Folks, just now I was trying to download the movies from Stan (stan.com.au)
But after gettting the key, I found out that the highest resolution is 540p
Already got the highest subscription plan (HD and 4K)
and already switched the resolution to "High" in the video player webpage.
[Attachment 68576 - Click to enlarge]
↑ all available streams in the mpd file.
Any chance to get 1080p manually, rather than relying on the downloader like streamfab etc.?
Results 1 to 16 of 16
[Attachment 68577 - Click to enlarge]
Switched to the "High" resolution -
On their help center, HD means that you are probably in a basic plan.
But I had the most expensive one, not the basic one.
[Attachment 68578 - Click to enlarge] -
As far as I remember, they use 4K, 1080p streams only for their SmartTV, AndroidTV applications. It's possible that if you follow API requests you can also access those streams.
It is just like Netflix, Prime and others...
Computers are able to get 720p contents at most, those are L3-protected. In your web browser, there is a L3-content-decryption-module.
4K contents are L1 or/and PlayReady protected (Very very few 4K-L3 examples out there)
To get 4K streams, you need a special device with a L1-content-decryption-module integrated to the device's system-on-chip (a set-top-box or a TV). It is not related to Android, it is related to the system-on-chip. It is a hardware-based issue.
Or... You need a Intel GPU with PlayReady 3.0 module integrated (Intel 7th Gen or later). Then you must connect your computer to a HDR monitor. You must not use any browsers, including Edge. You must only use Windows applications for Netflix, Prime, Disney, etc. Otherwise, you won't reach any 4K-HDR contents. -
You need to generate a token from a Nvidia Shield. Windows token is limited to 540p
and then use somthing like
headers = {
'Content-Type': 'application/x-www-form-urlencoded',
'Host': 'api.stan.com.au',
'Connection': 'Keep-Alive',
'Accept-Encoding': 'gzip',
'User-Agent': 'Dalvik/2.1.0 (Linux; U; Android 9; SHIELD Android TV Build/PPR1.180610.011)',
res = requests.get(
url='https://api.stan.com.au/concurrency/v1/streams?jwToken={}&programId={}&stanName=Stan-AndroidTV&quality=ultra&format=dash'.format(token, video_id),
params={
"jwToken": token,
"format": "json",
"capabilities.drm": "widevine",
"videoCodec": 'h265'
data = res.json()
keyId = data['media']['drm']['keyId']
license_token = data['media']['drm']['customData']
mpdurl = data['media']['videoUrl'].split('?')[0]
license_url = data['media']['drm']['licenseServerUrl'] + '?specConform=true'
or
payload = 'capabilities.audioCodec=aac&capabilities.drm=wide vine&capabilities.screenSize=3840x2160&capabilitie s.videoCodec=h265%2Cdecode%2Ch263%2Ch265%2Chevc%2C mjpeg%2Cmpeg2v%2Cmp4%2Cmpeg4%2Cvc1%2Cvp8%2Cvp9&cli entId=4b87ccf14a0791c8&features=hdr10,hevc&manufac turer=NVIDIA&model=SHIELD%20Android%20TV&os=Androi d-9&sdk=28&stanVersion=4.20.1&type=console&colorSpac e=hdr10'
r = requests.post(url='https://api.stan.com.au/concurrency/v1/streams?jwToken={}&programId={}&stanName=Stan-AndroidTV&quality=ultra&format=dash'.format(token, video_id), data=payload, headers=headers)
data = r.json()
license_url = data['media']['drm']['licenseServerUrl'] + '?specConform=true' -
The jwToken from the browser only allows you to get 540p. If you want 1080p/4K you need to take the jwToken during login from a Nvidia Shield.
Bonde, newbe here on Token's. Can you give me a link that explains exactly what a jwToken is?
Edited post to note that I looked it up on Google. Thanks anyway.Extraordinary claims require extraordinary evidence -Carl Sagan -
You can copy paste your token in to
and it should give you the info
"exp": 1681937047,
"jti": "REMOVED",
"iat": 1671569047,
"role": "user",
"uid": "REMOVED",
"streams": "uhd",
"concurrency": 4,
"profileId": "REMOVED",
"pir": true,
"tz": "LOCATION",
"app": "Stan-AndroidTV",
"ver": "4.20.1",
"feat": REMOVED -
Don't think so. I asked a smart person to help me.
Maybe you can use Fiddler to capture the data.
Folks, question solved.
Maybe it's because the movie I downloaded doesn't have 1080p (on this platform).
Another try just now (output below):
[Attachment 68833 - Click to enlarge]
It's unlikely that we can only access 1080p on TV or something else.
Best video converter from 540p to 4k?
By savvyguy in forum Newbie / General discussionsReplies: 6Last Post: 26th Jul 2021, 19:52 -
Stan, me old chum.
By Lamington in forum Video Streaming DownloadingReplies: 4Last Post: 31st May 2021, 13:54 -
540p stream vs 576p PAL DVD quality
By Tz2002 in forum Newbie / General discussionsReplies: 8Last Post: 25th Nov 2020, 19:01 -
[sorry wrong forum, please delete]
By Tz2002 in forum Video Streaming DownloadingReplies: 0Last Post: 25th Nov 2020, 12:57 -
Converting a 1080p 60Hz to 1080p 23.97Hz
By snadge in forum Video ConversionReplies: 3Last Post: 11th Sep 2019, 12:31
