:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
