I have a hard coded subtitle from TS sourceformate encoded to MKV simply done in Handbrake. Is there a way to encode that TS container without what appears to be the burned in subtitle?
Results 1 to 13 of 13
The snip below shows some detail I found that is relevant.
Yes there were origianl SRT subs for the lauguages shown. But they will not display properly since they overlay
the imbedded English subtitle. From the notes shown, that must be the DVB . Since there is an English SRT as well the goal is to
remove the embedded English sub from the media.
I'll see if I can copy in the whole MediaInfo.
Files..........: Wozzeck
Size...........: 14.2 GiB
Container......: ts
Resolution.....: 1920 x 1080 interlaced TFF
Codec..........: AVC @ 17 Mbps
Format.profile.: High @ L4.0
Audio.Codec....: AC3 5.1 chs @ 448 kbps
Frame Rate.....: 25 fps
Language.......: German
Subtitles......: Eng, Fre, Ger, Pol, Rus, Spa & Swe
Sub.Format.....: DVB Subpictures & SRT
Runtime........: 1:53:20
from original TS file
General
Complete name : C:\**********WOZZECK Metopera 01.11.2020*************.ts
Format : MPEG-TS
File size : 14.2 GiB
Duration : 1 h 53 min
Overall bit rate : 18.0 Mb/s
Frame rate : 25.000 FPS
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 3 frames
Codec ID : 27
Bit rate mode : Constant
Bit rate : 17.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.328
Stream size : 13.2 GiB (93%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : 6
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : 1 ms
Stream size : 363 MiB (2%)
Language : English
Service kind : Complete Main
Text #1
Menu ID : 1 (0x1)
Format : DVB Subtitle
Codec ID : 6
Delay relative to video : 17 s 838 ms
Language : English
Text #2
Menu ID : 1 (0x1)
Codec ID : 6
Delay relative to video : 17 s 858 ms
Language : German
Text #3
Menu ID : 1 (0x1)
Codec ID : 6
Language : French
Text #4
Menu ID : 1 (0x1)
Codec ID : 6
Language : Spanish
Text #5
Menu ID : 1 (0x1)
Codec ID : 6
Language : Russian
Text #6
Menu ID : 1 (0x1)
Codec ID : 6
Language : Swedish -
Won't work since the video's burned in subs are permanent and that setting just stops the subs being burned in again.
It could be I have misstated the exact problem. But in a brief spot inspection of the content of the recode from TS to M4V, the sub seen earlier is no longer there. Now I just have to confirm that the EN sub and other languages from the SRT group lines up with the play etc.
If you still have the original TS file just drop it into mkvtoolnix and untick stuff you don't need and add in any extra tracks you need. Then hit multiplex. You will have a mkv file in minutes. If you want you could then extract the srt sub using Inviska MKV Extract or similar to have a standalone srt file.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
That was one of the first things I tried. Nothing showed up. Nor did anything show up in the related tool for 'Nix called Inviska
which I use regularly to prepare SRTs from .. can't think of the acronym.. what Subtitle Edit converts with Tesseract. It'll come to me after I close this.
The only thing that showed anything for subs was that load of Handbrake so I unchecked the only "burn in" box it showed and
that has seemed to remove the embedded sub format. Indeed it might have been something I did, there's always that possibility. I have to do some checks on it to load all the subs again. -
If you don't have it get hold of TSDoctor it will show everything. The trial version is fully operational for 30 days the last time I looked.
By the way. I wish that performance of Alban Berg's Wozzeck had been released in Sydney! Just did a bit of digging and found that it was a co-production of the Metropolitan Opera; Salzburg Festival; the Canadian Opera Company, Toronto; and Opera Australia Must check again.
I have installed TSDoctor and I know there's a tutorial. The feature I wanted to use I couldn't locate. I guess I'm poor at reading software layout. None of it makes any sense but I did get the player to work.
In the TS file load I see a subtitle I want to extract. If you can give the steps for that it would be a start. All I did was drag and drop the TS into TSDoctor. It seems to have a lot of features I don't know how to unlock. -
Hello again,
Yes I got TS Doctor on your previous note. Please give instructions on how to do the extraction. I can load the program well enough and see the various subtitles on it's screen. Clicking on doesn't seem to activate anything. It'll take me a while to do a screen shot. I haven't loaded the program for a while.
Tool to locate and OCR hard-coded subtitles in MKV/MP4 Files?
By EmmB in forum SubtitleReplies: 1Last Post: 6th May 2022, 18:10 -
extracting hard coded subtitles to a srt format using videosubfinder
By jraju in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2022, 07:24 -
How to remove hard coded subtitles ? HELP PLEASE
By TIMETHIEF in forum SubtitleReplies: 28Last Post: 2nd Jul 2020, 10:24 -
hard subtitle keep source features
By ghazalo in forum Newbie / General discussionsReplies: 21Last Post: 24th May 2019, 13:15 -
How to Hard-code subtitle using FFmpeg on Mac OS ?
By Anuragvani in forum MacReplies: 1Last Post: 28th Jun 2018, 08:01
