Page 4 of 4
FirstFirst ... 2 3 4
Results 91 to 102 of 102
  1. @2nHxWW6GkN1l916N3ayz8HQoi ever shared a script on this forum and it is still there if you search his thread, that is the correct method do vdocipher. for diazole's script, if you read his code, you will find his method is correct too, but not suit for all vdocipher protected sites.
    another problem is CDM, they will check if you download many courses probably, if yes they will ban your CDM.
  2. Originally Posted by shellcmd View Post
    Are you talking about this script? https://forum.videohelp.com/threads/413153-Decryption-fails-with-keys#post2720615
    I looked at both scripts and it seems that they basically do the same thing, no? What could be different between different vdocipher sites?
    By the way, right now I'm just trying to use my extracted CDM to download the free video at https://www.vdocipher.com/blog/2014/12/add-text-to-videos-with-watermark/ and I'm failing :/. I think for that video diazole's script should work, no? What could I be missing here?
    Could there be some flag in the dumped CDM that disqualifies the device itself or something? The device is running a non-stock ROM and it is rooted.
  3. Originally Posted by pupsik View Post
    I finally managed to dump a CDM from Android 10, but I end up getting the same auth error when using Diazole's vdocipher.py script (https://github.com/Diazole/vdocipher-dl):
    Failed getting license response:
    {"code":2048,"message":"Authentication failed"}
    I can't figure out what I'm doing wrong. I properly block the auth requests in the browser -- the video says "6007. Unable to connect to license server. Try removing adblock or try different internet connection.". I then use the token in Diazole's script and I get the error.
    Can anyone please try using the script to see whether I'm the only one who has this problem, or something changed on vdo's end and the script no longer works?
    That script is 2+ years old and doesn't work anymore as is.
  4. Can someone fetch me the keys for this: https://jfc.org.il/en/news_journal/60654-2/101977-2/
    Thx!
  5. Originally Posted by ZangetsuZero View Post
    Thx!
    Get keys...
    0f071299c46a5ba5b176f82538fb6d0f:dcd4b9c549ba51f38 20337c29e50a7b7
    0957816beb7c510f82f05e7941a801ae:3cce266bec352afbf d39c38f8474aebd
    3922917ccfd6586785da4bb48fe3f341:df92e296ffda83735 5f6c141444b24c2
    a868e40ba5125c4c90a44fdece8847d0:4ceaf2e816f2a5a39 7f0b589186e1a37
    Total keys: 4
  6. Originally Posted by ZangetsuZero View Post
    Thx!
    Get keys...
    Total keys: 4
    Mar 2024
    Bihar,India
    Originally Posted by sahilflash View Post
    yes i tried with some wrong tokens but i didn't posted my CDM to the internet.. and bro which demo site you are talking about? and i in case my cdm revoked how can i fix this.. i dont have any other android device
    Ring vdocioher support and ask them to unban you
    Or..
    Learn from your mistakes, get new cdm. Then Don't burn new one.
    For new cdm if you install a different android os on your phone it will probably give you a new cdm since it's software generated. I believe it's possible to get multiple different cdms also if you get one from browser and one from different apps also but haven't tried this myself to confirm.
    thanks, i generated new cdm with different app.. and now it is working fine
    With which apps did you generate the old and new CDMs?
    I generated mine with Chrome on an Android device but I now suspect the CDM is revoked by vdocipher. I tried generating a new dump using Firefox and Opera but have not been successful.
    use android app which plays drm videos it will work, dont generate cdm with browser, cdm generated with browser will not work as i tried it many times, and, i dont know why but i keep getting blocked by vdocipher , currently my 5 cdms are blocked by vdocipher , so i have to keep generating new cdms with different apps, and if you still facing problem you can contact me on telegram @nik66
    what will happen if CDM dumped from my phone is blocked, will videos not play on my phone??
  8. Is the script still working? I have it worked 2 years ago, but trying to get some encrypted news videos, but using the script returns KeyError: 'license'.
    I wonder if my old CDM is not usuable anymore?
    Nov 2022
    pakistan
    Hy bud, did you find any solution? Please help I have got myself university videos to decrypt they take full money but only allow access until the end of seamster after that the videos are gone for good. This is very annoying as I want to study on my own terms.
    Please help
  10. Originally Posted by streetf22 View Post
    Can someone help me with keys to: https://jfc.org.il/movie/45184/
    your keys
    58a98ca1b30157169850395378c88b83:a60475567a1e8f24de0f92f8f3ba3ba1
    d4430a35961a5213b2fd0f4b58fde8c7:cd7095da49ee118f12297bfffacf7800
    1c0f9b36fe8f5238b13268c2e731bd04:6d7958432cc99430de259516510023d1
    3a0e548c25ec58d7b9030de04f924e4e:32b36d8e1e7ca686052893aa95393e5e
    you can easily obtain these keys with WidevineL3 Guessor and Real cdm
    https://forum.videohelp.com/threads/414140-%5BRelease%5D-Widevine-L3-Guesser-Extension...-Chrome-All-OS
  11. Originally Posted by cedric8528 View Post
    your keys
    Thank you, Real CDM is the problem
