Results 1 to 9 of 9
    Aug 2018
    Wrocław
    How to avoid effects like in the screenshot when using QTGMC?
    Right side - QTGMC
    Left side = bwdif
    Script:
    QTGMC(preset="slow",TR2=3, Sharpness=1.2, SLMode=1)
    (removing Sharpness and SLMode improves the thing, but I would not like to give up sharpening)
    (full screenshot attached)
  2. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Use QTGMC as deinterlacer "only", and sharpen later with a dedicated filter (general good approach)
  3. ^^^ This
    Or try an antialias filter like santiag()
    Also take a look at the discussion here:
    https://forum.videohelp.com/threads/404164-Why-is-QTGMC-so-destructive-and-why-do-so-m...l-recommend-it
    Aug 2018
    Wrocław
    Which would you recommend? ASharp didn't work for me.
  5. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    LSFmod(defaults="slow")
    As alternative, according to the characteristics of your source: SeeSaw() http://avisynth.nl/index.php/SeeSaw, CAS() http://avisynth.nl/index.php/CAS
    Aug 2018
    Wrocław
    Thanks. It's a bit weak that LFSmod and SeeSaw only accept YUV420...
  7. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Yes, the conversion to YV12() is sort of degradation sometime. Didée disappeared long time ago before improving his scripts .
    In any case, if you are deinterlacing your source and you want to sharpen only luma (which happens quite often) is not a big issue, because you can recover the chroma from a step prior to sharpening (and then to YV12() conversion):
    # deinterlacing
    deinterlaced=...
    ### convert to YV12
    deinterlaced_yv12=deinterlaced.convertToYV12()
    ### sharpening
    sharpened_yv12=deinterlaced_yv12.LSFmod(defaults="slow")
    ### convert to YUY2 with chroma from YUY2 color space
    sharpened=sharpened_yv12.convertToYUY2().MergeChroma(deinterlaced)
    Last edited by lollo; 22nd Nov 2023 at 11:12. Reason: fixed typo "you want to sharpen only chroma" to "you want to sharpen only luma"
  8. It's a bit weak that LFSmod and SeeSaw only accept YUV420...
    LSFmod works fine with other yuvxxx color spaces, iirc. the restriction to YV12 was only because older masktools2 versions didn't support other color spaces.
    Using:
    ClearAutoloadDirs()
    SetFilterMTMode("DEFAULT_MT_MODE", MT_MULTI_INSTANCE)
    LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\LoadDll.dll")
    LoadDLL("F:\Hybrid\64bit\Avisynth\avisynthPlugins\libfftw3f-3.dll")
    LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\LSMASHSource.dll")
    LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\masktools2.dll")
    LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\VariableBlur.dll")
    LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\aWarpSharpMT.dll")
    LoadPlugin("F:\Hybrid\64bit\Avisynth\avisynthPlugins\RgTools.dll")
    Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\mtmodes.avsi")
    Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\Zs_RF_Shared.avsi")
    Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\ExTools.avsi")
    Import("F:\Hybrid\64bit\Avisynth\avisynthPlugins\LSFmod.avsi")
    # loading source: G:\TestClips&Co\files\test.avi
    # color sampling YV12@8, matrix: bt601, scantyp: progressive, luminance scale: limited
    LWLibavVideoSource("G:\TestClips&Co\files\test.avi",cache=false,dr=true,format="YUV420P8", prefer_hw=0)
    ConvertToYUV444()
    # current resolution: 640x352
    LSFmod(edgemaskHQ=true)
    ConvertToYUV422()
    ConvertToYUV420()
    # Converting from 8 to 10bit for encoder
    ConvertBits(10)
    # setting output fps to 25.000fps
    AssumeFPS(25,1)
    PreFetch(16)
    #  output: color sampling YV12@10, matrix: bt601, scantyp: progressive, luminance scale: limited
    return last
    (4:2:0, 4:2:2, 4:4:4) works fine here. (script doesn't make any sense, I just wanted to test the color compatibility; I suspect the same might be true for SeeSaw)
    Cu Selur
  9. And for seesaw - there are modified versions that accept high bit depth and other subsampling by realfinder and dogway
    https://github.com/realfinder/AVS-Stuff/blob/master/avs%202.5%20and%20up/seesaw.avsi
    https://github.com/Dogway/Avisynth-Scripts/blob/master/MIX%20mods/SharpenersPack.avsi
    Was there motion in adjacent fields ? One scenario where BWDIF excels over other deinterlacers is weaving static content
