Results 1 to 19 of 19
    Aug 2015
    Quebec, Canada
    Hello,
    I'm trying to download a 1080p version of this video : https://www.noovo.ca/emissions/un-souper-presque-parfait/lundi-semaine-rive-nord-josee-s13e1
    I've done it in 720p and I've decrypted it (using PSSH / Licence Request and a working L3). There's a MPD capped to 720p (the one I used) and there's a 2nd and 3rd one (PMPD?) that contain information about 1080p
    <?xml version="1.0" encoding="utf-8"?>
    <MPD xmlns="urn:mpeg:dashchema:mpd:2011" xmlns:cenc="urn:mpeg:cenc:2013" profiles="urn:mpeg:dashrofile:isoff-live:2011" type="static" minBufferTime="PT4S" mediaPresentationDuration="PT0H21M50.208S">
    <BaseURL>https://pe-fa-vp06a.9c9media.com/playlist/4419065/40712518/dash/01140001/5455f5007055ac12/</BaseURL>
    <Period start="PT0S" duration="PT0H21M50.208S">
    <AdaptationSet contentType="video" segmentAlignment="true" startWithSAP="1">
    <Role schemeIdUri="urn:mpeg:dash:role:2011" value="main">
    </Role>
    <ContentProtection schemeIdUri="urn:mpeg:dash:mp4protection:2011" value="cenc">
    </ContentProtection>
    <ContentProtection schemeIdUri="urn:uuid:9a04f079-9840-4286-ab92-e65be0885f95" value="MSPR 2.0">
    <SegmentTemplate timescale="30000" initialization="index/bcd2e823/none/none/stream/$RepresentationID$/init.mp4" media="index/bcd2e823/none/none/stream/$RepresentationID$/segment/$Time$.m4f">
    <SegmentTimeline>
    <S d="120120" r="120">
    </S>
    <S d="111111">
    </S>
    <S d="120120" r="104">
    </S>
    <S d="127127">
    </S>
    <S d="120120" r="37">
    </S>
    <S d="60060">
    </S>
    <S d="120120" r="59">
    </S>
    <S d="89089">
    </S>
    </SegmentTimeline>
    </SegmentTemplate>
    <Representation id="h264/v2/192000" codecs="avc1.42c01e" mimeType="video/mp4" width="416" height="234" bandwidth="192000">
    </Representation>
    <Representation id="h264/v2/640000" codecs="avc1.4d401f" mimeType="video/mp4" width="640" height="360" bandwidth="640000">
    </Representation>
    <Representation id="h264/v2/2048000" codecs="avc1.4d401f" mimeType="video/mp4" width="1024" height="576" bandwidth="2048000">
    </Representation>
    <Representation id="h264/v2/3500000" codecs="avc1.640029" mimeType="video/mp4" width="1280" height="720" bandwidth="3500000">
    </Representation>
    <Representation id="h264/v2/7500000" codecs="avc1.640029" mimeType="video/mp4" width="1920" height="1080" bandwidth="7500000">
    </Representation>
    I successfully donwload the 1080p video/audio but my surprise if that the key don't work, I've tried various videos to make sure it wasn't my error but no, I'm just curious to know what I haven't done right so I can reproduce it.
    This is a free streaming so I would be surprise if they use another level of encryption
    Thanks for your help everyone
    kalemvar1
  2. with this mpd
    https://capi.9c9media.com/destinations/noovo_hub/platforms/desktop/bond/contents/2240106/contentpackages/4419065/manifest.pmpd?filter=14
    you can downlod at 1080p
    h264_v2_7500000 mp4 1920x1080 | 7500k dash | avc1.640029 7500k video only | DASH video, mp4_dash
    but L1 or L3 same 2 keys
    with this work only 720p, not 1080p
  3. If your keys don't work, it is either WV L1 or PlayReady protected. It is indicated in MPD file.
    That System ID in your message, "9a04f079-9840-4286-ab92-e65be0885f95" belongs to PlayReady. That's why your key didn't work.
    For higher-quality streams, PlayReady is preferred... For example, at a popular site I use, there are two video streams in 1080p:
    1- The one in Main Profile is PlayReady-protected (higher video bitrate, 5000-6500 kbps) - To watch that video, you need at least a 7th-Gen-Intel-GPU in which PlayReady 3.0 decryption module exists. Older GPUs aren't supported.
    2- The one in High Profile is WV L3-protected (lower video bitrate, 2500-3500 kbps) - That kind of 1080p videos can be watched on all devices - via browsers (like Mozilla Firefox) in which WV-L3 decryption module exists.
    So just as you're being forced to 720p, I can only get the lower-bitrate one in my case.
    Three different protections (L1, L3, PlayReady) are being used at different resolutions (480p, 720p, 1080p, UHD) of a specific content, and even at the same resolution with different bitrates and different encodings as I wrote above.
