Page 13 of 29
FirstFirst ... 3 11 12 13 14 15 23 ... LastLast
Results 361 to 390 of 849
  1. This is the result of my attempt, the video cannot be played. I have tried Android 9.0,Android 10.0, Android 11 and 12, but they are still useless.
    In addition, I have also tried setting the DNS of the router and my computer to 8.8.8.8, but it still hasn't worked. Please help me, thanks a lot!
  2. Originally Posted by sibuk View Post
    But it's still useless.
    Feb 2018
    Spain
    Make sure you are not using a vpn or the video will not play, I just tested it again and it works fine but would not work if I had a vpn turned on.
  4. Hi everyone, I'm having trouble getting the keys to dump. I'm using frida-server-16.1.4--android-x86_64 and running it on an emulated Pixel 3a with the Android API 34 x86_64. I can go to the bitmovin DRM demo page and play the video successfully with widevine DRM but I can't get dump_keys.py to detect and grab the keys, it just stays on "Hooks completed". Does this method not work with some of the newer APIs? I've read through the replies on this thread and a couple others and I can't seem to find any obvious reason why this wouldn't work.
    Edit: maybe an important thing to note, no popup appeared saying that my device's ID needed to be verified. However the video still played. Does this mean anything?
    Feb 2022
    Search the forum first!
    The function names that Frida tries to hook are different if using Android 10 and above. Cedric uses Android 9 (pie) You need to give Frida some help and find the function names yourself. if you use anything different
    See https://forum.videohelp.com/threads/407196-Dumping-L3-from-Android-10-11-and-12.
  6. Hello,
    I followed the description step by step.
    Then the dumper makes this problem:
    C:\dumper-main>Python dump_keys.py
    File "C:\dumper-main\dump_keys.py", line 6, in <module>
    from Helpers.Scanner import Scan
    File "C:\dumper-main\Helpers\Scanner.py", line 7, in <module>
    from Helpers.wv_proto2_pb2 import SignedLicenseRequest
    File "C:\dumper-main\Helpers\wv_proto2_pb2.py", line 33, in <module>
    _descriptor.EnumValueDescriptor(
    File "C:\Users\xxx\AppData\Local\Programs\Python\Python 311\Lib\site-packages\google\protobuf\descriptor.py", line 796, in __new__
    _message.Message._CheckCalledFromGeneratedFile()
    TypeError: Descriptors cannot not be created directly.
    If this call came from a _pb2.py file, your generated code is out of date and must be regenerated with protoc >= 3.19.0.
    If you cannot immediately regenerate your protos, some other possible workarounds are:
    1. Downgrade the protobuf package to 3.20.x or lower.
    2. Set PROTOCOL_BUFFERS_PYTHON_IMPLEMENTATION=python (but this will use pure-Python parsing and will be much slower).
    More information: https://developers.google.com/protocol-buffers/docs/news/2022-05-06#python-updates
    Could you help?
    Thank you.
  7. Originally Posted by hopeful View Post
    Hello,
    Could you help?
    Thank you.
    its been covered multiple times in this thread, go have a read through or search.
  8. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Hello,
    Could you help?
    Thank you.
    I'll give you a hint:
    Jump to page 9
    Feb 2022
    Here's a thing. If every you need to downgrade a python module, from, say, a series 4 version to a series 3 version, and you are unsure which is the latest module available in series three, Just try
    pip install  protobuf==3.x.x
    The command will fail but will list all the versions available. which in this example is protobuf==3.20.3
  10. I've followed the guide exactly and have 2 command prompt windows open yet I can't connect to frida-server after running
    Python dump_keys.py
    [Attachment 73826 - Click to enlarge]
  11. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Python dump_keys.py
    What version Android are you using?
    What version frida is installed in python? It should be the same (or close to the) version of the one you are pushing to the emulator.
  12. Originally Posted by Karoolus View Post
    Python dump_keys.py
    Same as in the guide. Android 9.0 x86. The frida version I pushed to the emulator is 16.1.4. and the one in python is the same.
    Edit: Fixed it. Thank you cedric8528 for the amazing guide!
