  1. Is there a way to remove the noise reduction that QTGMC does in the Hybrid program?
  2. Member Skiller's Avatar
    Oct 2013
    Germany
    Maybe try my combination of settings I posted here a while back. Keep in mind I use this for sources such as VHS and DV. It might not be good for use with HD resolutions (probably way too slow to begin with).
  3. So where in Hybrid do I put in the script?
  4. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    I often use something inspired to Skiller settings to retain "original" look and don't denoise too much:
    QTGMC(preset="slow", matchpreset="slow", matchpreset2="slow", sourcematch=3, tr1=2, tr2=1, NoiseTR=2, sharpness=0.1)
    I do not use Hybrid so I cannot help, but Selur will do it for sure once he reads.
  5. Keep in mind that the lossless modes in QTGMC reduce it's ability to smooth edges, resulting in more aliasing and buzzing edges.
    And settings that work well for one video may not work as well with others.
  6. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Sure. Always experiment a lot with own material
