Hello
does anyone know of a professional box that can be added to my home TV system to capture / record HDMI 2.0 sources up to 4K
is there such a box and does it capture and remove and protection so I can store TV recordings from various HDM sources BluRays etc.
Thanks for any info
Take a look at this
https://forum.videohelp.com/threads/410389-Alternative-to-Hauppauge#post2698405 -
There is no stand-alone professional box or professional HDMI capture device capable of recording these sources due to the HDCP copy protection applied to their HDMI output. You would need an HDMI splitter that removes HDCP as a side effect to use such gear. Unfortunately I don't know of any that are currently available.
It is easier to rip Blu-ray and UHD Blu-ray using a Windows PC equiped with a suitable optical drive than it is to record the output from a player.Ignore list: hello_hello, tried, TechLord, Snoopy329
PCI capture card not showing in various capture software (GV-MVP/GXW)
By ThaKarra in forum Capturing and VCRReplies: 5Last Post: 24th May 2023, 14:41 -
AJA LHe Plus Capture card options for VHS capture ?
By acusman in forum Capturing and VCRReplies: 3Last Post: 3rd Feb 2023, 15:21 -
Using Canon's EOS Utility to capture on screen video VS a capture card
By RoyZ7 in forum Capturing and VCRReplies: 0Last Post: 23rd Apr 2020, 07:18 -
Out of touch with video capture - USB capture device advice
By Lambchop in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2018, 04:19 -
VHS PAL Capture - Very minor pink noise appearing on sports capture
By Robertp in forum RestorationReplies: 12Last Post: 9th Nov 2018, 19:50
