Results 91 to 120 of 210
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Thanks 2nHxWW6GkN1l916N3ayz8HQoi for the reply
Just tested key posted by you and it's working
for my own learning purpose, May I know what I was doing wrong there?
You did some changes in that decrypt function or used different script?Last edited by LittleSoldier; 4th May 2024 at 06:56.
I didn't bother with any existing scripts. I just read their js code and took what I needed directly from the page source. I won't bother going into detail since one of the site's devs is lurking around and making changes everytime a solution is found lmao. That's why you see so many scripts that don't work anymore. I think it's silly to even try to play this game.
hlsdl -b -K 2AAC616013F1877619AF8AC01ABFF0A6 https://dnqe0v482iyb1.cloudfront.net/spees/w/o/6197321b0cf23d7cc6e572e1/v/6337f80fe4b0...d5a/index.m3u8
> START media_playlist_get_links
> END media_playlist_get_links
HLS Stream is AES-128 encrypted.
{"d_t":"vod"}
{"t_d":794,"d_d":0, "d_s":0}
Downloading part 0
Downloading part 0
PMT wrong table id: 0x42
{"t_d":794,"d_d":2,"d_s":93248}
Downloading part 1
Downloading part 1
{"t_d":794,"d_d":4,"d_s":154348}
Downloading part 2
Yes, Every time dev come up with something new, so all previous working scripts gets broken.
Do you mind if I PM you related to a python code?
LZAA are you using existing posted script in this thread or got a key using your own script? -
For a particular site, the substring values (e.g. f = a(o(g), h(window.apkId.substring(16, 48)) are changing every time page is refreshed no matter how quickly I do it. Is it supposed happen like this?
Until a few days ago, I was able to decrypt the video using the script, but now its not possible. I will provide the apkId and the m3u8 link, can someone check from their end and let me know if its getting decrypted? -
https://dnqe0v482iyb1.cloudfront.net/spees/w/o/60e975430cf20278db21ff30/v/66045190cde6...67f/index.m3u8
66306566663065666230666531316265326537366230666531 31626532653736
Thanks, let me know if anything else is needed. -
Originally Posted by hoxabe5434
Here you go : https://www.goclasses.in/s/courses/65e16b97e4b0650d691ca473/take -
./N_m3u8DL-RE.exe "https://dnqe0v482iyb1.cloudfront.net/spees/w/o/60e975430cf20278db21ff30/v/66045190cde69650931cf67f/u/665053bea49b3a429449fab2/t/12c8277efffd03c1aeb70c7a10781859/p/assets/videos/60e975430cf20278db21ff30/2024/03/27/66045190cde69650931cf67f/index.m3u8" --save-name "Recording - Lecture 5 - Four Fundamentals Subspaces" --custom-hls-key 0a3a2cf94abec0891622afd929805e78 -mt -M mp4 -sv best -sa best
Yes Please. Also, if you can guide me on how you are tackling the substring changes on page refresh, that would be really helpful.
(By the time the decrypt function executes, the substring values already change and it throws 'ERROR: Padding is invalid and cannot be removed.')
Thanks. -
Isn't this one outdated?
I had the script posted in the current thread working until recently before I believe the site devs set the period for substring value changes to very low (may be every second or so). Th same script works on the other sites that were posted here before (e.g. futurly.com) as those dont change the substring values nearly as often (maybe once a day or so).
So for example, if its using 0:32 this moment, on next page refresh (even if done within 2-3 seconds) it might use :9+41: and so on.
How do I tackle this issue? (Someone I know has a workaround, but is asking money for giving out the solution. So I didnt bother asking him again :P)
I am not sure if I am clearly passing on the message here, its quite hard on explain in plain text :/ -
Ohh, is it? TBH, I dont understand the previous method completely. Could you please guide on how to download the videos from the website I that shared earlier using that method? Thanks a ton.
howto deal with HLS 128 bit aes encrypted - the hard one
By code47 in forum Video Streaming DownloadingReplies: 63Last Post: 28th Dec 2023, 08:45 -
How do I download AES encrypted video streamed over HLS?
By Videogamer555 in forum Video Streaming DownloadingReplies: 1Last Post: 20th Jul 2022, 08:03 -
Help downloading AES-encrypted HLS video stream
By Woodswolf in forum Video Streaming DownloadingReplies: 26Last Post: 25th May 2019, 14:20 -
Help me with AES encrypted HLS downloading ?
By shraman in forum Video Streaming DownloadingReplies: 0Last Post: 30th Jul 2018, 06:54 -
By vidder in forum Video Streaming DownloadingReplies: 3Last Post: 4th Jul 2018, 17:24
