Results 1 to 30 of 31
  1. delete
  2. i don't know what the certificate for base 64 is
  3. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    it's None
    import base64
    import requests
    import pyperclip
    from pywidevine.L3.cdm import cdm, deviceconfig
    from base64 import b64encode
    from pywidevine.L3.getPSSH import get_pssh
    from pywidevine.L3.decrypt.wvdecryptcustom import WvDecrypt
    def generate_pssh(kid: str):
        str1 = '000000387073736800000000edef8ba979d64acea3c827dcd51d21ed000000181210'
        str3 = '48e3dc959b06'
        return base64.b64encode(bytes.fromhex(str1 + kid + str3)).decode()
    def get_keys(pssh, lic_url,certificate_b64=None):
        wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=certificate_b64, device=deviceconfig.device_android_generic)
        widevine_license = requests.get(url=lic_url, headers=headers)
        license_b64 = b64encode(widevine_license.content)
        wvdecrypt.update_license(license_b64)
        Correct, keyswvdecrypt = wvdecrypt.start_process()
        if Correct:
            return keyswvdecrypt
        else:
            return None
    pssh = input('PSSH: ')
    lic_url = input('License URL: ')
    headers = {
        'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.1234.56 Safari/537.36',
        'Referer': 'https://www.jiocinema.com/',
    keys = get_keys(pssh, lic_url)
    if keys:
        print()
        for key in keys:
            print('--key ' + key)
        key_string = ' '.join([f"--key {key}" for key in keys])
        pyperclip.copy(key_string)
    else:
        print("\nFailed to retrieve keys from JioCinema API.")
    Also
    afaik a license request is always a POST and not GET so I think it should be
    widevine_license = requests.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=headers)
  4. thanks it works, btw in the headers i found out there are just two things 'x-playbackid' and 'unique id'. that seem to change for every video. How can i incorporate it in the code so i don't have to change it manually in the code before executing?
    thanks
  5. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    thanks
    I don't see them in the headers in your script you posted above.
    Post the script you have right now, so I'm not breaking anything else by making a change to your script
  6. Code:
    import base64
    import requests
    import pyperclip
    import subprocess
    def get_keys(pssh, lic_url, certificate_b64=None):
        if Correct:
        else:
            return None
    mpd_url = input('MPD URL: ')
    headers = {
        # Headers remain the same
        'User-Agent': 'Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:109.0) Gecko/20100101 Firefox/116.0',
        'Accept': '*/*',
        'Accept-Language': 'en-US,en;q=0.5',
        # 'Accept-Encoding': 'gzip, deflate, br',
        'accesstoken': 'eyJhbGciOiJFUzI1NiIsInR5cCI6IkpXVCJ9.eyJkYXRhIjp7InVzZXJJZCI6ImFjNGU1Y2E5LWY4YTYtNGU0Mi1iYjkxLWFiNjQzY2QxMTMxZSIsInVzZXJUeXBlIjoiR1VFU1QiLCJhcHBOYW1lIjoiUkpJTF9KaW9DaW5lbWEiLCJkZXZpY2VJZCI6IjI1MTcwMTM4MjUiLCJkZXZpY2VUeXBlIjoicGhvbmUiLCJvcyI6ImlvcyIsInByb2ZpbGVJZCI6IjBiMThjYWE3LTFmMWQtNDEwZi04NWJjLWIyNWJiNzg2Y2Q0MCIsImFkSWQiOiIyNTE3MDEzODI1In0sImV4cCI6MTY5MTQxNjg5OCwiaWF0IjoxNjkxNDA5Njk4fQ.MQFzyzkwhooJI617fpP7o-6zNkih9a9qlEE7f2kmgDzCqAcBfjiKCNb1GtGg3K_Cb3ROSg42czOYOeJIs4NUbQ',
        'appname': 'RJIL_JioCinema',
        'content-type': 'application/octet-stream',
        'deviceid': '2517013825',
        'devicetype': 'Web',
        'isdownload': 'false',
        'os': 'android',
        'uniqueid': 'ac4e5ca9-f8a6-4e42-bb91-ab643cd1131e',
        'versioncode': '560',
        'x-feature-code': 'ytvjywxwkn',
        'x-platform': 'Web',
        'x-playbackid': 'c13ba3aa-2c14-4d99-ba6f-2fd7d627dfcd',
        'Origin': 'https://www.jiocinema.com',
        'Connection': 'keep-alive',
        'Sec-Fetch-Dest': 'empty',
        'Sec-Fetch-Mode': 'cors',
        'Sec-Fetch-Site': 'cross-site',
        # Requests doesn't support trailers
        # 'TE': 'trailers',
    if keys:
        print("\nKeys generated:")
        for key in keys:
        # Convert keys to a comma-separated string
        keys_str = ':'.join(keys)
        # Construct the command with the MPD URL
        command = f"./N_m3u8DL-RE -M format=mp4 --key {keys_str} \"{mpd_url}\" --save-name ge.mp4"
        # Execute the command using subprocess
        try:
            subprocess.run(command, shell=True, check=True)
        except subprocess.CalledProcessError as e:
            print(f"Error occurred: {e}")
    else:
  7. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    import base64
    import requests
    import pyperclip
    import subprocess
        if Correct:
        else:
            return None
    x-playbackid = input('X-playbackid: ')
    uniqueid = input('UniqueID: ')
    headers = {
        'Accept': '*/*',
        'os': 'android',
        'uniqueid': uniqueid,
        'x-playbackid': x-playbackid,
        # 'TE': 'trailers',
    if keys:
        for key in keys:
        try:
    else:
  8. thank you, I was wondering instead of entering PSSH, can I extract PSSH from mpd url?