    Sep 2023
    Red Wood City
    doesn't work on Android 13 x86_64
    2023-10-01 09:17:06 PM - main - 39 - INFO - Functions hooked, now open the DRM stream test on Bitmovin from your Android device! https://bitmovin.com/demos/drm - but nothing happen
  14. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Try with Android 9, like in the guide. If that works, you can try a different version. I haven't had any luck with A13 so far (haven't tried very much though) but 9-10-11 work flawlessly.
  15. Hi guys, having issue pushing file to sd card using
    adb.exe push frida-server-16.1.4-android-x86 /sdcard
    I havefrida-server-16.1.4-android-x86 in my AppData\Local\Android\Sdk\platform-tools folder
    comes back with
    adb: error: failed to copy 'frida-server-16.1.4-android-x86' to '/sdcard': remote couldn't create file: No such file or directory
    frida-server-16.1.4-android-x86: 1 file pushed, 0 skipped. 21.3 MB/s (51624572 bytes in 2.313s)
  16. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    comes back with
    Share a screenshot of:
    1. running the adb devices command
    2. your platform-tools folder
    3. running the command (including command and output)
  17. Originally Posted by Karoolus View Post
    comes back with
    I think its because my virtual device doesn't boot up, I have changed it from auto to hardware and software for the graphics but it just times out and never starts.
    I am running android studio on win11 virtual machine. Might have to try directly on my laptop.
Name:	Screenshot 2023-10-06 091113.png
Name:	Screenshot 2023-10-06 092104.png
Name:	Screenshot 2023-10-06 091938.png
    Image Attached Images
  18. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Yeah I don't know how well it will work, running a VM (cause the AVD is essentially a VM) inside another VM. I've had problems with running it inside a VM on one host, but it was fine on another host, so ymmv.
    You could try running it bare metal indeed. You could also just check my signature and use one of those.
  19. Originally Posted by Karoolus View Post
    Went through it all locally on my laptop and got my 2files
    device_client_id_blob
    device_private_key
  20. Hi, i am stuck at this step
    [Attachment 74281 - Click to enlarge]
    everything else has worked until now, I get error "python was not found"
    [Attachment 74282 - Click to enlarge]
    I have python 3.12 and I have updated environment variables
    EDIT: after restarting PC, "python dump_keys.py" seems to execute now. But with the following error
    [Attachment 74283 - Click to enlarge]
    EDIT#3: Reading through previous posts, multiple users had the protobuf error and just need to uninstall current version and install 3.20.1
    Following post#249 on page 9.
    Originally Posted by sarvo99 View Post
    I faced the same problem here is the solution -
    To downgrade the protobuf package in your Python environment, you can use pip, the package manager for Python. Follow these steps:
    Write in cmd window -
    pip show protobuf
    pip uninstall protobuf
    pip install protobuf==3.20.1
    Python dump_keys.py
    All thanks to ChatGPT.
  21. Hi Chaps...
    I'm Starting right from the beginning...
    Win 10... 64bit
    Installed android-studio-2022.2.1.20-windows.exe I am then offered the option to download extra components, such as (Packages to install: - Google APIs Intel x86 Atom System Image (system-images;android-28;google_apis;x86) I'm sure this was so that i could emulate 9.0 pie. but on the same page it states that HAXM is not installed, do i wish to install it.
    Is this normal, as it is not explained in the first part of Page 1 by cedric.
    [Attachment 74307 - Click to enlarge]
    I'm sure once the basics are setup the rest should be quite easy to follow.
    I decided to install HAXM, oddly it states that it is not installed, so i installed it again, it stated that it was re-installed successfully.... maybe time for a reboot.
    my option now..
    [Attachment 74308 - Click to enlarge]
    The first item seemed to be pre-installed,.. the second I attempted to create. neither has been run yet, as, typical, i am on my second windows update for today.
    Should have put this as the first image,.... sorry chaps...
    [Attachment 74309 - Click to enlarge]
    Should I be selecting SDK Manager or Virtual Device Manager,..... trying my best to follow cedrics images.
