I would be so grateful for help.
I now have a bin of useless cables and gadgets from Amazon. Notrhing seems to work.
One the source side:
Hitachi VM-825LA 8mm video camera. The outputs are some weird square plug socket for a cable that is long gone, and no one sells; and Yellow and white RCA composite out.
On the receiving side:
Macbook Air, with its $%^& Thunderpots, I mean Thunderbolt inputs, which are generally incompatible (USB, HDMI DVI, etc). Or:
An an old Windows machine running windows 10 that might has only usb ports for video in. i don't know if the graphics card is adequate.
One lost expenditure was a small box with a mini SD in it. They didn't tell me it reduced my 8mm to VGA. No other format. That's real blurry.
* Is there a chain of devices that will lead from RCA Composite to some kind of storage medium?
daVinci Resolve won't recognize this camera. If I get it into Mac and iMovie don't I suffer unacceptable loss of resolution after going through the 400/800 firewire converters
Please help! Memories of my first- and only- born are on the line!
Look at the recent threads in the capture forum.
https://forum.videohelp.com/threads/406066-What-is-best-capture-device
For most this kind of USB device works well
https://www.amazon.com/DATA-connection-video-capture-GV-USB2/dp/B00428BF1Y/
This may be Windows only -
If it has firewire out then easiest to just buy a firewire card and go that route. WinDV or ScenealyzerLive for transfer.
If not then you're gonna need to go down the rabbit hole of USB capture cards.
Or pick up a Sony D8 cam that can do analog playback and has firewire and use that.
Hitachi vm-h825la Hi8 Camcorder Horizontal Lines
By Tarack in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Jun 2022, 00:15 -
TDK 8mm HS90 not working on Hitachi VM-E648LE?
By alexxci in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 16th Aug 2021, 00:30 -
What is recommended for a good 8mm camcorder for capturing video?
By jadoggin in forum Capturing and VCRReplies: 8Last Post: 7th Nov 2019, 12:23 -
8mm old camcorder help
By vdubz in forum Capturing and VCRReplies: 6Last Post: 31st May 2018, 00:52 -
8mm Camcorder Playback Distortion?
By kamkorder in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 31st Dec 2017, 20:16
