I am trying to find the m3u8 of this show. The issue is QI using different encryptions method for mobile browser and pc browsers.
On mobile browser videos are limited <720p (to force people download their apk) but i was able to find the m3u8.
On the PC browser agent videos are 360p to HD but i couldn't find any way to download or locate the m3u8.
Few tools i tried so far
zackmark29 m3u8-parser downloading empty m3u8 file
webvideo-downloader able to download the first 2 fragments in PC browser agent but connection 403 for rest of the fragments.
Common downloaders like lux, yt-dlp, tubedigger, crispc, allavsoft didn't work. IDM was able to locate few fragments but these are locked.
Show is region locked to china and taiwan so please use vpn
https://www.iq.com/play/%E8%80%81%E5%B8%AB%E6%99%9A%E4%B8%8A%E5%A5%BD-episode-1-19rrlj...xs?lang=en_us#
Results 1 to 14 of 14
use Stream Recorder - download HLS as MP4 ext for chrome
simple and easy
use capture mode
[Attachment 67582 - Click to enlarge]
and 1080p is on subscription. max free res is 720p only
[Attachment 67583 - Click to enlarge] -
I tired that and bitrate is too low compared to the original one and video is kinda choppy/skipping frames. Hard to watch it on big screen.
[Attachment 67585 - Click to enlarge] -
Just checked it. The output are segmented and you'll need to download each then merge
example from your provided url:
https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/5cdd7f0ca5bb94fa21d9d0c...5601&cphc=arta
https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/6ea81420c1e51b0adbb46db...5601&cphc=arta
https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/6c893ebfeac643ca4729ee7...5601&cphc=arta
https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/d05ac671de90be48eb00d87...5601&cphc=arta
https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/6b80e6ced15130cac1ec925...5601&cphc=arta
https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/8876fc62eba1f2eb309c1b5...5601&cphc=arta
https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/c2127ebd25b0fce94163134...5601&cphc=arta
https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/9a4d4662cf67f8682993c8b...5601&cphc=arta
https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/4c6771b1fa40bb8dd9ed2d5...5601&cphc=arta -
Well you could use aria2c it should have basic command that let you download from txt file like this:
Code:https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/5cdd7f0ca5bb94fa21d9d0c...5601&cphc=arta out=output_1.flv https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/6ea81420c1e51b0adbb46db...5601&cphc=arta out=output_2.flv https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/6c893ebfeac643ca4729ee7...5601&cphc=arta out=output_3.flv https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/d05ac671de90be48eb00d87...5601&cphc=arta out=output_4.flv https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/6b80e6ced15130cac1ec925...5601&cphc=arta out=output_5.flv https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/8876fc62eba1f2eb309c1b5...5601&cphc=arta out=output_6.flv https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/c2127ebd25b0fce94163134...5601&cphc=arta out=output_7.flv https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/9a4d4662cf67f8682993c8b...5601&cphc=arta out=output_8.flv https://akcdnoversea.inter.71edge.com/videos/v0/20160627/e8/35/4c6771b1fa40bb8dd9ed2d5...5601&cphc=arta out=output_9.flv
You'll need manual/custom script in order to modify the dash url so that you can get the m3u8 format instead of flv/f4v
I made a script that can help you just rename to .bat
It will automatically download with ariac then merge and convert to mp4 with ffmpeg (Though converting flv to mp4 have warning/errors. Just ignore it or find solution)
Then you can enable aria2c download format in my repo. The instruction is there as well
Now create bins folder and put there the aria2c and ffmpeg
or if you have it already in your environment variables, you can edit the script
then click the bat and input the file name of txt fileLast edited by zackmark29; 12th Nov 2022 at 14:18. Reason: updated batch file
Here is JS code to get m3u8. (VIP for 1080p)
Code:var download = function (text, filename) { let b = new Blob([text], { type: 'text/plain' }); let a = document.createElement("a"); a.href = URL.createObjectURL(b); a.setAttribute("download", filename); a.click(); }; var ndIq = function() { var info = playerObject._player.package.engine.adproxy.engine.movieinfo.current.originalData.data.program.video.find(a=>a._selected); var m3u8Content = info.m3u8; var title = document.querySelector('.intl-album-title span span').innerText.trim() + "_" + document.querySelector('.intl-play-title a').nextSibling.nodeValue + "_" + info.scrsz + "_" + (info.code == 2 ? "H264": "H265") + "_" + document.getElementsByClassName("iqp-time-dur")[0].innerText.replace(/:/, ".") + "_" + (info.vsize / 1024 / 1024).toFixed(2) + "MB.m3u8"; if(m3u8Content!="") download(m3u8Content, title); }; ndIq();
[Attachment 67673 - Click to enlarge]
Code:F:\RE_LIVE>N_m3u8DL-RE.exe "New Life Begins_Episode 1_640x360_H264_46.25_119.77MB (1).m3u8" 11:54:45.268 INFO : N_m3u8DL-RE (Beta version) 20221116 11:54:45.301 INFO : Loading URL: New Life Begins_Episode 1_640x360_H264_46.25_119.77MB (1).m3u8 11:54:45.311 INFO : Content Matched: HTTP Live Streaming 11:54:45.312 INFO : Parsing streams... 11:54:45.315 INFO : Extracted, there are 1 streams, with 1 basic streams, 0 audio streams, 0 subtitle streams 11:54:45.315 INFO : Vid Kbps | 335 Segments | ~46m25s 11:54:45.315 INFO : Selected streams: 11:54:45.316 INFO : Vid Kbps | 335 Segments | ~46m25s 11:54:45.316 INFO : Save Name: New Life Begins_Episode 1_640x360_H264_46.25_119.77MB (1)_2022-11-17_11-54-45 11:54:45.317 INFO : Start downloading...Vid Kbps 11:54:45.558 WARN : Reading media info... 11:54:45.591 INFO : [0x100]: Video, h264 (High) ([27][0][0][0]), 640x360, 25 fps 11:54:45.593 INFO : [0x101]: Audio, aac (LC) ([15][0][0][0]), 72 kb/s 11:54:51.430 INFO : ffmpeg merging... 11:54:52.427 INFO : Done
justjob457Guest
Sorry to bother you all
I have tried your bookmarklet from @zackmark29 and JS code from @nilaoda, its works !! i can get .m3u8 file and use N_m3u8DL-RE to decrypted to get .mp4
but even so, I want to practice skills to use in other sites that are only available in my country such as AIS play
So I choose IQIYI in my practice to get .m3u8 with my own, Because there are many people can done with it.
i start to read
https://forum.videohelp.com/threads/404994-Decryption-and-the-Temple-of-Doom
https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-Studio and
https://forum.videohelp.com/threads/407216-Decryption-The-Dungeon-of-Despair
and i was very confused, Why is there no .m3u8?
Iqiyi
By EricDraven in forum Video Streaming DownloadingReplies: 9Last Post: 29th Sep 2021, 11:50 -
Downloading video streams from Iqiyi
By Sori in forum Video Streaming DownloadingReplies: 18Last Post: 14th May 2021, 12:48 -
[Potplayer] support for user-agent M3U
By KamiOh in forum Software PlayingReplies: 4Last Post: 2nd Sep 2020, 08:09 -
Changing browser
By Jomapil in forum ComputerReplies: 6Last Post: 17th Sep 2019, 12:13
