Am new to Video Downloaders so do not know all the correct terminology. Tried to search both the VH Forum and Google using key words "video downloaders" can capture "soft subtitles" but for both got nothing relevant so must be doing something wrong.
Would like to capture the English soft subtitles for Shoshana Zuboff on surveillance capitalism | VPRO Documentary https://www.youtube.com/watch?v=hIXhnWUmMvw which is excellent!
I posted this as "Portable Windows Video DownLoader & SubTitles?" https://forum.videohelp.com/threads/406420-Portable-Windows-Video-DownLoader-SubTitles
videobruger recommended using yt-dlp.
I downloaded it but got nowhere because am totally new to trying to use cmd with Windows 10.
Had no problems using FireDM portable but it is No longer developed. https://www.videohelp.com/software/sections/video-streaming-downloaders
Think at this time it is best for me to stick to GUI Video Downloaders.
Appreciate any recommendations for GUI Video Downloaders that Can Capture Soft Subtitles.
But it's so fun, and easier when you get the hang of it.
Here, check this
https://streamable.com/qx815r
Code:ytdlp.exe --write-subs --skip-download "https://www.youtube.com/watch?v=hIXhnWUmMvw"
If we want video/audio we just don't use --skip-download. Then, ytdlp will download best quality automatically.
If we want video/audio in different quality, then we use the -F to see what quality is available
Code:ytdlp.exe --write-subs -F "https://www.youtube.com/watch?v=hIXhnWUmMvw"
Code:ytdlp.exe --write-subs -f 137+140 "https://www.youtube.com/watch?v=hIXhnWUmMvw"
[ss]vegeta
"But it's so fun, and easier when you get the hang of it. Here, check this https://streamable.com/qx815r"
Checked the video, my problem is it is totally unfamiliar which is why I would like to use a GUI for now.
Have done a number of searches but so far nothing relevant.
Instead get "It looks like there aren't many great matches for your search" so am doing something wrong.
Would be nice if there was a list of functions for yt-dlp GUIs.
Also seems like there are others having problems. ex "Hi can someone eli5 how to get yt-dlp working on windows 10" https://www.reddit.com/r/youtubedl/comments/u4cc3m/hi_can_someone_eli5_how_to_get_ytdlp_working_on/ -
Just adding my 2¢ worth...
I used to use GUIs all the time, specifically youtube-dl-gui, because I'm going blind and had problems seeing text on command lines, but some of the members here (including [ss]vegeta) changed my mind about them. The good thing about yt-dlp is that you can put a command into an old school DOS batch file and it works fine. Here's an example of one I use regularly:
Code:@echo off cd Movies yt-dlp.exe --output %%(title)s.%%(ext)s http://path_to_video pause
--ap-mso your_streaming_service_name --ap-username your_username --ap-password your_password
If they store your login in a cookie you can add:
--cookies c:\path_to_cookie_folder\cookies.txt
You can see what formats are available for a video with:
--list-formats
Once you know what is available, you can specify a specific format with:
--format format or --format hls-xxxx
or
-f "best[height=1080]" or -f "best[height=720]"
Create a subtitle file:
--write-sub
Subtitle format:
--sub-format format
There are many more in the youtube_dl manual, including more subtitle options. I put several different commands in a text file, like this:
yt-dlp.exe -f "best[height=720]" --output %%(title)s.%%(ext)s
yt-dlp.exe --format hls-xxxx --output %%(title)s.%%(ext)s
yt-dlp.exe --cookies c:\mp3\2\cookies.txt --output %%(title)s.%%(ext)s
yt-dlp.exe --cookies c:\mp3\2\cookies.txt -f "best[height=720]" --output %%(title)s.%%(ext)s
Then copy whatever I need to put in a batch file. Personally, I find this much better than a GUI, because when I edit links in a text file, I can see what I'm doing much better.
You can put as many links as you like (one per line) in a batch file, but I stick to 5 at a time and not too many blocks of 5 in one session, because I think downloading dozens of videos in the time it takes to watch one attracts unwanted attention from system administrators who swing the Ban Hammer...
Give it a try... You might like it!
Ax
Video Downloaders - Android
By eager to learn in forum Video Streaming DownloadingReplies: 23Last Post: 24th Apr 2022, 17:38 -
Can anyone recommend a decent PCI-E capture card with S-Video & RCA inputs?
By bergqvistjl in forum Capturing and VCRReplies: 5Last Post: 6th Nov 2020, 16:08 -
Video Downloaders are not working any more. Are there any that still work?
By valhalla in forum Video Streaming DownloadingReplies: 9Last Post: 24th Apr 2020, 10:09 -
Recommendations Portable Reddit Video DownLoaders?
By KermitJ in forum Video Streaming DownloadingReplies: 5Last Post: 25th Jan 2020, 12:11 -
how to extract subtitles from soft-sub mega video?
By sarksi_yol1 in forum SubtitleReplies: 0Last Post: 2nd Jul 2019, 13:11