  4. good explanation. thanks ridibunda
    Aug 2015
    Quebec, Canada
    Thanks for the explanation ridibunda & Iomero,
    without asking how, can DRM from Playready can be remove at this point ? or it's a dead end for me ?
  6. dead. PR = no chance
    you have to settle for 720p
  7. You can force a different mpd that is purely wv with:
    https://capi.9c9media.com/destinations/noovo_hub/platforms/desktop/bond/contents/2240106/contentpackages/4419065/manifest.mpd
    but its 720p max, so whichever way you slice it or dice it, unless you can crack mspr; its 720p as lomero said.
  8. redacted
    Aug 2015
    Quebec, Canada
    Thanks howboring
    it's working with
    https://capi.9c9media.com/destinations/noovo_hub/platforms/desktop/bond/contents/22401...5/manifest.mpd
    Then add the query param ?filter=0x14 and now you have 1080p on the wv manifest.
    https://capi.9c9media.com/destinations/noovo_hub/platforms/desktop/bond/contents/22401...pd?filter=0x14 is indeed give me 1080p WV manifest and DL is working, obviously my key isn't (was working for 720p), I have to generate a new one with this manifest, I'm just not sure how to use only a .MPD to play this 1080p video to obtain the licence ?
    Thanks all for your respond
  10. nice work kalemvar1 on the 1080p manifest tweak.
    you can get the pssh from the init file of the video.
    ie.
    AAAAlnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAHYIARIQ/FyTS9EI+wM7DkcWVeVyjxoJYmVsbG1lZGlhIlVwbGF5bGlzdC80NDE5MDY1LzQwNzEyNTE4L2Rhc2gvMjAxNDAwMDEvZWE5ZjU3MmRlY2RlZGRhMC9pbmRleC9iY2QyZTgyMy9ub25lL25vbmUvZHJt
    you can use that with the same license url to get keys from getwvkeys.cc
    keys:
    fc5c934bd108fb033b0e471655e5728f:1379f96f3889da5f5c154934690f17b1
    0a35151ea1467da66d8a695286afe531:05fce7d68ec0ff25ceba9a4bbaee1a5c
    these keys work to decrypt the video and audio from the wv mpd (including 1080p).
  11. great work lads
  12. Member k2000's Avatar
    Jan 2022
    Canada
    ie.
    keys:
    where is this unit file?
    If it can work for other site this method? info please.
  13. where is this unit file?
    getpssh.py
    MPD URL: https://capi.9c9media.com/destinations/noovo_hub/platforms/desktop/bond
    /contents/2240106/contentpackages/4419065/manifest.mpd?filter=3
    Generating PSSH from init Anyway....
    INIT_PSSH:-  AAAAlnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAHYIARIQwOOCW3zXmJYu1hcH+CzP0xoJYmVsbG1lZGlhIlVwbGF5bGlzdC80NDE5MDY1LzQwNzEyNTE4L2Rhc2gvMjAwMzAwMDEvNTk4Zjc1OGM1YzYzY2JlYi9pbmRleC9iY2QyZTgyMy9ub25lL25vbmUvZHJt
    SUCCESS
    License:https://license.9c9media.ca/widevine
    PSSH:AAAAlnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAHYIARIQwOOCW3zXmJYu1hcH+CzP0xoJYmVsbG1lZGlhIlVwbGF5bGlzdC80NDE5MDY1LzQwNzEyNTE4L2Rhc2gvMjAwMzAwMDEvNTk4Zjc1OGM1YzYzY2JlYi9pbmRleC9iY2QyZTgyMy9ub25lL25vbmUvZHJt
    Headers:{'user-agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (Ktesttemp, like Gecko) Chrome/90.0.4430.85 Safari/537.36'}
    Time:Sun Jun 12 21:49:08 2022
    c0e3825b7cd798962ed61707f82ccfd3:6ff15b0dd762fef6f0557975adbe55a7
    86c8668eb518b5a1b4a6e2b65682f04e:5d31868ae37a3c92f61a342d10ac25ad
  14. Member k2000's Avatar
    Jan 2022
    Canada
    getpssh.py
    SUCCESS
    where is this file located getpssh.py
  15. Originally Posted by k2000 View Post
    from getwvkeys discord
    https://www.upload.ee/files/14225032/getpssh.py.html
    the init file is the first part of the video/audio
  16. Member k2000's Avatar
    Jan 2022
    Canada
  17. Member k2000's Avatar
    Jan 2022
    Canada
    Do you also have a technique if there are AC3 or EAC3 audio tracks to hide instead of AAC?
  18. It looks like they closed this loophole for getting a 1080p WV manifest. At least it doesn't seem to work anymore with CTV.