    Last edited by LastResort; 11th Oct 2023 at 14:05. Reason: Error explaining my actions.
  22. Ridiculous as this may seem, but I am almost there,.... but after reading many people having the same problem, I too have the same error.
    D:\Android\dumper-main>Python dump_keys.py
    File "D:\Android\dumper-main\dump_keys.py", line 6, in <module>
    File "D:\Android\dumper-main\Helpers\Scanner.py", line 3, in <module>
    from Crypto.PublicKey import RSA
    ModuleNotFoundError: No module named 'Crypto'
    I have made sure that my versions are correct,...
    I followed angela's help...
    C:\WINDOWS\system32>pip install protobuf==3.x.x
    ERROR: Could not find a version that satisfies the requirement protobuf==3.x.x (from versions: 2.0.0b0, 2.0.3, 2.3.0, 2.4.1, 2.5.0, 2.6.0, 2.6.1, 3.0.0a2, 3.0.0a3, 3.0.0b1, 3.0.0b1.post1, 3.0.0b1.post2, 3.0.0b2, 3.0.0b2.post1, 3.0.0b2.post2, 3.0.0b3, 3.0.0b4, 3.0.0, 3.1.0, 3.1.0.post1, 3.2.0rc1, 3.2.0rc1.post1, 3.2.0rc2, 3.2.0, 3.3.0, 3.4.0, 3.5.0.post1, 3.5.1, 3.5.2, 3.5.2.post1, 3.6.0, 3.6.1, 3.7.0rc2, 3.7.0rc3, 3.7.0, 3.7.1, 3.8.0rc1, 3.8.0, 3.9.0rc1, 3.9.0, 3.9.1, 3.9.2, 3.10.0rc1, 3.10.0, 3.11.0rc1, 3.11.0rc2, 3.11.0, 3.11.1, 3.11.2, 3.11.3, 3.12.2, 3.12.4, 3.13.0rc3, 3.13.0, 3.14.0rc1, 3.14.0rc2, 3.14.0rc3, 3.14.0, 3.15.0rc1, 3.15.0rc2, 3.15.0, 3.15.1, 3.15.2, 3.15.3, 3.15.4, 3.15.5, 3.15.6, 3.15.7, 3.15.8, 3.16.0rc1, 3.16.0rc2, 3.16.0, 3.17.0rc1, 3.17.0rc2, 3.17.0, 3.17.1, 3.17.2, 3.17.3, 3.18.0rc1, 3.18.0rc2, 3.18.0, 3.18.1, 3.18.3, 3.19.0rc1, 3.19.0rc2, 3.19.0, 3.19.1, 3.19.2, 3.19.3, 3.19.4, 3.19.5, 3.19.6, 3.20.0rc1, 3.20.0rc2, 3.20.0, 3.20.1rc1, 3.20.1, 3.20.2, 3.20.3, 4.0.0rc1, 4.0.0rc2, 4.21.0rc1, 4.21.0rc2, 4.21.0, 4.21.1, 4.21.2, 4.21.3, 4.21.4, 4.21.5, 4.21.6, 4.21.7, 4.21.8, 4.21.9, 4.21.10, 4.21.11, 4.21.12, 4.22.0rc1, 4.22.0rc2, 4.22.0rc3, 4.22.0, 4.22.1, 4.22.3, 4.22.4, 4.22.5, 4.23.0rc2, 4.23.0rc3, 4.23.0, 4.23.1, 4.23.2, 4.23.3, 4.23.4, 4.24.0rc1, 4.24.0rc2, 4.24.0rc3, 4.24.0, 4.24.1, 4.24.2, 4.24.3, 4.24.4)
    ERROR: No matching distribution found for protobuf==3.x.x
    I then tried pip show protobuf
    C:\WINDOWS\system32>pip show protobuf
    Version: 3.20.1
    Summary: Protocol Buffers
    Home-page: https://developers.google.com/protocol-buffers/
    Author:
    Author-email:
    License: BSD-3-Clause
    Location: C:\Users\xxxxxxxx\AppData\Local\Programs\Python\Py thon311\Lib\site-packages
    Requires:
    Required-by: google-api-core, googleapis-common-protos
    Which I think is the correct one.
