Page 1 of 28
1 2 3 11 ... LastLast
Results 1 to 30 of 830
    Nov 2017
    Madrid, Spain
    Hi, I've been using ffmpeg in Windows for many years, and I always missed the convenience of some graphical interface to have drag and drop, file listing, batch processing, progress bar, the typical windows application features. I searched for something simple, because my operations are usually just stream copy to .mp4, .ts, convert to mp3, flac 16/44,1, convert video audio tracks to aac 2 channels, trimming, concatenating, also some video shrinking and resizing.
    The point is, all the similar programs that I tried are either too complex for just a few things I want to do, or they do not allow to use the parameters set of your choice, I'm somewhat limited to use predefined options.
    So, for advanced users that just miss the convenience of Windows Explorer, and at the same time want to have total control of ffmpeg behaviour, I started developing this application: FFmpeg Batch. Free and open source for anyone to try, beta but fully functional, compatible with Windows 7/8/10.
    https://sourceforge.net/projects/ffmpeg-batch
    My programming skills are limited. Any feedback very welcome.
    Aug 2013
    Central Germany
    It seems to be quite similar to TEncoder ... surely useful for people with similar needs.
    Nov 2017
    Madrid, Spain
    I have released a new version, with some bug fixes, better translation, and audio features like volume change, shifting, graphical waveform.
    Nov 2017
    Madrid, Spain
    New version 1.05 with stream mapping and mkv multiplexing.
    Single stream mapping and encoding.
    https://files.videohelp.com/u/273695/FFbatch_setup_1.05.msi
    Dec 2017
    Hi. I just tried using this to batch convert pairs of CDG+MP3 files to MP4, but I get Unhandled Exception when trying to add the first file ? Same issue occurs regardless of which mp3 is selected as the source.
    Doing a similar ffmpeg conversion from Windows 10 command prompt work ok.
    ffmpeg -i test1.cdg -i test1.mp3 -b:v 1M -y test1.mp4
    I can provide copies of the source files if this helps?
    Here is the error I'm getting:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentOutOfRangeException: Length cannot be less than zero.
    Parameter name: length
    at System.String.Substring(Int32 startIndex, Int32 length)
    at WindowsFormsApp1.Form1.openFileDialog1_FileOk(Obje ct sender, CancelEventArgs e) in C:\Users\Abel\ownCloud\FFmpeg Batch\FFBatch_Lview_Final\WindowsFormsApp1\Form1.cs:lin e 209
    at System.Windows.Forms.FileDialog.OnFileOk(CancelEve ntArgs e)
    at System.Windows.Forms.FileDialog.HandleVistaFileOk( IFileDialog dialog)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.2115.0 built by: NET47REL1LAST
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    FFBatch
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/EibolSoft/FFmpeg%20Batch/FFBatch.exe
    Win32 Version: 4.7.2110.0 built by: NET47REL1LAST
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    Win32 Version: 4.7.2046.0 built by: NET47REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Core
    Win32 Version: 4.7.2117.0 built by: NET47REL1LAST
    Nov 2017
    Madrid, Spain
    Hi, thanks for the input, it looks like file size it's not being reported correctly.
    You can try this modified 1.5.0.1 executable by replacing it on the installation folder.
    If you get the same result, test files are very welcome.
    https://drive.upm.es/index.php/s/PDpS6u8JgpZUbCq
    Regards
    Abel
    Dec 2017
    Still getting the same error. Zip attached containing the mp3 & cdg I'm testing with.
    Pete
    Nov 2017
    Madrid, Spain
    Hi again, I havent been able to reproduce the issue, I have added your files and could convert them successfully, results attached.
    Maybe the way of adding parameters for specific track encoding is not clear: if parameter is not "copy", -c:v or -c:a is then included, so since your are transcoding you need to add a codec like libx264, and then the bitrate parameter. You can see what I did it on the screenshot below. clearly the feature needs some work:
    [Attachment 44108 - Click to enlarge]
    Processed files: https://drive.upm.es/index.php/s/aVT4j0ijjMugkX9
    Since by default muxing is saved as mkv, I included version 1.05.2, that obtains file extension from main screen format textbox.
    Dec 2017
    Hmm. Not sure what's going on with my install, but I'm still getting the "System.ArgumentOutOfRangeException: Length cannot be less than zero." error.
    I've tried the software on both windows 7 & 10 laptops, but same issue. I also tried moving the source folder to a different location. I wonder if there's something conflicting in windows config ?
    Is there a particular version of .NET framework that should be installed ? Also is this 32 or 64 bit ?
    Nov 2017
    Madrid, Spain
    I think I found the issue, I was handling poorly the size decimal separator, since I assumed it was ",".
    Please remove your current version, delete the installation folder if you still have any custom exe file there and try this new version 1.1 with better
    size formatting:
    https://sourceforge.net/projects/ffmpeg-batch/files/FFbatch_setup_1.1.msi/download
    Thanks for your input and sorry for the inconvenience.
    Visual Studio .NET installer is not very good, but it should detect required dependencies, in this case .NET runtime 4.6.2. 64 bits. I leave the link for .NET 4.6.2 if required: https://www.microsoft.com/en-us/download/details.aspx?id=53344
    Last edited by Eibol; 26th Dec 2017 at 00:29. Reason: 64 bits / .net 4.6.2 / Found solution new version
    Nov 2017
    Madrid, Spain
    New version 1.1 with mp4 muxing support and solved runtime error while adding files due to wrong file size string handling.
