Results 1 to 30 of 30
  1. someone leaked this in telegram.
    t.me/getwvkeys
    notaghost#9997
    plus a 1gb key cache in there.
  2. i'm not able to open the link pls help
  3. thats really bad, is it WKS/Freyja doing this? why ruin such nice service
  4. are they gonna leaked cdmdb aswell?or sell it to people?
  5. Originally Posted by olmads View Post
    Why do you think this will ruin it?
    I don't think so. Most of the stuff is public anyway.
    I don't think this will have any effect on the site nor do I think notaghost and the others involved with the site will care about this.
    Hardly doubt so. Also hardly doubt they got those.
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  6. Originally Posted by luvmichelle View Post
    its a telegram link
  7. Originally Posted by [ss]vegeta View Post
    well, im curious about how they got to key db
  8. Originally Posted by PUOPUO View Post
    Nothing spectacular.
    Maybe notaghost will tell here.
    click click2
  9. Originally Posted by [ss]vegeta View Post
    they said it was publicly given, good
  10. Originally Posted by luvmichelle View Post
    https://cyberfile.is/7y4/GETWVKEYS-source-code-main.zip
    https://cyberfile.is/7y5/keys.db
  11. Originally Posted by id0ntcar3 View Post
    thank you so much
  12. We need an expert to tell us what these are good for.
  13. Maybe for someone who have nothing to do all day and parse db keys )
  14. search locally for cache keys via KID
    sqlite3 keys.db "SELECT keys FROM DATABASE WHERE KID == '6c5c7d3b45af3de7beb2e8f07c9b4a00';"
    search locally for cache keys via pssh
    sqlite3 keys.db "SELECT keys FROM DATABASE WHERE pssh == 'AAAAbXBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAAE0IARIQv Oisat93mhzMKRdzYYDMjxoIY2FzdGxhYnMiJGV5SmhjM05sZEV sa0lqb2lZMnhwY0Y4eE1qa3hNekk1TlNKOTIHZGVmYXVsdA==' ;"
  15. Excellent, thanks Jack.
    click click2
  16. That's great.
    Let's make the beginners understand it.
    1- Download Precompiled Sqlite Binaries for Windows and extract the contents to the same folder:
    https://www.sqlite.org/2022/sqlite-dll-win32-x86-3380500.zip
    https://www.sqlite.org/2022/sqlite-tools-win32-x86-3380500.zip
    You will end up with 5 files in that folder (sqldiff, sqlite3.def, sqlite3.dll, sqlite3, sqlite3_analyzer)
    2- Add Sqlite to Path. It doesn't have to be "C>Sqlite". Put the folder wherever you want, just don't forget to add that location to Path.
    "Control Panel > System > Advanced System Settings > Environment Variables".
    Double click the "Path" item from User variables. Click on "New", enter location.
    If you have a Path already, just modify it and add Sqlite location. Do not create another Path value, because it will replace the previous one (Your Python path would be removed, for example)
    3- Put "keys.db" file to that Sqlite folder. Then you can make your searches via Command-Prompt or Powershell.
    Powershell needs a "./" at the beginning of the command. Like that:
    ./sqlite3 keys.db "SELECT keys FROM DATABASE WHERE KID == '6c5c7d3b45af3de7beb2e8f07c9b4a00';"
    Good luck.
  17. Thank you @ridibunda;
    I download also DB browser,
    and i edit DB keys and add mines key that i dont found.
  18. I don't get the point, sorry. This database cannot contain a key for EACH pssh, can it? So for what cases is this meant?
  19. tis DB work offline mode @Quint,
    is normal to be limited , i found inside more than 400.000 keys. Well i try to download a movie...and surprise , i didn't found so i use other way to get keys.
    Feb 2022
    Search the forum first!
    sqlite> select count(KID) as count FROM DATABASE;
    Gives 403466 unique KID's with their pssh and keys. And all you need to do is check if your kid is in there among nearly half a million others. Seems worth it to me.
  21. Thanks guys. I did all the steps. How do I start downloading stuff now?
  22. Originally Posted by shampistols69 View Post
    You jump out of nowhere in this thread. You are not the thread starter nor do you have other posts in this thread.
    Downloading what? From where?
    Read the other threads of this sub-forum and if you don't find explanations, open a new thread.
    Downloading is usually done with yt-dlp.
    You did all the steps of what? Managing the keys database?
    Even though there are 400k + keys, doesn't necessarily mean they will match what you wanted to download.
    click click2
  23. Member
    Feb 2022
    There is a lot of junk in the keys.db database that is not accessible from the usual SQL commands.
    For instance some of the headers included in the call to the getwvkeys.cc api are there.