    thanks
  9. 'x_playbackid = input('X-playbackid: ')'
  10. x-playbackid = input('X-playbackid: ')
    SyntaxError: cannot assign to expression here. Maybe you meant '==' instead of '='?
  11. @swappyison
    accesstoken is needed and this module:
    pip install pyjwt
    with accesstoken working for a few hours
    since all important data comes from jwt, it might work for those who have a premium account..
    (don't have it so that just guess..)
    [Attachment 72989 - Click to enlarge]
    from pathlib import Path
    import subprocess
    import jwt
    import re
    access_token = '< accesstoken here >'
    print('\ntest link: https://www.jiocinema.com/movies/sergeant-bhojpuri/3767689\ntest link: https://www.jiocinema.com/tv-shows/kaalkoot/1/janam-din/3788001\n')
    link = input('link: ')
    link_id = re.findall(r'.*/(.*)', link)[0].strip()
    m3u8DL_RE = 'N_m3u8DL-RE.exe'
    def replace_invalid_chars(title: str) -> str:
        invalid_chars = {'<': '\u02c2', '>': '\u02c3',
        ':': '\u02d0', '"': '\u02ba', '/': '\u2044',
        '\\': '\u29f9', '|': '\u01c0', '?': '\u0294',
        '*': '\u2217'}
        return ''.join(invalid_chars.get(c, c) for c in title)
    decoded = jwt.decode(access_token, options={"verify_signature": False})
    #print(f'\n{decoded}\n')
    deviceId = decoded['data']['deviceId']
    uniqueid = decoded['data']['userId']
    appName = decoded['data']['appName']
    import requests
    from requests.packages.urllib3.exceptions import InsecureRequestWarning
    requests.packages.urllib3.disable_warnings(InsecureRequestWarning)
    headers2 = {
        'authority': 'apis-jiovoot.voot.com',
        'accept': 'application/json, text/plain, */*',
        'accesstoken': access_token,
        'appname': appName,
        'content-type': 'application/json',
        'deviceid': deviceId,
        'origin': 'https://www.jiocinema.com',
        'referer': 'https://www.jiocinema.com/',
        'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36',
        'x-platform': 'androidweb',
        'x-platform-token': 'web',
    json_data2 = {
        '4k': False,
        'ageGroup': '18+',
        'appVersion': '3.4.0',
        'bitrateProfile': 'xhdpi',
        'capability': {
            'drmCapability': {
                'aesSupport': 'yes',
                'fairPlayDrmSupport': 'yes',
                'playreadyDrmSupport': 'none',
                'widevineDRMSupport': 'yes',
            'frameRateCapability': [
                    'frameRateSupport': '30fps',
                    'videoQuality': '1440p',
        'continueWatchingRequired': True,
        'dolby': False,
        'downloadRequest': False,
        'hevc': False,
        'kidsSafe': False,
        'manufacturer': 'Windows',
        'model': 'Windows',
        'multiAudioRequired': True,
        'osVersion': '10',
        'parentalPinValid': True,
    response2 = requests.post('https://apis-jiovoot.voot.com/playbackjv/v4/'+link_id+'', headers=headers2, json=json_data2, verify=False).json()
    contentType = response2['data']['contentType']
    if contentType == 'MOVIE':
        movie_name = response2['data']['name']
        title = f'{movie_name}'
    elif contentType == 'EPISODE':
        showName = response2['data']['show']['name']
        season_num = int(response2['data']['episode']['season'])
        episode_num = int(response2['data']['episode']['episodeNo'])
        episode_title = response2['data']['fullTitle']
        title = f'{showName} - S{season_num:02d}E{episode_num:02d} - {episode_title}'
    else:
    title = replace_invalid_chars(title)
    print(f'\n{title}\n')
    mpd = response2['data']['playbackUrls'][0]['url']
    lic_url = response2['data']['playbackUrls'][0]['licenseurl']
    try:
        import requests
        headers03 = {
            'Accept': 'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9',
            'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36',
        response03 = requests.get(mpd, headers=headers03, verify=False).text
        pssh = re.findall(r'<cenc:pssh>(.{20,170})</cenc:pssh>', response03)[0].strip()
        print(f'{pssh}\n')
        import base64, requests, sys, xmltodict, json
        import time
        import re
        headers = {
            'authority': 'prod.media.jio.com',
            'appname': appName,
            'os': 'android',
            'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.0.0 Safari/537.36',
            'versioncode': '570',
            'x-playbackid': uniqueid,
        def WV_Function(pssh, lic_url, cert_b64=None):
            wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_b64, device=deviceconfig.device_android_generic)