    I have one folder within C:\Users\xxxxxxxx\AppData\Local\Programs\Python\Py thon311\Lib\site-packages called Cryptodome with a cap C.
    I've re-read everything, but still get the same error.
    Have re-installed pycryptodome
    C:\WINDOWS\system32>pip install pycryptodome
    Collecting pycryptodome
    Obtaining dependency information for pycryptodome from https://files.pythonhosted.org/packages/87/c4/c979db0914a23541d62c9e4b5e8a30f56a78c6de...4.whl.metadata
    Downloading pycryptodome-3.19.0-cp35-abi3-win_amd64.whl.metadata (3.4 kB)
    Downloading pycryptodome-3.19.0-cp35-abi3-win_amd64.whl (1.7 MB)
    ---------------------------------------- 1.7/1.7 MB 3.0 MB/s eta 0:00:00
    Installing collected packages: pycryptodome
    Successfully installed pycryptodome-3.19.0
    [notice] A new release of pip is available: 23.2 -> 23.2.1
    [notice] To update, run: python.exe -m pip install --upgrade pip
    My emulator is running,
    previous to this i had already followed cedric's detailed instructions,... apart from the version updates. which i copied to a txt file and renamed as necessary.
    frida-server-16.1.4-android-x86 unpacked
    As said everything worked as it should have done right up to dump_keys.py (had to hunt around for this as the link in page one was dead.
    here's my method, of what I did, I kept a text file of each step.
    Microsoft Windows [Version 10.0.19045.3570]
    (c) Microsoft Corporation. All rights reserved.
    C:\WINDOWS\system32>pip install frida
    Collecting frida
    Obtaining dependency information for frida from https://files.pythonhosted.org/packages/df/3e/8ae933efd51f18bc7b555fac682124a48ed087b7...4.whl.metadata
    Downloading frida-16.1.4-cp37-abi3-win_amd64.whl.metadata (2.1 kB)
    Downloading frida-16.1.4-cp37-abi3-win_amd64.whl (32.6 MB)
    ---------------------------------------- 32.6/32.6 MB 5.1 MB/s eta 0:00:00
    Installing collected packages: frida
    Successfully installed frida-16.1.4
    C:\WINDOWS\system32>pip install frida-tools
    Collecting frida-tools
    Downloading frida-tools-12.3.0.tar.gz (200 kB)
    ---------------------------------------- 200.5/200.5 kB 3.0 MB/s eta 0:00:00
    Installing build dependencies ... done
    Getting requirements to build wheel ... done
    Preparing metadata (pyproject.toml) ... done
    Collecting colorama<1.0.0,>=0.2.7 (from frida-tools)
    Downloading colorama-0.4.6-py2.py3-none-any.whl (25 kB)
    Requirement already satisfied: frida<17.0.0,>=16.0.9 in c:\users\lianidos\appdata\local\programs\python\py thon311\lib\site-packages (from frida-tools) (16.1.4)
    Collecting prompt-toolkit<4.0.0,>=2.0.0 (from frida-tools)
    Obtaining dependency information for prompt-toolkit<4.0.0,>=2.0.0 from https://files.pythonhosted.org/packages/a9/b4/ba77c84edf499877317225d7b7bc047a81f7c2ee...y.whl.metadata
    Downloading prompt_toolkit-3.0.39-py3-none-any.whl.metadata (6.4 kB)
    Collecting pygments<3.0.0,>=2.0.2 (from frida-tools)
    Obtaining dependency information for pygments<3.0.0,>=2.0.2 from https://files.pythonhosted.org/packages/43/88/29adf0b44ba6ac85045e63734ae0997d3c58d8b1...y.whl.metadata
    Downloading Pygments-2.16.1-py3-none-any.whl.metadata (2.5 kB)
    Collecting wcwidth (from prompt-toolkit<4.0.0,>=2.0.0->frida-tools)
    Obtaining dependency information for wcwidth from https://files.pythonhosted.org/packages/58/19/a9ce39f89cf58cf1e7ce01c8bb76ab7e2c7aadbc...y.whl.metadata
    Downloading wcwidth-0.2.8-py2.py3-none-any.whl.metadata (13 kB)
    Downloading prompt_toolkit-3.0.39-py3-none-any.whl (385 kB)