    FFmpeg Batch 1.1
    Dec 2017
    This version now works for me, and file size errors gone - thanks.
    Couple of new questions:
    1) How to save the Batch Processing settings so I don't need to configure "libx264 -b:v 1M" and Eng Audio for every file ?
    2) The resultant MP4 plays fine in VLC with video & audio, but not in Windows Media where I don't see video ?
    Nov 2017
    Madrid, Spain
    Glad to know it works at last.
    For question one, those features are not implemented on current version yet, but on 1.2 they will be somehow available. I may provide a beta executable so you can have them earlier.
    Unlike VLC, Windows Media Player is rather "picky" with media files, so maybe you need to try other parameters until you find the ones that your such player version accepts. It maybe a color space limitation, so for improved compatibility, you may try adding this to your parameters set: -pix_fmt yuv420p
  14. I need help with 'How to convert OPUS audio of MP4/WEBM/MKV to MP3/AC3 without re-encoding video?'
    at this thread https://forum.videohelp.com/threads/386336-Dealing-with-OPUS-audio-of-MP4-WEBM-MKV#post2505812
    Installing FFmpeg Batch 1.1 gives the warning:
    This installation package is not supported by this processor type. Contact your product vendor.
    Sword is no substitute for kitchen-knife.
    Nov 2017
    Madrid, Spain
    Hi, maybe you have a 32 bits operating system and the product searches a 64 bits. You can find below a 32 bits installer that should work fine, try and let me know:
    FFmpeg Batch 1.1 32 bits: https://drive.upm.es/index.php/s/bVuxKEKZrfTbIJN/download
  16. Thanks.
    Installed. When used, gave this message: [screenshot attached]
    Please advise.
    Aug 2013
    Central Germany
    You cannot put VP8 video into an MP4 container, it does not belong to the video formats supported by the MPEG-4 standard.
  18. Originally Posted by LigH.de View Post
    Oops!
    Thanks.
    Will try MKV, instead.
    Can't find a preset with video copy and audio to 192k MP3.
  19. Created a new preset.
    It's working.
    Thanks.
    Nov 2017
    Madrid, Spain
    New version 1.2:
    - Added batch subtitling feature. Add videos and the application will search and mux subtitle files available on the same folder with the same name.
    - Added feature to save a default enconding for mapping and muxing tracks.
    - Solved issues with subrip subtitles encoding and mapping PGS subtitles.
    - Prevented unintended file overwriting ruining source file.
    - Minor bug fixed.
    64 bits: https://files.videohelp.com/u/273695/FFbatch_setup_1.2_x64.msi
    32 bits: https://files.videohelp.com/u/273695/FFbatch_setup_1.2_x86.msi
    FFmpeg Batch
    Last edited by Eibol; 2nd Jan 2018 at 05:10. Reason: typo, last-minute link update
  21. Thanks for update.
  22. Member
    Nov 2017
    Madrid, Spain
    You are welcome. Below new version with some bug fixes.
    Cheers
    Thanks for update.
  23. Member
    Nov 2017
    Madrid, Spain
    Update 1.2.2: Refinements and bug fixes on batch subtitling feature. Better warnings and compatibility between mkv/mp4 containers.
    32 bits: https://files.videohelp.com/u/273695/FFbatch_setup_1.2.2_x86.msi
    64 bits: https://files.videohelp.com/u/273695/FFbatch_setup_1.2.2_x64.msi
    FFmpeg Batch
  24. Member
    Nov 2017
    Madrid, Spain
    New version 1.3.1:
    - Redesigned interface now shows all process estimated remaining time. Fixed bug due to localization issues.
    - Added feature to include ffmpeg pre-input parameters, and easy pre-input seeking, for faster seeking operations.
    - Added feature to create a video using a still image and audio file.
    https://files.videohelp.com/u/273695/FFbatch_setup_1.3.1_x64.msi
    https://files.videohelp.com/u/273695/FFbatch_setup_1.3.1_x86.msi
    FFmpeg Batch
    Last edited by Eibol; 21st Jan 2018 at 17:43. Reason: New version to fix fatal error due to localization
  25. Member
    Nov 2017
    Madrid, Spain
    New version 1.3.1 in order to fix a fatal error due to time measurement localization and pre-input seeking buggy field.
  26. Member
    Aug 2013
    Central Germany
    The notorious "German decimal comma" issue?
  27. Member
    Nov 2017
    Madrid, Spain
    Now the opposite, english decimal point killing me
  28. I'm a MEGA Super Moderator Baldrick's Avatar
    No changelog for 1.3.2?
  29. Member
    Nov 2017
    Madrid, Spain
    Hopefully, all localization errors fixed.
    Ver 1.3.2
    - Added total time info.
    - Added total file list size info.
    - A few interface improvements.
    - Long term support version.
    https://files.videohelp.com/u/273695/FFbatch_setup_1.3.2_x64.msi
    https://files.videohelp.com/u/273695/FFbatch_setup_1.3.2_x86.msi
    FFmpeg Batch Converter
  30. Member
    Nov 2017
    Madrid, Spain
    Updated Screenshots, with comparison converting audio to mp3 using single thread, 46 seconds, vs N-threads, 13 seconds. (Only recommended for audio only conversions).
    [Attachment 44475 - Click to enlarge]
    [Attachment 44476 - Click to enlarge]
    Stream mux:
    [Attachment 44477 - Click to enlarge]
    Batch subtitling:
    [Attachment 44478 - Click to enlarge]