            widevine_license = requests.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=headers, verify=False)
            if Correct:
                return Correct, keyswvdecrypt
        Correct, keys = WV_Function(pssh, lic_url)
        for key in keys:
        ke_ys = ' '.join([f'--key {key}' for key in keys]).split()
        print()
        subprocess.run([m3u8DL_RE,
                        '-M', 'format=mkv:muxer=ffmpeg',
                        '--concurrent-download',
                        '--log-level', 'INFO',
                        '--save-name', 'video', mpd, *ke_ys])
    except IndexError: #DRM free
        print()
                        '--save-name', 'video', mpd])
    try:
        Path('video.mkv').rename(''+title+'.mkv')
        print(f'{title}.mkv \nall done!\n')
    except FileNotFoundError:
        print("[ERROR] no mkv file")
    Last edited by sk8ordi3; 24th Aug 2023 at 12:58. Reason: script updated.. (handle both lic url type)
  12. delete
  13. delete
  14. Originally Posted by swappyison View Post
    hi i am trying to use a similar code for a website that has no playbackid, has an api like this https://gwapi.zee5.com/content/tvshow/0-6-199?translation=en&country=IN , and response headers that include nl and sdrm. like this url: https://www.zee5.com/tv-shows/details/bhabi-ji-ghar-par-hai/0-6-199/maryada-threatens-.../0-1-6z5403446
    could you please help?
    this content is not drm protected:
    show you an url is drm protected and free..
  15. than use hls and not widevine
    (if you fast maybe you can still play in vlc)
    https://zee5vodnd.akamaized.net/hls1/elemental/hls/TV_SHOWS/AND_TV/August2023/04082023/Episode/BQC_CS_Bhabi_Ji_Ghar_Par_Hai_Ep2129_Episode_04082023_hi_fdf0e55f58421769bf5d67a1e2418a30/index-phone.m3u8?hdnea=st=1691481560~exp=1691485280~acl=/hls1/elemental/hls/TV_SHOWS/AND_TV/August2023/04082023/Episode/BQC_CS_Bhabi_Ji_Ghar_Par_Hai_Ep2129_Episode_04082023_hi_fdf0e55f58421769bf5d67a1e2418a30/index-phone.m3u8*~hmac=d5b521e9024dfc3611930401e2ac17002a98f5ca03712697970194ca4fe39194
  16. thanks
    Jul 2023
    India
    Originally Posted by sk8ordi3 View Post
    @swappyison
    pip install pyjwt
    import subprocess
    import jwt
    import re
        '*': '\u2217'}
    import requests
    headers2 = {
        'appname': appName,
    json_data2 = {
        '4k': False,
        'ageGroup': '18+',
        'capability': {
            'drmCapability': {
        'dolby': False,
        'hevc': False,
        'kidsSafe': False,
        'model': 'Windows',
        'osVersion': '10',
    #print(f'\n{response2}\n')
    else:
    #print(f'\n{mpd}\n')
    #print(f'\n{lic_url}\n')
    try:
        import requests
        headers03 = {
        print(f'{pssh}\n')
        import time
        import re
        headers = {
            'authority': 'key-jiocinema.voot.com',
            'appname': appName,
            'os': 'android',
            if Correct:
        for key in keys:
        print()
        print()
    try:
    what to enter in access token ???
  18. Member
    Oct 2022
    Behind You
    The access token.
    I help all that ask.
  19. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    The access token.
    [Attachment 73128 - Click to enlarge]
    Genius!
    Jul 2023
    India
    The access token.
    thanks bro i meant where to find it but no problem i found out myself. btw u r a genius
  21. @sk8ordi3, bro jiocinema has basically two different license urls for DRM videos:
    1.) starting from key-jiocinema, like this: https://key-jiocinema.voot.com/keydelivery/v2/widevine?lt=exp=1692868783~st=1692867883...f0b1e893726fe7
    2) starting from prod.media-proxy, like this:https://prod.media.jio.com/proxy?video_id=2000536858
    currently script is working for the second license url type only
  22. show both types plain video url, because putting two license url's in there is useless...
    so this is the proxy one:
    https://www.jiocinema.com/tv-shows/mangala-gowri-maduve/1/rajeev-searches-for-his-baby/3537388
    what is the other video url?
  23. no i meant some videos have license url of one kind (like key-jiocinema) and others have of other kind(like proxy one).
  24. Originally Posted by swappyison View Post
    I do not understand..
    show me the video url that doesn't work with the script...
  25. got it
    script updated
    (now handle both lic url type)
  26. @sk8ordi3
    Is there a way to automate updating access token instead of manual input?
  27. Member lottery's Avatar
    Jan 2019
    how to get new accesstoken from jiocinema
