  1. Hi
    how can i re encode the audio stream from a video from 6ch to 2ch?
    Mar 2008
    Read through this thread (post #28 specifically):
    https://forum.videohelp.com/threads/369941-Quiet-sound-on-youtube
  3. Originally Posted by khaled22 View Post
    Hi
    You need perform operation called 'downmixing'
    https://trac.ffmpeg.org/wiki/AudioChannelManipulation#a5.1stereo
    or
    custom downmixing
    -af "pan=stereo|FL < FL+1.414FC+0.5BL+0.5SL+0.25LFE|FR < FR+1.414FC+0.5BR+0.5SR+0.25LFE"
  4. Originally Posted by khaled22 View Post
    Hi
    Use clever Ffmpeg-GUI.
    Load your video, click main, click encode audiostream, select your 6ch audio stream, click go to the encoder, select the codec and the 5.1 to 2 channels, click the D-mix options button and select one of 4 formulas, click ok and click encode.
    If finished, click multiplex, select the new created 2ch audiostream (in green), the videostream and other streams you want and click multiplex.
    Done.
  5. thank you all for your replies..ill check them out..managed to do it also by using "pan=stereo|c0=FL|c1=FR"
  6. Originally Posted by khaled22 View Post
    This means you are loosing audio from other channels - for example if something was only in FC (like dialogue) then it will be not present in your stereo - proper downmixing trying to preserve audio from all channels in stereo.
