Results 1 to 15 of 15
    Jan 2023
    Lithuanian
    Hi,
    Local ISP tv.telia.lt change DRM server and now i have problem.
    From licence server always response:
    {"DrmErr": "code": "11", "desc": "Device and Portal Id Mismatch"}}
    Licence request Payload (send with base64):
    {"LatensRegistration":{"CustomerName":"Telia TV PROD","AccountName":"330041","PortalId":"0d3e2135-4f0c-4aa0-a500-2fc20b2d23c8"},"Payload":"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"}
    Maybe I don't know something?
    I found information that yelo.telenet.tv uses the same widevine server, maybe someone knows about it?
  2. edit your script and send the request with payload in json format.
    if you just afew keys, send me login and the video url.
    Jan 2023
    Lithuanian
    @andrewzhong
    JSON invalid request, then the server: "The license request is malformed". Chrome send base64 info
  4. if you just want the keys. pm me the login and video url. i grab for u.
    Jan 2023
    Lithuanian
    I'm trying to figure out what I'm doing wrong, if you can help, thanks.
  6. they match the portal id to the cdm device - so in your case, you are using a web portal id with an android cdm device - which is why it doesnt work.
    you need the portal id from the android app.
    Jan 2023
    Lithuanian
    Thanks for the info, I'll try with android
  8. Originally Posted by slaptasBotas View Post
    @slaptasBotas, any luck?
    @ElCap, do you happen to know if it has to be the portal id of the Android device CDM files were acquired from or can it be any Android device? I captured the portal ID from the payload sent via Chrome app on my Android phone but it still returns the same error (perhaps because CDM files I use were acquired from another device?..).
    Jan 2023
    Lithuanian
    @joasis, yes it has same... My mistake was that the CDM was from the old device, and the VOD info was from another. I'm from the emulator CDM now, I took the info from the VOD App and it works so far.
  10. Interesting to me. Would this possibly also work if you use just user-agent switcher in the browser set to android?
  11. Originally Posted by joasis View Post
    i dont know this site specifically, but when i encountered it before the portal id needed to be retrieved from the android app.
    it sounds like slaptasBotas has it working from the same device as the cdm was extracted from so id try that first.
  12. I appreciate all the answers. I tested and it has to be the portal id retrieved with the save device that CDM files were dumped from. This can be achieved by using the Android Studio method, as described in this thread. User agent has no effect on the outcome.
    By the way, in this particular case (tv.telia.lt), the provider blocked Widevine (WvLicenseProxy) requests from Android Studio emulator and I was not able to peak at the encoded payload that contains the portal id. However, requests to tv.telia.lt/api/settings/settings?display2SymbolsLangCodes=false were made and the response contained shakaPduid, which is the same as the portal id. Use remote debugging to access DevTools of Android version of Chrome.
  13. Originally Posted by joasis View Post
    it has to be the portal id retrieved from the save device that CDM files were dumped from.
    I see. Thanks!
  14. who can help with request in base64?
  15. Originally Posted by andrewzhong View Post
    Hi, I'd like to get a key to a video protected by drm. Could you help me?
    I'll send you an pm
