I need help how get
".\widevine_device.wvd"
https://github.com/Diazole/vdocipher-dl
Results 1 to 16 of 16
You can checkCode:
pywidevine create-device -k "path/to/device_private_key" -c "path/to/device_client_id_blob" -t "ANDROID" -l 3 -o "output_path"
to see what each flag stands for.Code:pywidevine --help
If you want to dump your own files, there's @cedric's guide
https://forum.videohelp.com/threads/408031-Dumping-Your-own-L3-CDM-with-Android-Studio
Or if you want to find existing files, there's @karoolus post
https://forum.videohelp.com/threads/413719-Ready-to-use-CDMs-available-here%21--[----->+<]>.++++++++++++.---.--------.
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Thank you!
I tried using different existing files, but always says: "ValueError: RSA key format is not supported"?
Can you show a screenshot of the folder, the terminal with the command, and the output of what you're trying to do?
C:\Users\Home\Desktop\videoz>pywidevine create-device -k C:\Users\Home\Desktop\1901532735\client_id.bin -c C:\Users\Home\Desktop\1901532735\private_key.pem -t "ANDROID" -l 3 -o C:\Users\Home\Desktop\videoz\A INFO:root:pywidevine version 1.8.0 Copyright (c) 2022-2025 rlaphoenix INFO:root:https://github.com/devine-dl/pywidevine Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "C:\Users\Home\AppData\Local\Programs\Python\Python312\Scripts\pywidevine.exe\__main__.py", line 7, in <module> File "C:\Users\Home\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Home\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "C:\Users\Home\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Home\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Home\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Home\AppData\Local\Programs\Python\Python312\Lib\site-packages\click\decorators.py", line 33, in new_func return f(get_current_context(), *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Home\AppData\Local\Programs\Python\Python312\Lib\site-packages\pywidevine\main.py", line 197, in create_device device = Device( ^^^^^^^ File "C:\Users\Home\AppData\Local\Programs\Python\Python312\Lib\site-packages\pywidevine\device.py", line 108, in __init__ self.private_key = RSA.importKey(private_key) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "C:\Users\Home\AppData\Local\Programs\Python\Python312\Lib\site-packages\Crypto\PublicKey\RSA.py", line 857, in import_key raise ValueError("RSA key format is not supported") ValueError: RSA key format is not supported -
You're running the wrong command. Change it to
Code:pywidevine create-device -c C:\Users\Home\Desktop\1901532735\client_id.bin -k C:\Users\Home\Desktop\1901532735\private_key.pem -t "ANDROID" -l 3 -o C:\Users\Home\Desktop\videoz\A
AHHH! Thanks! Y'r live saver!
But still unable to find license keys
Tried:
via Firefox extension: Widevine L3 Decrypter (Says: No keys)
via site: https://emarsden.github.io/pssh-box-wasm/get-license/
says: Licence request failed
Code:CDM session: b'\xfc\xdf"\n\xb1c\xf5\xd5\x84\x1a\xbav\xff\x87\x11\xf4' License request HTTP error 403 Client Error: for url: https://cbsi.live.ott.irdeto.com/widevine/getlicense?CrmId=cbsi&AccountId=cbsi&SubContentType=Default&ContentId=3GjFaScXISDwd29Zi0FNsb8aUhCeHzRg&CMCD=mtp%3D300%2Cot%3Dk%2Csf%3Dd%2Csid%3D%2257780217-be3c-4569-82ed-12a22e5fb2f0%22%2Csu Backtrace: Traceback (most recent call last): File "", line 13, in File "/lib/python3.12/site-packages/requests/models.py", line 1021, in raise_for_status raise HTTPError(http_error_msg, response=self) requests.exceptions.HTTPError: 403 Client Error: for url: https://cbsi.live.ott.irdeto.com/widevine/getlicense?CrmId=cbsi&AccountId=cbsi&SubContentType=Default&ContentId=3GjFaScXISDwd29Zi0FNsb8aUhCeHzRg&CMCD=mtp%3D300%2Cot%3Dk%2Csf%3Dd%2Csid%3D%2257780217-be3c-4569-82ed-12a22e5fb2f0%22%2Csu -
Thanks again. But still unable to do it. Tried for days nothing seems to work
I'm afraid not, that's paid content.
https://forum.videohelp.com/threads/404993-Please-ONLY-ask-for-help-videos-that-everyo...ere-is-my-post
If you want, cbs.com is ok. Paramount plus no.--[----->+<]>.++++++++++++.---.--------.
