Results 271 to 300 of 306
Thanks for this, but I've already got the series, it was just that one episode missing.
Out of curiosity, how would I use this and could ot be edited to download other series from itvx?
Is the top url the original source, and the bottom url the downloadable source? If so, what are the keys in the middle?
TIA -
I'm new. I know nothing about scripts. Is there step by step guide to downloading from ITVX?
I want to download the complete Cadfael series in HD.
http://www.itv.com/watch/cadfael/CADFAEL -
Well, you need to start learning stuff.
Since you want ITV in HD then your best bet is probably to setup Devine on your PC, made by some awesome folks and our beloved @stabbedbybrick
You can find the thread of Devine in the sticky threads, but I'm not sure how helpful it will be for you.
On the other hand, there's a great (somewhat easy to follow) guide posted by user @SaintyUK that you can find here
https://forum.videohelp.com/threads/416617-Semi-automated-guide-to-install-stabbedbybr...fork-of-Devine
If you show that you are trying to learn, and trying to make it work, and that you're reasonable, people will probably help you if you stumble upon things. -
I'm stuck at this...
Add your Widevine Device (.wvd) file to this directory
What's a Widevine Device file?
I'm using Windows 11.Last edited by trev_uk; 11th Dec 2024 at 16:10.
Easy route: https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21
Fun route: https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-Studio
To convert to wvd if needed...
Install pywidevine with: pip install pywidevine
Then follow: https://github.com/devine-dl/devine?tab=readme-ov-file#widevine-provisionsLast edited by SaintyUK; 11th Dec 2024 at 16:22.
Thanks!
I think I've installed everything.
Which command do I need (in command prompt) to download Cadfael eps in HD from ITVX?
(I own the complete Cadfael on DVD but the ITVX episodes are in HD. There's no Blu-ray release) -
Start with this as a test:
Then read:Code:devine dl -w S01E01 itv https://www.itv.com/watch/cadfael/CADFAEL
And:Code:devine dl -?
Code:devine dl itv -?
first: poetry shell
then devine dl ..........
or you can
poetry run devine dl .........
[Attachment 84086 - Click to enlarge]Last edited by iamghost; 11th Dec 2024 at 18:08.
I don't know what any of that means but thanks for trying.first: poetry shell
or you can
Looking at your screenshot, that first ep seems to be in SD (576p). -
Looks to me that season 1 is only available in 576p. Season 2, 3 and 4 are 1080p...
Looking better but still not working...
(Of course, I've hidden my ITVX log-in info)
Been a while since I checked this thread. Has there been any changes allowing us to grab 1080p video from ITV-X ?
Thanks -
Yes! Using Devine and stabbedbybrick's Devine services!
I'm not learning fast enough
If it's not too much to ask, would you kindly grab this for me in 1080p or higher if available?
https://www.itv.com/watch/royal-carols:-together-at-christmas/10a2200/10a2200a0004
I know it's available on another service but this ITV version has better colour and would love to have it in 1080p. Thank you -
merry christmas
https://gofile.io/d/N69Nz9 -
All this is just too complicated for me...
Maybe some good soul can download&share the Royal Variety Performance 2024?
https://www.itv.com/watch/the-royal-variety-performance/L0897/L0897a0025 -
Far too big at full quality - someone else maybe willing to download and upload it for you.
If not this will do it, you'll need N_m3u8DL-RE, Shaka Packager and mkvmerge...
Code:N_m3u8DL-RE "https://itvpnpctv.blue.content.itv.com/L0897-0025-001/22/1/VAR070-HD-S/L0897-0025-001_22_1_VAR070-HD-S.ism/.mpd?filter=%28%28type%3D%3D%22video%22%26%26DisplayHeight%3C%3D1080%29%7C%7C%28type%21%3D%22video%22%29%29&hdnea=st%3D1738229056~exp%3D1738250656~acl%3D/L0897-0025-001/%2A~hmac%3D132101ee49666f6948b350fa12494633565b3958c53b8ae616b71e6309cc17ec" ^ --key acce8f6f3fd04ca099aac1e645ca55f4:d80b032189239c5e6b248bfa27ca4193 ^ --use-shaka-packager -M format=mkv:muxer=mkvmerge ^ --no-log --write-meta-json false ^ --save-name "The Royal Variety Performance 2024" -
I have it if you want but the codec is AV1.
Code:General : The Royal Variety Performance.S65E01.The Royal Variety Performance 2024.FHD.AV1.AAC.mkv Format : Matroska at 2 353 kb/s Length : 2.07 GiB for 2 h 6 min 8 s 40 ms Video #0 : AV1 at 2 221 kb/s Aspect : 1920 x 1080 (1.778) at 25.000 fps Audio #0 : AAC at 128 kb/s Infos : 2 channels, 48.0 kHz Language : en
Failing to download on ITV Hub
By ChemicalMisfit in forum Video Streaming DownloadingReplies: 20Last Post: 7th Feb 2022, 17:14 -
How are people downloading from ITV Player in 2021?
By gazzacee in forum Video Streaming DownloadingReplies: 6Last Post: 4th Aug 2021, 16:52 -
problems downloading itv.com/ itv player files with tubedigger software
By elm in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2021, 05:28 -
Itv subtitles
By codymts in forum SubtitleReplies: 1Last Post: 11th Dec 2020, 16:30 -
CMD Get Crash when downloading this MPD URL!
By Semohan in forum Video Streaming DownloadingReplies: 4Last Post: 4th Dec 2020, 13:10