    ---------------------------------------- 385.2/385.2 kB 4.8 MB/s eta 0:00:00
    Downloading Pygments-2.16.1-py3-none-any.whl (1.2 MB)
    ---------------------------------------- 1.2/1.2 MB 3.7 MB/s eta 0:00:00
    Downloading wcwidth-0.2.8-py2.py3-none-any.whl (31 kB)
    Building wheels for collected packages: frida-tools
    Building wheel for frida-tools (pyproject.toml) ... done
    Created wheel for frida-tools: filename=frida_tools-12.3.0-py3-none-any.whl size=209506 sha256=1f0aac898f36d2f0e065f2fa2fd235184dbc807bcb8 eb5016b4a35074fc521bd
    Stored in directory: c:\users\lianidos\appdata\local\pip\cache\wheels\9 5\34\46\3e2c3108de4fcae46153d9152c52d1d2f439511718 7847b313
    Successfully built frida-tools
    Installing collected packages: wcwidth, pygments, prompt-toolkit, colorama, frida-tools
    Successfully installed colorama-0.4.6 frida-tools-12.3.0 prompt-toolkit-3.0.39 pygments-2.16.1 wcwidth-0.2.8
    C:\WINDOWS\system32>cd C:\Users\xxxxxxxxxx\AppData\Local\Android\Sdk\plat form-tools
    C:\Users\xxxxxxxx\AppData\Local\Android\Sdk\platfo rm-tools>adb.exe devices
    List of devices attached
    emulator-5554 device
    C:\Users\xxxxxxxx\AppData\Local\Android\Sdk\platfo rm-tools>adb.exe push frida-server-16.1.4-android-x86 /sdcard
    frida-server-16.1.4-android-x86: 1 file pushed, 0 skipped. 112.5 MB/s (51624572 bytes in 0.438s)
    adb.exe shell
    su
    mv /sdcard/frida-server-16.1.4-android-x86 /data/local/tmp
    chmod +x /data/local/tmp/frida-server-16.1.4-android-x86
    my last step before the dumper error...
  23. I saw jawz22 pip list and there was a file called crypto in there,.... Angela mentioned in another page to probably try pip install crypto... yep it worked. the emulator was unbelievably slow,... said that i could wait for something to run or cancel (sorry i can't remember what it was) but deffo due to the speed of my old machine. but i managed to scroll down to bitmovin's player and clicked play,... nothing really moved, but it seemed to be enough to create my first 2 keys.... wow.... thanks cedric for the guide, and Angela and the others that contributed.
    I have one question,... in order to create a new set of keys do i delete my created phone and recreate a new one????
  24. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    yes, create a new AVD and dump the keys in the same way
  25. Thanks for all the support in the thread.
    I was able able to get the files.
    Difficulties encountered are:
    No knowing that downgrading protobuf package as explained in page 9 is required:
    pip show protobuf
    pip install protobuf==3.20.3
    Python dump_keys.py
    Also injecting proper frida server x86 or x86_64 depending on the phone selected in the Android studio in my case.
    Making sure frida server in running before running dumper main in a SEPARATE terminal.
    Thanks everyone.
  26. Originally Posted by Karoolus View Post
    Thank you for the reply Karoolus.....
    Sorry if my posting went a bit off kilter,.....
  27. Hi Everyone
    Everything works fine, but the result is a bit different.
    Does anyone know how I can solve it?
    I use Studio Android
    Android9
    frida-server-16.0.2-android-arm64
    https://github.com/wvdumper/dumper
    [Attachment 74362 - Click to enlarge]
Name:	Immagine 16-10-23 - 10.06.jpeg
  28. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Originally Posted by ennada View Post
    Hi Everyone
    Can you give more information?
    Android version, frida version, which dumper script, ...
  29. Once I have obtained the two files, how do I obtain the KEY?
    regards
