Hello,
I would like to know if it is possible to have the file in 1080p and not in 720p
MPD : https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/6057955896001/d...I5OTA4Mg%3D%3D
Link : https://www.toggo.de/spongebob-schwammkopf/folge/das-krosse-kittchen-das-ananas-wohnmobil-vep11784
I would like to point out that I am a beginner in this field and that I don't know it very well.
Whether you can get 1080p with a L3 CDM depends on the streaming service. Most will only serve up to 720p for an L3 client. Generally speaking, for 1080p and better you need an L1 CDM - which you can forget about obtaining.
I did many audio-video-subtitle decryptions but I am still a beginner, too. There are so many things to learn.
As darkw4v3 said, it's the streamer's choice. But you can find many L3-protected contents in 1080p. Because every Android device and every computer on this earth, let you watch L3-protected contents. And that guarantees the maximum audience number for the streamer.
L1-devices are the minority. L1-devices are not very cheap for everyone to buy. If a streamer completely moves its HD contents into L1 protection, it can lose a serious number of audience.
According to my experiences, even the most popular streamers like NFlix, are using L3 for 1080p contents. For each content, I noticed two 1080p streams incoming, one of them with a higher bitrate with a different encoding profile (I mean AVC profiles, Main-High) and with L1 protection, the other one with a lower bitrate with L3 protection.
So, you don't need to think like "Forget 1080p if you don't have a L1 CDM".
And it is also said that all UltraHD contents are protected with L1 and/or PlayReady. But you can also find L3-protected Ultra HD contents (I found on MUBI). Yes, they are rare, but they exist.
So, we don't really have to match L1 only with HD&UHD, L3 only with SD... It changes site to site, content to content.
It is a little bit complicated "look and see" event. You should try it by yourself and discover the background.
Can download 720p but not 1080p from Noovo.ca
By kalemvar1 in forum Video Streaming DownloadingReplies: 18Last Post: 2nd Apr 2023, 14:03 -
How to download from zee5 site and download mpd link
By qasem1368 in forum Video Streaming DownloadingReplies: 7Last Post: 25th Nov 2021, 22:28 -
Video in 1080p, Srt in 720p
By Morton54 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2020, 18:59 -
For same bitrate which looks better between 720p and 1080p
By iKron in forum Newbie / General discussionsReplies: 34Last Post: 18th Dec 2019, 12:52
