Results 1 to 24 of 24
  1. Hi, i get the key from getwvkeys from stream.mpd but im trying m4decrypt but it doesnt work, i dont know what to do. I downladed the video, get pssh and get the key and descrypt but VLC cant play it. Thanks!!
    this is the stream.mpd: https://dmf9cnjua2s32.cloudfront.net/media/Rv0JJTO1G4zg0/4756790b/stream.mpd
  2. Try to decrypt with shaka packager
    syntax is something like this
    packager-win.exe in=aa.webm,stream=video,output=aa_dec.webm --enable_raw_key_decryption --keys key_id=92af6bfcf1ba0f834e8d793ee3453715:key=8be5d4d41c21c8c07f6d6da91a80be0c
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  3. Now i can see something but still encrypted because i cant see anything only this:
    [Attachment 66444 - Click to enlarge]
    Im gonna still searching
  4. You get wrong keys prolly cuz you used wrong license url. Inspect better and find the right license url.
    click click2
  5. thanks i will do it
  6. i can see my mistake i dont have the right pssh. On the console of google chrome i cant find the PSSH for this alert: Feature Policy: “encrypted-media”, and i cant find widevine too. with pssh on the mpd file i get :Cached Key, the KID and No key founds..... TT
    May 2022
    Chile
    The PSSH that is in the mpd seems correct, your problem is in the license url.
    Did you try generating PSSH with the KID?
  8. Originally Posted by Sebast94 View Post
    i found a lincese with the name "auth" on chrome inspection and it gots a header: https://license.vdocipher.com/auth
  9. doestn work on getvwvkeys..says key no found
    May 2022
    Chile
    It won't work for you, based on what I saw, that license url set json request (doesn't work with geywvkeys), you need to use a custom script.
    https://forum.videohelp.com/threads/403205-Get-KID-and-key-from-mpd-file
  11. Originally Posted by davidbdn1994 View Post
    Since you have access to getwvkeys, search the Discord, you should find a vdocipher script.
    click click2
  12. Originally Posted by [ss]vegeta View Post
    The token is very big, and i think it close for that when i put the auth and next the api key:
    [Attachment 66450 - Click to enlarge]
  13. Member DINAM's Avatar
    Sep 2021
    Rusia
    It is a video with two pairs of keys, it is a promotional video of 10 minutes,
    7dbda4cb8be85a459b09b2aadf42471a:73577a4df4e6b13131cab3282fd570d8
    ed1cc93c6c6f5c5fb089b2060909618d:4c52057653de7a825b5c0693c3ca44f9
  14. Now in Getwvkeys there is a place only for vdocipher, but vdocipher are killing the keys and they are considering to delete vdocipher from the website... They are saying to use your own keys, but I don't know where to start to get keys from vdocipher.
    Feb 2022
    Search the forum first!
    Surely you mean get your own CDM? Join the club; start here:- https://forum.videohelp.com/threads/404994-Decryption-and-the-Temple-of-Doom#post2650297
  16. Thanks I will start, the keys has expiration? And if so, how long does it expire?
    Feb 2022
    Are you referring to 'keys' as in the things you use to decrypt a media file? Or the thing you use to get the keys - i.e. a Content Decryption Module (CDM)?
  18. Member
    Feb 2022
    AFAIK the keys last for as long as the media is available from the particular provider. But why should it matter? You download media; get keys; and decrypt contemporaneously.
  19. Originally Posted by A_n_g_e_l_a View Post
    +10 points for using "contemporaneously"
  20. I have a problem The website there im gone to download videos has a protection, and you can only use one navigator and one IP, if i use onother system they can block me, i hope to solve the problem of vdocipher on getwvkeys... (The protection is for no share the account, not for download videos)
  21. Originally Posted by davidbdn1994 View Post
    I have a problem
    Indeed, you have. You are on your own mate!
    click click2
  22. Member
    Dec 2022
    algeria
    I have a problem
    hello guys
    i want getwvkeys to decrypt mpd live streams
    i cant verefied in getwvkeys ccthanks
  23. Originally Posted by boino2006 View Post
    hello guys
    Ask at the place where the issue is....getwvkeys
