Trying to grab this video:
https://www.tsn.ca/hockey-canada/video/~2589256
Was able to get a low-res version (960x540) without too much trouble.. but it was bothering me because I know there's got to be a better one out there.
Investigating.. I find there's two video manifests:
https://capi.9c9media.com/destinations/tsn_web/platforms/desktop/bond/contents/2589256...9/manifest.mpd
https://capi.9c9media.com/destinations/tsn_web/platforms/desktop/bond/contents/2589256.../manifest.pmpd
The first one has the low res video. The second one has the higher res video I'm after, but it appears it's using a different encryption scheme (presumably playready). And here's where I hit a wall, because I'm not sure how to get the keys.
As per the good people in this thread - https://forum.videohelp.com/threads/406020-Can-download-720p-but-not-1080p-from-Noovo-ca - for 9c9media stuff just tack
onto the end of the .mpd link and you can get the keys for higher resolutions from the Widevine server.Code:?filter=14
As the PSSH (KIDs) of the 1080p video is different, as the linked thread goes into, you can't rely on the PSSH from userscripts like EME Logger. Assuming I didn't make any mistakes and downloaded the correct init segment, these keys should work for the 1080p video with PSSH:Code:AAAAU3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADMIARIQP9Mece7w1Sl8F0fe3armTRoJYmVsbG1lZGlhIhJmZi00NmI5ZGJiNi0xMjQ5MDg=
Code:3fd31e71eef0d5297c1747deddaae64d:3278e28229bdd3221adb01bccb92fa57 d48023f5f34f0ace82f5f8399eaa4a46:d3f22845da67c7d2a3ae32b828b07921 54ffc966acfdb070561dac12e5404720:8e9c6346da8ca3641d719f47f8371ea5
Hi!
I think I'm trying to do something similar with TSN.ca. I can't really follow your logic above; If I take an mpd like this one: https://live-cito.9c9media.ca/1c3b314400c213d678f83ef6687899a3dfb7c8b21674096484889/f/...1/manifest.mpd and add ?filter=14 to the end of it; the result in both cases (with or without the filter query param) is an identical mpd file. (how do you know which is the correct mpd for a given media stream? I see a new one get loaded every 5 seconds or so, indefinitely)
Currently working with N_m3u8DL-RE to download all the 1080p fragments (using an mpd url like the one linked to above); but can't decrypt any of them using mp4decrypt. Feel like I'm missing a crucial piece of the equation here. Have seen tools in this forum like axinom's pssh box - but am failing to see how a pssh can yield decryption keys. I've a full Chrome network traffic recording (har file) of my session (e.g. all urls, all headers, all content etc..) so can provide more info if required.
Any help is appreciated. -
Please continue with you reading. To get the desired keys you will need to send this pssh in conjunction with some header data to the license server utilizing a cdm with a script (could be python) or a site that enable such activities. If these terms are unfamiliar, to you then do as suggested and please continue reading.
Downloading encrypted m3u8 with encrypted key
By alanonymous in forum Video Streaming DownloadingReplies: 4Last Post: 29th Mar 2022, 10:51 -
Downloading encrypted mpd video files
By umar_0x01 in forum Video Streaming DownloadingReplies: 40Last Post: 6th Sep 2021, 12:02 -
Please help me download this video encrypted with Playready DRM from .mpd
By PescaGialla in forum Video Streaming DownloadingReplies: 6Last Post: 2nd Feb 2021, 13:23 -
Help downloading AES-encrypted HLS video stream
By Woodswolf in forum Video Streaming DownloadingReplies: 26Last Post: 25th May 2019, 15:20 -
By vidder in forum Video Streaming DownloadingReplies: 3Last Post: 4th Jul 2018, 18:24
