Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 64
  1. Browser console code:
    function Uint8ToString(u8a){
      var CHUNK_SZ = 0x8000;
      var c = [];
      for (var i=0; i < u8a.length; i+=CHUNK_SZ) {
        c.push(String.fromCharCode.apply(null, u8a.subarray(i, i+CHUNK_SZ)));
      return c.join("");
    var u8 = new Uint8Array([42, 172, 97, 96, 19, 241, 135, 118, 25, 175, 138, 192, 26, 191, 240, 166]);
    btoa(Uint8ToString(u8));
    [Attachment 67172 - Click to enlarge]
    Code credits: stackoverflow
  2. You can use hlsdl to download the video.
    import re
    import base64
    import requests
    from Crypto.Cipher import AES
    import binascii
    import os
    def _decrypt_key(data):
        tmp1 = data[0:16]
        tmp2 = data[32:48]
        dec1 = AES.new(base64.b64decode(spka),AES.MODE_ECB)
        tmp3 = dec1.decrypt(tmp1)
        dec2 = AES.new(tmp3,AES.MODE_ECB)
        return dec2.decrypt(tmp2)
    headers = {'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/105.0.0.0 Safari/537.36', 'Referer': 'https://www.futurly.com/'}
    url_base = input("Enter URL index m3u8 : ")
    spka = input("Enter the spka : ")
    match = re.search(r"(https?://.*\/)", url_base)
    url_stream = match.group(1).strip()
    r=requests.get(url_base, headers=headers)
    matchs = re.findall(r"(h.*m3u8)", r.text)
    video = url_stream+matchs[-1]
    r=requests.get(video, headers=headers)
    matchs = re.search(r"AES-128,URI=\"(.*)\"", r.text)
    uri_url = url_stream+matchs.group(1).strip()
    res = requests.get(uri_url)
    res.encoding = "binary/octet-stream"
    key_data = _decrypt_key(res.content)
    base64_key = (base64.b64encode(key_data).decode('utf-8'))
    hex_key =(binascii.hexlify(key_data).decode('utf-8'))
    os.system(f'hlsdl -K {hex_key} -o file_output.mp4 -b "{url_base}"')
  3. Aaaand here are our heroes.
    Thanks guys.
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  4. nxhda
    Sep 2022
    import re
    import base64
    import requests
    import binascii
    import os
        tmp1 = data[0:16]
        tmp2 = data[32:48]
    This is useful, thank you!
  5. thanks dark125, a really useful tip!
    but where can find spka value?
    @ NBA456017
    stupid question: how to have all value on right windows as your shot on your post#14?
    which browser or which setting you have used for this?
    with mouseover i can see all value, but it's not comfortable.i have this only (tested on brave and FF)
    [Attachment 67178 - Click to enlarge]
  6. Click the 3 dots in the upper right corner and choose dock side
    spka is here, I guess?
    [Attachment 67179 - Click to enlarge]
    click click2
  7. nxhda
    Sep 2022
    @ NBA456017
    look here
  8. thanks NBA456017 i know how to find this value with CTRL+F
    my question is another: on your post#14 you have 3 window: folder tree, window code, and on right side another window. how to have this window ?
    [Attachment 67183 - Click to enlarge]
    Feb 2022
    Search the forum first!
    edit
  10. nxhda
    Sep 2022
    That doesn't matter
  11. Originally Posted by whs912km View Post
    The easiest way is just by typing spka in the console =D
    [Attachment 67187 - Click to enlarge]
  12. thanks zack, nice tip
    @NBA456017
    it's a secret this window??
  13. Great job to all involved. Congrats.
  14. psaframe
    Mar 2021
    Algeria
    Very awsome job done by true heros.
    Thanks again guys...
    Jan 2022
    Peru
    guys help me, I'm getting error "Uncaught ReferenceError: spka is not defined" using on here https://bitmovin.com/demos/drm
  16. This is not AES128 Encrypted....
    You have to use mp4decrypt to decrypt the video
  17. nxhda
    Sep 2022
    widevine
  18. Member
    Jan 2022
    Peru
    How to decrypt after that I can able to download the audio and video file from the mpd "https://cdn.bitmovin.com/content/assets/art-of-motion_drm/mpds/11331.mpd" kindly help me to decrypt.
