I've spend at least an hour today messing with various software (including avisynth for the dotcrawlplusplus script) trying to recreate the look of VHS. How does it look to you all and is there anything here you would improve?
Video source is haruhi suzumiya, which was the only one I had on my PC
That looks ok to me. Suitably ugly VHS-like... Be better if you could have fuzzy black borders down each side.
There was a package discussed about two years ago called "VHS effects"
https://forum.videohelp.com/threads/397802-VirtualDub-AVISynth-VHS-Effect-Script-Error
It needed some slight modifications to the script but the result was very good -
while mostly satisfied by it, I couldn't think of a way to make video have haloing (both the chromatic and unsharp masking ones).
Does anyone know how to do it? -
also the process for this output was kinda complicated and insanely slow:
1. getting the 1080p bluray source into the premiere pro
2. in there making the colours worse and tinted as well as blurring chroma channels (especially the blue one).
3. rendering the video in downscaled 480p24
4. extracting the blue channel out of the 480p video and putting it into a different sequence, this time in 480i29.97
5. adding vhs noise (sourced from black scenes from some high quality MPEG2s I happened to own)
6. rendering a 480i video with noisy blue channel
7. applying dotcrawlplusplus onto the video
8. getting video back into the premiere, adding some more noise, this time onto all channels,
9. importing the rendered 480i into virtualdub and deinterlacing it with blend method, in order to hide all even slightly jagged edges
MPEG2 artefacts degrading visuals
By beep_boop_iamrobot in forum Capturing and VCRReplies: 1Last Post: 22nd Sep 2022, 04:20 -
Replicating the look of analogue video - combing and rainbowing
By rrats in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2022, 02:26 -
Chroma Shift creates artefacts
By phelissimo_ in forum RestorationReplies: 0Last Post: 19th Sep 2021, 06:49 -
Avisynth artefacts around edges
By pm-s in forum EditingReplies: 4Last Post: 10th Jul 2021, 06:44 -
weird interlacing/deinterlacing artefacts
By phelissimo_ in forum Video ConversionReplies: 11Last Post: 1st Jan 2021, 09:57
