Can someone recommend a video converter that:
must have:
* Manually and freely define all encoding params
* Batch conversion
nice to have:
* CONVENIENTLY(*) define custom encoding profiles to re-use and edit later.
* Decent progress indication on batch & file operations
* split/merge/crop/rotate
Don't need:
* Anything beyond h264/5 codecs, mp4/mkv/avi containers
* Capture capabilities
* Bells, whistles, and a lot of bs that the most recommended converters tend to include.
(*) Believe it or not, some leading converters let you define only ONE custom profile / let you name profiles but not later edit or even view their specs / let you name profiles but can't later read name bcoz beyond ~12 characters the fancy UI does't show it / sometimes lets you define, and sometimes not - not clear why / return to default/built-in profile after each run or addition to cue. And so much more
If needed, I'll use a command line app with batch files, if this is what it takes..![]()
Only after posting this, (shame on me
) I did some more checking on this very forum and found FFmpeg-Batch developed by user Eibol in the last 9 years. From first tries it seems absolutely GREAT, for anyone who prefers functionality and control, over fanciness and the illusion that an app can make intelligent decissions instead of the user
Don't be scared of the FFmpeg command line parameters, which are generated automatically by the Parameter Wizard, and shown for advanced use only.
I'm leaving this post here, as it may be a good starting point for others.
Compressing PNG files into Video
By Chauceratemyhamster in forum EditingReplies: 8Last Post: 6th Jan 2025, 00:49 -
Syncing Audio and Video with Any Video Converter Ultimate Version 7.07
By sancarloscylist in forum Video ConversionReplies: 2Last Post: 8th Jan 2021, 18:26 -
video converter any video converter has basic settings video bit rate as -1
By jraju in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2020, 12:15 -
Is compressing your files even worth it anymore?
By stonesfan99 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2020, 11:49 -
Combining multiple Video files and compressing
By unknown in forum Newbie / General discussionsReplies: 10Last Post: 8th Nov 2018, 03:46
