Results 1 to 30 of 41
  1. This is the mpd
    <?xml version="1.0" encoding="UTF-8"?>
    <!--Generated with https://github.com/google/shaka-packager version v2.3.0-5bf8ad5-release-->
    <MPD xmlns="urn:mpeg:dash:schema:mpd:2011" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:mpeg:dash:schema:mpd:2011 DASH-MPD.xsd" xmlns:cenc="urn:mpeg:cenc:2013" profiles="urn:mpeg:dash:profile:isoff-on-demand:2011" minBufferTime="PT2S" type="static" mediaPresentationDuration="PT896.2333374023438S">
      <Period id="0">
        <AdaptationSet id="0" contentType="video" width="1280" height="720" frameRate="15360/512" subsegmentAlignment="true" par="16:9">
          <ContentProtection value="cenc" schemeIdUri="urn:mpeg:dash:mp4protection:2011" cenc:default_KID="4a7ecc5a-bb29-581b-a123-02896503050f"/>
          <ContentProtection schemeIdUri="urn:uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed">
            <cenc:pssh>AAAAUnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADIiKnZkb2NpcGhlcjo1MjA2MjRmOTg4NmU0NTZhOTE2NjVkNmQyZDQyYTdlNkjj3JWbBg==</cenc:pssh>
          </ContentProtection>
          <Representation id="0" bandwidth="60000" codecs="avc1.64001f" mimeType="video/mp4" sar="1:1">
            <BaseURL>video_7963_720_60.mp4</BaseURL>
            <SegmentBase indexRange="1025-2376" timescale="15360">
              <Initialization range="0-1024"/>
            </SegmentBase>
          </Representation>
          <Representation id="2" bandwidth="175000" codecs="avc1.64001f" mimeType="video/mp4" sar="1:1">
            <BaseURL>video_9065_720_175.mp4</BaseURL>
            </SegmentBase>
          </Representation>
        </AdaptationSet>
        <AdaptationSet id="1" contentType="audio" lang="en" subsegmentAlignment="true">
          <ContentProtection value="cenc" schemeIdUri="urn:mpeg:dash:mp4protection:2011" cenc:default_KID="c48a5fed-6d47-516b-b27d-18042c211073"/>
          <Representation id="1" bandwidth="90000" codecs="mp4a.40.2" mimeType="audio/mp4" audioSamplingRate="48000">
            <AudioChannelConfiguration schemeIdUri="urn:mpeg:dash:23003:3:audio_channel_configuration:2011" value="2"/>
            <BaseURL>audio_2325_0_90.mp4</BaseURL>
            <SegmentBase indexRange="984-2815" timescale="48000">
              <Initialization range="0-983"/>
            </SegmentBase>
          </Representation>
        </AdaptationSet>
      </Period>
    </MPD>
    I can see Pssh: AAAAUnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADIiKnZkb2 NpcGhlcjo1MjA2MjRmOTg4NmU0NTZhOTE2NjVkNmQyZDQyYTdl Nkjj3JWbBg==
    Also Default_KID: 4a7ecc5a-bb29-581b-a123-02896503050f
    Is default_KID the actual KID, in many mpd file i use https://tools.axinom.com/decoders/PsshBox to get KID , but here I get Content ID :
    Text- vdocipher:520624f9886e456a91665d6d2d42a7e6
    Bas16- 76 64 6F 63 69 70 68 65 72 3A 35 32 30 36 32 34 66 39 38 38 36 65 34 35 36 61 39 31 36 36 35 64 36 64 32 64 34 32 61 37 65 36
    Base64- dmRvY2lwaGVyOjUyMDYyNGY5ODg2ZTQ1NmE5MTY2NWQ2ZDJkND JhN2U2
    How to get the actual KID, and how to get the key?
  2. actual KID=Default_KID
  3. What is the token for https://license.vdocipher.com/auth ?
    {"token":"eyJvdHAiOiIyMDE2MDMxM3ZlcnNJTkQzMTNhelpaZHlBcGxMaTlJQ2ljT21DendNZU1XR2hlSVBGVlFPTzc5Yk40MEVVamdCIiwicGxheWJhY2tJbmZvIjoiZXlKMmFXUmxiMGxrSWpvaU1XRTFNalUxT0dJell6QmhORE14Wm1FeVl6STFNRFkwWldFM01UZzBOVFVpZlE9PSIsImhyZWYiOiJodHRwczovL3d3dy52ZG9jaXBoZXIuY29tLyIsInRlY2giOiJ3diIsImxpY2Vuc2VSZXF1ZXN0IjoiQ0FRPSJ9"}
    discord=notaghost9997
  4. Is content Id that I get from decoding from Pssh Box important ? Will it be used?
    I have had a hard look at this code (token).
    I have no idea where notaghost got it from. It is not a part of the manifest so I have to assume that he (assuming that notaghost is male) created it from data within the pssh.
