Hi,
When I open this .srt I have "error readind subtitle number 1" , any idea?
Results 1 to 14 of 14
I used subtitle edit to open the file and found no issues,could be that subtitle creator hasn't been updated in over 14 years.
thanks too I've always used subtitle edit but I have a problem https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD...15#post2676458that I can't solve and I was looking for the alternative with subtitle creator
Easy solution is to export the sub as vobsub in subtitle edit,it is meant for dvd.
ok
sorry for my bad English, I'll try to summarize, then
1 in Subtitle Edit file-export- vobsub selects all
[Attachment 68388 - Click to enlarge]
it offers me I don't know why .it and I change to .sub
[Attachment 68389 - Click to enlarge]
now how should i add the new .sub to the dvd i tried with ifoedit but it doesn't work
P:S: I muxed a dvd with ita audio using PgcDemux.exe, MuxMan, VobBlanker , PgcEdit. -
You need to import to infoedit with the idx file,not sub.
thanks for this, the color I choose then on powerDVD looks different
[Attachment 68391 - Click to enlarge]
[Attachment 68392 - Click to enlarge]
or VLC
[Attachment 68393 - Click to enlarge] -
Muxman may change the colors when it authors the DVD. There is a way to fix them. See https://forum.videohelp.com/threads/335583-Muxman-changes-color-of-SUP#post2083937
How To Detect Timecode Duration Error in Subtitle Edit
By violettiong in forum SubtitleReplies: 1Last Post: 23rd Nov 2021, 10:49 -
Subtitle Workshop gives floating point divide by zero error opening videos.
By bizzybody in forum SubtitleReplies: 2Last Post: 26th Feb 2021, 01:15 -
Subtitle edit, warning subtitle contains negative timing codes fix please
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2019, 18:52 -
Subtitle edit audio profile - audio sync error.
By hibbs in forum SubtitleReplies: 9Last Post: 11th Dec 2018, 20:44 -
Error messages with Subtitle Workshop
By Patapin in forum SubtitleReplies: 10Last Post: 30th Aug 2018, 05:01