    {"accept": "*/*", "accept-encoding": "gzip, deflate, br", "accept-language": "ja,zh-TW;q=0.9,zh;q=0.8,en-US;q=0.7,en;q=0.6", "content-length": "4277", "origin": "https://www.hulu.jp", "referer": "https://www.hulu.jp/", "user-agent": "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/98.0.4758.102 Safari/537.36"}
    {"Connection": "close", "Content-Length": "234", "Accept-Encoding": "gzip", "Cf-Ipcountry": "TW", "X-Forwarded-For": "118.161.39.187", "Cf-Ray": "6e555cda7c537c5f-LAX", "X-Forwarded-Proto": "http", "Cf-Visitor": "{\"scheme\":\"http\"}", "User-Agent": "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36", "Accept": "*/*", "Content-Type": "application/json", "Cf-Connecting-Ip": "118.161.39.187", "Cdn-Loop": "cloudflare"}
    "Connection": "close", "Content-Length": "319", "Accept-Encoding": "gzip", "Cf-Ipcountry": "US", "X-Forwarded-For": "2001:19f0:4400:60aa:5400:3ff:fea5:c30", "Cf-Ray": "6eebec312a134c53-SIN", "X-Forwarded-Proto": "https", "Cf-Visitor": "{\"scheme\":\"https\"}", "Content-Type": "application/json", "Cf-Connecting-Ip": "2001:19f0:4400:60aa:5400:3ffxxxxx", "Cdn-Loop": "cloudflare"}
    It is not good news for users, though, as some bare IP address are shown; as in the above example -i.e 118.161.39.187. And googling what 'Cf-Connecting-Ip' is gave "CF-Connecting-IP provides the client IP address connecting to Cloudflare to the origin web server"
    Interestingly a whois search revealed nothing for that IP
    "rdapConformance": [
    "nro_rdap_profile_0",
    "cidr0",
    "rdap_level_0"
    "notices": [
    "title": "Source",
    "description": [
    "Objects returned came from source",
    "JPNIC"
    "title": "Terms and Conditions",
    "description": [
    "This is the APNIC WHOIS Database query service. The objects are in RDAP format.",
    "This information has been partially mirrored by APNIC from JPNIC. To obtain more specific information, please use the JPNIC WHOIS Gateway at http://www.nic.ad.jp/en/db/whois/en-gateway.html or whois.nic.ad.jp for WHOIS client. (The WHOIS client defaults to Japanese output, use the /e switch for English output)"
    "links": [
    "value": "https://jpnic.rdap.apnic.net/ip/118.161.39.187",
    "rel": "terms-of-service",
    "href": "http://www.apnic.net/db/dbcopyright.html",
    "type": "text/html"
    "title": "Whois Inaccuracy Reporting",
    "description": [
    "If you see inaccuracies in the results, please visit: "
    "links": [
    "rel": "inaccuracy-report",
    "href": "https://www.apnic.net/manage-ip/using-whois/abuse-and-spamming/invalid-contact-form",
    "type": "text/html"
    "description": [
    "The server has not found anything matching the Request-URI."
    "errorCode": 404,
    "title": "Not Found",
    "port43": "whois.apnic.net"
    Very clever of someone.
    Less clever of getwvkeys.cc to let this out to the wild as it clearly contains data to identify users.
    Edit: I have just checked and counted 138634 IP addresses exposed for 'Cf-Connecting-Ip' and 148621 for 'X-Forwarded-For'.
    Last edited by A_n_g_e_l_a; 13th Jun 2022 at 06:19. Reason: Count of exposed IP adresses
  24. I see. So the database a collection of what was asked for in the past.
  25. Member
    Jun 2022
    Ur moms house
    Nah it’s from the future bro, what else would a database contain
  26. Member
    Jun 2022
    Ur moms house
    "cidr0",
    "rdap_level_0"
    "notices": [
    "title": "Source",
    "description": [
    "JPNIC"
    "description": [
    "links": [
    "type": "text/html"
    "description": [
    "links": [
    "type": "text/html"
    "description": [
    "errorCode": 404,
    Less clever of the kid that threw a temper tantrum to leak stuff as revenge.
  27. Member
    Feb 2022
    Originally Posted by Puyodead1 View Post
    Less clever of the kid that threw a temper tantrum to leak stuff as revenge..
    Of course. It takes two to tango though.
    Anyone running a web facing site knows intrusion attempts happen daily.
    So, as a site owner, you have a responsibility to lock up your goodies.
    Encrypt your back-office data.
    Set up your database to only work from local user and one other IP only (yours) - all traffic comes via the local API and is thus seen as the local user.
    Place Nginx reverse proxy in front of everything as a first line of defence.
    Nginx might have helped against the DoS attacks too.
    To be clear; I applaud Ghost for setting up an excellent service for those without their own CDM. The implementation, it appears, was a little naive. But learn from mistakes and build-back better! Onwards and upwards...
  28. Originally Posted by id0ntcar3 View Post
    could you pls reupload it?thanks...
  29. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    https://github.com/GetWVKeys
  30. Originally Posted by Karoolus View Post
    thx but no keys.db inside...