    The pssh gives one piece of data, namely ...... vdocipher:520624f9886e456a91665d6d2d42a7e6
    What notaghost posted is base64 encoded json data
    {"otp":"20160313versIND313azZZdyAplLi9ICicOmCzwMeM WGheIPFVQOO79bN40EUjgB","playbackInfo":"eyJ2aWRlb0 lkIjoiMWE1MjU1OGIzYzBhNDMxZmEyYzI1MDY0ZWE3MTg0NTUi fQ==","href":"https://www.vdocipher.com/","tech":"wv","licenseRequest":"CAQ="}
    now we have two additional pieces of data
    "otp":"20160313versIND313azZZdyAplLi9ICicOmCzwMeMW GheIPFVQOO79bN40EUjgB"
    and
    "playbackInfo":"eyJ2aWRlb0lkIjoiMWE1MjU1OGIzYzBhND MxZmEyYzI1MDY0ZWE3MTg0NTUifQ=="
    Decoding the playbackInfo, we get
    "playbackInfo":"{"videoId":"1a52558b3c0a431fa2c250 64ea718455"}"
    This is as far as I got.
    Need to figure out how to move from "videoId":"1a52558b3c0a431fa2c25064ea718455" (as per notaghost ) to vdocipher:520624f9886e456a91665d6d2d42a7e6 (as per the pssh).
    Also, "otp":"20160313versIND313azZZdyAplLi9ICicOmCzwMeMW GheIPFVQOO79bN40EUjgB" <== where does this come from? Is this a constant or variable?
    Or maybe this post by notaghost is a red herring.
  6. Not misleading you can find that information when you play the vdocipher video in network tab of developer tool
    https://ibb.co/yhwTjST
    It is required to get content keys.
    OK, the plot thickens
    Notaghost said "you can find that information when you play the vdocipher video"
    OK, we have an attached picture to prove it. Thanks Notaghost.
    All that I have is the first post by Deshdeepak which is a reference to a mpd manifest file. A reference to a referrer url cannot be found within the context of this file.
    All we have is a reference to Content ID :vdocipher:520624f9886e456a91665d6d2d42a7e6
    So, how can we derive the the vdocipher video url from 520624f9886e456a91665d6d2d42a7e6?
    @Deshdeepak, can you please post the referrer (top) url for which this mpd file applies? Thanks
    I figured out that the referrer url is as per "href":"https://www.vdocipher.com/"
    but this referrer is from the decoded json token
    This video?
    [Attachment 60945 - Click to enlarge]
    [Attachment 60946 - Click to enlarge]
    Still do not know how Notaghost could get this url from the mpd manifest in post #1.
    I realize that Notaghost is brilliant but this is bordering on the Amazing Kreskin territory.
  9. Originally Posted by jack_666 View Post
    This has been done to death on here and another thread tells all, but no one wants to search any longer. Just demand answers in a new thread.
    And yes, Notaghost is good. But maybe fed up of spoon feeding people.
  10. Jack I sincerely love the way you write. Please continue to do so
  11. Code:
    e76ae17d861546be9c238e6582509c2c:de1a91e2306bf8442236a80477f526e1
  12. Originally Posted by hannc View Post
  13. How you get it the key? U dont need widevine key?
    Please tell me
    [Attachment 72661 - Click to enlarge]
    getwvkeys cached keys, they store many pssh and keys
  15. Yes i know it. But need url widevine. What the url?
    dont know?
    where did you get mpd from? there is license on inspect so find from there
  17. Hello, everyone! Can anyone help me please!
    I have a question is it possible to get KEY using MPD, KID and PSSH? I have license url, mpd, KID and PSSH.
    I don't know how to do that and also in getwvkeys.cc it says like this:
    {"code":400,"error":true,"message":"Failed to get license: 400 Bad Request"}
    Even everything is correct but I couldn't get the keys.
    mpd: https://exxen-vod.ercdn.net/otf/m/qb/konusanlar_s02b25_rev02/konusanlar_s02b25_rev02.s...usanlar-s2-b25
    PSSH: AAAANHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABQIARIQ4A/PkRIqT1mqdvIAZOkq7g==
    KID: e00fcf91122a4f59aa76f20064e92aee
    License: https://fasterius.ercdn.com/ues/client/get_summary?publicKey=b169b8b1fffbd0cc5d0b98b5058ba068
    Thanks in advance.
  18. Originally Posted by Hafiz View Post
    Thanks in advance.
    1. That might not be the proper license.
    2. Maybe you also need headers.
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
    Please can someone help me get the key for this mpd. thank you
    https://b46178-p52-h93-aefpwpov-tdd2f0d.1.cdn.telefonica.com/_46178/dash/2plus.isml/manifest.mpd
  20. Originally Posted by djcalmix View Post
    Link down, can you upload again your mpd and license please?
  21. Originally Posted by gwe202 View Post
    @gwe202
    link down? try again mate. this link is fully working (anyway no key found from pssh on database)
  22. Member
    url link? not mpd
  23. Member
    I said site video url not mpd
  24. Member
    Is movistar
  25. Is not a url...
  26. Originally Posted by djcalmix View Post
    Is movistar
    [Attachment 73738 - Click to enlarge]
    this what video url mean
    https://www.youtube.com/watch?v=tAGnKpE4NCI
    what is video url when you watch it on movistar?
