Results 1 to 17 of 17
  1. Video files out of my Sony camera with .mts extension (i believe is MKV format?) when loaded to VirtualDub2 have a lot of frames corrupted. If i convert them to mp4 container (no re-encoding) with AviDemux then they open just fine, not a single corrupted frame.
    What can be causing this? Inside original VirtualDub with VirtualdubFFMpegPlugin .mts files have no lag, but playback is sluggish.
    Video source file https://www.upload.ee/files/15281379/00017.zip.html
  2. .mts or .m2ts are container formats for Mpeg transport streams. Typical for videocams and blu-ray discs.
    VirtualDub2 shows corrupted frames until it hits the next keyframe (a matter of the decoder). In your case keyframes (I-frames) are found every 24 frames (24, 48, 72 etc.) in the videostream.
    May 2005
    PAL User
    That source file you posted is already an MP4 (AVC/H264 codec). Can you post up the original MTS file?
    I've got an M2TS file here that is AVC (ie H264). Conceivably, your MTS file is also AVC, as indicated by your "no-recoding" comment (all AVIDemux was doing was changing the container, not the actual video codec). Hence, it could be that VDub just can't handle the "MTS" part of it/container.
    You can analyse the guts of a file using Mediainfo. It will tell you what the underlying codec is. Afte you open the file in Mediainfo, go to the "Tree" view.
  4. Originally Posted by Alwyn View Post
    My bad here is .MTS file straight from camera. https://www.upload.ee/files/15288487/mts.zip.html
    From what i understand decoder MP4 in VirtualDub2 is located in file called avlib-1.vdplugin, perhaps i can try alternative decoder, what are the ones available to allow importing MP4 files?
    I have used FFMpeg Input Plugin 2.0 for original VirtualDub, but its sluggish pressing play button, are there others?
  5. Originally Posted by VidNoob123 View Post
    The problem with garbled frames for random seeking with VirtualDub2 is for .mts or .m2ts container mainly. For .mp4 I don't get any problems here, except perhaps for the first few frames. Maybe because my files files were using the mp4 option 'faststart'.
    May 2005
    PAL User
    The underlying codec of the MTS is AVC (or H264). I changed the container to MP4 with AVIDemux (Copy, Copy, Muxer>MP4) and it plays more smoothly in VDub 2 than the MTS file with no grey frames scrubbing back and forth along the timeline.
    Unfortunately, AVIDemux doesn't have a batch function.
  7. You can convert to .mp4 container like
    ffmpeg.exe -i "%~1" -c:v copy -c:a copy "%~1_.mp4"
    Save this line as a .bat or .cmd text file, put it as an icon onto your desktop and drag and drop your .mts onto that icon.
    Or for batch processing:
    @echo off
    :next
    if "%~1"=="" goto done
    shift
    goto next
    :done
    Drag and drop your many .mts onto that icon.
    May 2005
    PAL User
    Good one Sharc.
    Oops. There's a flash and then nothing. Where would the MP4 end up?
  9. Same folder as the source, unless you would specify the destination path explicitly.
    Add pause at the end of the script to see any error messages.
    If ffmpeg is not in the system path you may have to specify the full path to the ffmpeg.exe
    May 2005
    PAL User
    That worked. Thanks.
  11. Originally Posted by Alwyn View Post
    Actually it does two ways to batch, i already adopted the easier one for converting all my MTS to MP4 yesterday. Used windows .bat file
    @echo off
    set "imageFolderPath=%~dp1"
    mkdir "%imageFolderPath%\MP4"
    for %%F in ("%imageFolderPath%*.mts") do "C:\Program Files\Avidemux 2.8 VC++ 64bits\avidemux_cli.exe" --video-codec "copy" --audio-codec "copy" --output-format "MP4" --load "%%F" --save "%%~pF\MP4\%%~nF.mp4" --quit
    My concern however was if its possible to use another MP4 plugin for VirtualDub to open MTS without bug.
  12. Originally Posted by VidNoob123 View Post
    An alternative method is the directshow input driver. So if you have a decoder such as lav filters installed it will use that
    There is a x64 version of the driver here
    http://www.virtualdub.org/beta/DShowInputDriver-0.93.zip
    Beware, sometimes directshow can be buggy . It's like a last resort
    Aug 2018
    Wrocław
    I had the same problem with my mts.
    The error is only in the preview when you jump between keyframes, when converting it will be ok.
    Use Cache Input Driver (you're probably using ffmpeg Input Driver).
    No need to convert.
  14. Originally Posted by rgr View Post
    Could you elaborate on that, i am not that good with this things, how i switch input diver in VirtualDub2?
    P.S. I had this corrupted frames show in the MP4 videos i exported from VDub as well.
    Aug 2018
    Wrocław
    Link:
  16. Originally Posted by rgr View Post
    Link:
    Did not have ffmpeg plugin installed for VirtualDub2 so it was corrupted on Caching input driver.
    Could you try my video in post #4 and see if you get corruption?
    Aug 2018
    Wrocław
    Link:
    I think I made a mistake With "Cache input driver" it is as you describe, with "ffmpeg input driver" everything is ok.
    But rendering to x264 even with "Cache input driver" is ok, frames are distorted only in preview.