  19. nxhda
    Sep 2022
    --key ccbf5fb4c2965be7aa130ffb3ba9fd73:9cc0c92044cb1d694 33f5f5839a159df
    --key 9bf0e9cf0d7b55aeb4b289a63bab8610:90f52fd8ca48717b2 1d0c2fed7a12ae1
    --key eb676abbcb345e96bbcf616630f1a3da:100b6c20940f779a4 589152b57d2dacb
    --key 0294b9599d755de2bbf0fdca3fa5eab7:3bda2f40344c7def6 14227b9c0f03e26
    --key 639da80cf23b55f3b8cab3f64cfa5df6:229f5f29b643e2030 04b30c4eaf348f4
  20. @ NBA456017
    simply suggestion: if you add keys into tag code tag
    [Attachment 67404 - Click to enlarge]
    avoid having spaces after 50 characters as the default forum add
  21. nxhda
    Sep 2022
    @ NBA456017
    ok
  22. Member
    Jan 2022
    Peru
    appreciate your help, could you please share the process of getting the keys.
  23. OMG You guys are amazing!! I've been working for 3 weeks nonstop on this exact same issue! Thank god I found this post when I almost gave up, its never too late I hope.
    So I wrote a detailed error report here. I used Streamlink and I posted the original js player, deobufscation, and my custom plugin
    https://github.com/streamlink/streamlink/discussions/4947
    I also attached my plugin below (change cloudfront.net to .py)
    Its the same website from this post with video host cloudfront, my spka = "OThlMzVkNzQ1NDEyNjliNQ==" (line 21 in cloudfront.py posted below)
    Panda's comment in that post was helpful but the solution was a little broad. (I also donated to them so hopefully got solved eventually lol, but probably by me lol)
    So the Error is Padding is incorrect while decrypting segment
    I think it probably has to do with Line 49 of cloudfront.py which pad the iv
    iv = b"\x00" * (16 - len(iv)) + iv
    I wrote this plugin and this line based on green cats code from https://github.com/streamlink/streamlink/issues/2253
    I wonder how can I modify it at this moment, is this line another layer of decryption that I need to find in the original player.js?
    Thank you so so much. I promise I'll help everyone else here with this issue in the future after I figure it out (which I'll just share my whole build of streamlink)
    @[ss]vegeta @zackmark29 @dark125
  24. Thank you guys so much
  25. Banned
    Jan 2023
    Mumbai
    i think this works
    Find the spka on Futurly web and replace it in the script:
    import re
    import logging
    import base64
    import argparse
    from streamlink import StreamError
    from streamlink.plugin import Plugin
    from streamlink.stream import HLSStream
    from streamlink.stream.hls import HLSStreamWriter, HLSStreamReader
    log = logging.getLogger(__name__)
    spka = "REPLACE"
    class FuturlyStreamWriter(HLSStreamWriter):
        def _decrypt_key(self,data):
            tmp1 = data[0:16]
            tmp2 = data[32:48]
        def create_decryptor(self, key, sequence):
            if key.method != "AES-128":
                raise StreamError("Unable to decrypt cipher {0}", key.method)
            if not self.key_uri_override and not key.uri:
                raise StreamError("Missing URI to decryption key")
            key_uri = self.key_uri_override if self.key_uri_override else key.uri
            if self.key_uri != key_uri:
                res = self.session.http.get(key_uri, exception=StreamError,
                                            retries=self.retries,
                                            **self.reader.request_params)
                self.key_data = self._decrypt_key(res.content)
                self.key_uri = key_uri
            iv = key.iv or num_to_iv(sequence)
            # Pad IV if needed
            return AES.new(self.key_data, AES.MODE_CBC, iv)
    class FuturlyStreamReader(HLSStreamReader):
        __writer__ = FuturlyStreamWriter
    class FuturlyStream(HLSStream):
        def open(self):
            reader = FuturlyStreamReader(self)
            reader.open()
            return reader
    class Futurly(Plugin):
        url_re = re.compile(r"""https://d2qny97nu4rj64.cloudfront.net/.*.m3u8""")
        def __init__(self, url):
            super(Futurly, self).__init__(url)
        @classmethod
        def can_handle_url(cls, url):
            return cls.url_re.match(url) is not None
        def _get_streams(self):
            return {"live":FuturlyStream(self.session,self.url)}
    __plugin__ = Futurly
    not working now. Putting correct spka value but giving ' padding is incorrect error'. Can you help?
  26. Originally Posted by dark125 View Post
    i think this works
    import re
    import logging
    import base64
    import argparse
    spka = "REPLACE"
            tmp1 = data[0:16]
            tmp2 = data[32:48]
            # Pad IV if needed
        def open(self):
            reader.open()
            return reader
        @classmethod
    [Attachment 68696 - Click to enlarge]
    Is anyone able to assist with downloading AES-128 videos from CloudFront, as there seems to be no SPKA in the console?
  27. hey guys they have removed spka can anybodu know how to get spka from this url??
    https://www.durgasoftonline.com/s/preview/courses/Core-Java-5e6e5cc40cf208a88ca3191d
  28. psaframe
    Mar 2021
    Algeria
    Here we are again. another scammer & indian seller.
    try to fish elswhere.
